Question about Craftsman Garden
How to adjust the mower deck on 1050 cub cadet 1050
buffalonyman
  • 1865 Answers
SOURCE: Can I print out the maintenace manual for Cub Cadet Mower
I need the serial number so that I can locate the manual
Posted on Jun 16, 2009
lester482529
  • 226 Answers
SOURCE: I need a diagram for the deck belt on my Cub Cadet
go to partstree.com put in your make &model #.then clickdeck assembly.hope this helps
Posted on Jul 19, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
SOURCE: I have a cub cadet lt 1050 mower and I need to
I just replaced mine today and let me tell you it was a pain in the ****, Had to remove the deck, steering attachment on the underside,and the electric PTO. Took about two hours.
Posted on Apr 01, 2010
  • 13 Answers
SOURCE: I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Posted on Apr 16, 2010
LGTX 1050 Cub Cadet PTO will not engage blades on mower deck
If its an electric clutch it may not be getting power use a test wire from batter touch it to clutch and if you here it engage its ok sometimes the get corroded a bit and wont lick in but sounds like no power to clutch.
Apr 05, 2017 | Cub Cadet Garden
Why does my cub cadet have a different cutting deck as shown on the parts diagram. The tension spring came off and I need to know how to attach.
The tension spring connects behind the deck on the mower frame it will have a notch that the spring will connect to. You should be able to see where the paint may be missing or scratched from where the spring was previously
Mar 26, 2016 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
Wiring diagram
I have a 2009 LT 1050. I acquired my parts and electrical diagram from Cub Cadet. Go to their website, follow menu's to find your manuals.
Aug 10, 2015 | Cub Cadet LTX1045 2009 and After Deck Belt...
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Cub Cadet LTX 1050 50 inch. How do I get the deck belt over the PTO?
A common problem:
Make sure that:
1) You have the right belt if it's a replacement.
2) The mower control is in the "DO NOT CUT" or "NOT ENGAGED" position.
3) The tension idler has fully retracted.
Jul 18, 2015 | Cub Cadet Garden
How to replace drive belt on cub cadet 1050
Fairly easy to replace once the deck and the electric PTO are removed just make mental notes or rough of the belt path before removing the old belt. One thought if I remember correctly this uses 7/16" belt and a 1/2" width will not work due to the tight clearance at the engine pulley so stick with OEM belt.
Oct 14, 2014 | Cub Cadet Garden
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Garden Logo
13 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
