A
Anonymous Posted on Aug 01, 2013
Yamaha rx-v671 usb overload issue - Yamaha Audio Players & Recorders
stephane b
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Oct 12, 2023
stephane b
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
855
Points
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
yamaha rx-v671 usb overload issue - ampli r027-w2gpcyn2rttv51s5zcrlhnl2-d-0.png
4 Related Answers
Marek Podmaka
  • 127 Answers
  • Posted on Mar 02, 2010
SOURCE: yAMAHA YDS-11 TO A RX-V459
Hi, as per yamaha site RX-V459 doesn't have the DOCK connector which is used by YDS-11 dock (or the bluetooth module). This is the only possibility to connect the YDS-11. YDS nor receiver don't have USB connector and they are not needed.
For example RX-V465 does have DOCK connector and supports YDS-11.
For your receiver, you can use only analog audio cable with your iPod.
Anonymous
  • 24 Answers
  • Posted on Aug 10, 2012
SOURCE: how do I reset my yamaha rx-v671 receiver?
If there is no apparent cause for the protection mode activating (such as shorted speakers, burning smell, blown fuses, lighting strike or mains power surges), reset the protection as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
Anonymous
  • 24 Answers
SOURCE: Yamaha RX V671 will not turn on anymore after a power outage
The protection mode has activated.
Reset the protection mode as follows and see what happens.
Anonymous
  • 274 Answers
  • Posted on Oct 04, 2012
SOURCE: how to connect Niles #SSVC-6 Speaker Selector to Yamaha RX-V671
Greg, It pretty basic hookup,Just hook it up to your speaker terminal on the reciever or amp.To the input of the (Speaker) Selector.
I want to hook two speakers on each terminal (L/R).
The correct way would be to hook only one speaker to the powered outputs and use PRE-OUT outputs to connect separate amplifier (or active speakers).
For 2 speakers to work connected to the same powered output of receiver, their impedance would need to be high enough. Yamaha receivers officially support impedance >= 4 ohm for front speakers. If you would connect 2 different 8 ohm speakers, the combined impedance could be theoreticcaly 4 ohm, but that depends on many parameters. On low volumes it should work, but could overload the receiver if used for louder volumes.
Also note that the impedance is a function of frequency (specific to every speaker), so for different frequencies the power from receiver would be devided differently between the speakers and the sound would not be good.
1helpful
Yamaha RX-V671 zone 2 no BDDVD audio
Zone 2 cannot pull audio from the hdmi inputs.
CMK-P3X for yamaha reciver RX-V670
  1. I have a yamaha receiver rx-v670.But it's one of part is damage which we not identified.we found a number on part body.VP832 and XK593 CMK-P3K.Please any one inform me the part name.Thanks.
How to connect Niles #SSVC-6 Speaker Selector to Yamaha RX-V671
Yamaha RX-V671receiver does not power on,
you should open the reciver, let it dry and with a thoothbrush clean the circuits.
it could help, but if anyrthing electric is burn inside you need to change it.
4helpful
How do I reset my yamaha rx-v671 receiver?
21helpful
5answers
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
