Genius keyboard k639
I press the sleep button"the halfmoon symbol"...then my computer sleep and my problem is how to wake it up, what button will i press in order to activate...
s4u311
  • 813 Answers
SOURCE: Sleep button
u have to aigain press ur sleep button tehen he will be wake uo
or power off ur pc & restart its
Posted on Mar 31, 2008
SOURCE: Saitek Eclipse II: how to retain color choice after computer sleeps?
I think it is just the way it is. mine does that as well. b/c mine does the same thing on any computer i have it pluged into though.
Posted on Aug 16, 2008
SOURCE: Can I disable Sleep Button
If you are using Vista ... control panel.... system and maintenance.... Power Options. On the left there is an option for "Choose what the power buttons do" You can disable the sleep button there. C'mon Compaq... get a brain!! Who's dumb idea was it to put the sleep button there?
Posted on Apr 16, 2009
SOURCE: what is 1/4 moon symbol on top left of my compaq
You are correct. The moon is sleep mode. Closing and opening the lid will often take it out of sleep mode. You might have to "unlock" the keyboard as well by entering a password (just hit return if you haven't entered a password.)
Under power options, you can select what the computer does in sleep mode.
Posted on Jun 20, 2009
billfox1966
  • 231 Answers
SOURCE: I pressed the sleep button on my logitech S510
shut down and unplug the keyboard transmitter from the pc. now remove any batteries from the keyboard and depress several keys insuring the drainage of any stored voltage. reboot pc without the keyboard and then if haulted by error or after booting to windows shut it down, replace the batteries in the keyboard the plud in the keyboard transmitter and restart making sure all components are connected properly. this should rest the keyboard and the system as well.
Posted on Jul 09, 2009
Pressed the sleep button..how do I get it to w"wake-up?"
Is there an actual button on your keyboard that is the sleep button? Or did you put it to sleep within Windows?
If you pressed the sleep button on your keyboard, you should be able to press that button again, and it should wake up. If you pressed it within Windows, then pressing any key should wake it up.
If neither of those works, then sometimes you need to press the power button. Don't hold it down, just press it, and your computer should wake up.
Hope this helps!
Thanks for using FixYa.
Aug 27, 2011 | HP Computers & Internet
My HP w2007 has started clicking to Monitor Going to Sleep and then going blank. I have never known how to wake it up so I have to turn the whole computer off and restart. HELP
Hey there, Normally simply pressing a random key on your keyboard or moving your mouse should wake it up, if it doesn't though I think the easiest way to solve this is to simply turn off the sleep mode after x amount of time.
If you have windows 7, press the start button and type in "power options", go ahead and open power options and there you will be able to set the time it takes before your PC shuts down, and you can also set it to never.
If you still wish to use this feature but just want to be able to it's a bit tricky and it won't even work for all PCs but if the keyboard waking isn't working, then it's probably because your pc does have this feature. When your PC is off, boot it up again and enter the bios by pressing F10 i believe it is for HP. And somewhere you should be able to set which devices are allowed to wake up your computer, all devices are probably disabled now, so go ahead and enable the keyboard to wake up your computer. Now save and exit, and the next time your PC goes to sleep mode you should be able to wake it up by pressing a key on your keyboard.
I hope I was able to assist. If I was, please don't forget to rate this solution.
Jul 28, 2011 | HP Pavilion F1523 15" LCD Monitor
I don't know how to get rid of the speaker symbol in the center of the Itouch screen.
Turn the iPod Touch off and then back on again. Here's how: Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
If this doesn't help, try to reset the iPod touch while it is connected to power. To reset, press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge the device until it is fully charged.
Apr 18, 2011 | Audio Players & Recorders
My keyboard has a quarter moon on a round button top left what is this
Hey,
that is very likely the sleep button, it puts the computer into a low power sleep state, which you can turn it back on by pressing any button or mouse.
just let it go to sleep first before you start pressing other buttons again.
if its not coming up press on the power button once and it wakes up.
let me know if you have any other questions.
Nov 17, 2010 | HP DC170B Keyboard
I put my laptop in the sleep mode as a requirement for using "Magic Jack" and have using the power switch to go out of sleep mode and activate Vista. I read this could cause problems later but don't know...
On most computers, you can resume working by pressing your computer's power button. However, not all computers are the same. You might be able to wake your computer by pressing any key on the keyboard, clicking a mouse button, or opening the lid on a laptop.
It just need an interruption to wake from the sleep mode so its perfectly ok to do so by any key or by the power key....
For any further guidelines give a comment...
Feb 28, 2010 | Computers & Internet
I am running a model 1045 on VISTA. The sleep key puts my computer to sleep but what key wakes it up?
Normally when you put your computer to sleep with your keyboard you only have to press a key on the keyboard to wake the computer again.
I normally use my spacebar to wake my pc but any key should work fine.
Kind regards!!!
Jan 06, 2010 | HP Multimedia Cordless Keyboard/Mouse...
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 29, 2009 | Apple iPhone 3G
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Sleep button
Mar 31, 2008 | Labtec 9675120403 Keyboard
Computers & Internet Logo
David Payne
David Payne
