Question about Ovens
My omega oven 00652XB is not heating up but grill still works, what can I do?
2 Suggested Answers
  • 69 Answers
SOURCE: my omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Posted on Mar 18, 2010
Tip
Omega europa oven control settings
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
on Aug 30, 2010 | Ovens
I have Omega wall oven model 00652xb 6yrs old, there are dribble marks in between the glass in the door. How do I clean it. I can't see how it comes apart. Thanks
The oven glass is a sealed double pane. it is not designed for removal, separation, cleaning, and reassembly.
May 12, 2016 | Ovens
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Dec 06, 2014 | Ovens
Omega OA 25 oven auto turn off?
Is there a way to change from "Fan Forced Oven" to normal conventional heating oven in an Omega OA25 model?
Jan 14, 2012 | Ovens
My omega europa oven is not heating up .grill fan
Mar 18, 2010 | Ovens
Omega oven model number is OO910XA
If it is a common problem with Omega, they may not be ready to admit it. Since it occured 2 times, possibly the hinges use nylon rollers for smooth and quiet operation, but the hinges are not well shielded from the hi heat of 500-600 degrees and the nylon parts fail after a few months constant heat exposure. There is a common problem that happens with oven doors when they do not seam to close tight: besides being old and normally worn, if a door is leaned on while it is open, the hinges could be stretched and then they will never allow the door to close tight. This has happened to many ovens regardless of age, and the customer never realized that the weight or pressure they applied to the door when in the open position has done damage; yet they wunder why the door does not close well. Goodluck,Macgivor
Jan 27, 2010 | Ovens
Omega Europa 20-1 oven. What do the symbols mean?
Oct 03, 2009 | Ovens
Omega europa 40-1 oven settings?
I had the same problem when I moved into my current apartment (mine's the 20-1 model). I was at a loss as to what all those symbols meant, so emailed info@hagemeyer.com.au and they sent me a pdf copy of the manual. It's not exactly the same model as you have, but I assume the symbols are the same. I'm happy to email you my manual if you'd like. Otherwise, the controls (for the 20-1 at least) are as follows:
I hope that all makes sense.
Apr 12, 2009 | Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
