SOURCE: Instruction Manual for Thane Q-grill.
go to this site http://www.thane.com/manuals/manuals.php then scroll down to the Thane Q-BBQ Grill manual, select it and it will open in PDF formate so you will have a free instant manual.. if this helps please rate me and let me know..thanks and good luck!
SOURCE: I have a Thane Q
This is a solution to the same problem for full size LP gas grills, but it will work for your grill, too. Assuming there is gas in the cylinder (?).
Turn the gas valve OFF and remove the cylinder. Wait 10 minutes and reinstall the gas cylinder.
Ope the gas valve VERY, VERY SLOWLY (Slow motion, slow). Once te vales is fully open turn the valve back 1/4 turn. Now, light the burner and turn it to HIGH. Did the burner light and does the flame height look correct? If so, you solve the problem.
If the above didn't work, either the cylinder of gas is empty or the regulator on the grill is locked up permanently and will need to be replaced.
Hope this helped you and Happy Grilling. Thanks for choosing FixYa.
