Question about Honda Garden
Won t run without choke - Honda Garden
    Master:
  • 969 Answers
Rebuild or replace carb. Replace all carb gaskets.
Posted on Jul 04, 2015
Idles with 1/2 choke. If open choke, or throttle - engine dies without any RPM spike. Carb was cleaned, jet is clean. When idles, there is gas in the primer bulb.
Hi, Andrew and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Bike won Run without Choke
Dirt Rider Magazine
Bike starts up idles on choke dies with choke off our when warm XS650 Forum
What could be wrong if bike will only run on choke
Mar 10, 2016 | GAS Motorcycles
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Thundercat won't run without full choke
is airbox and filter all good no leaks, could be blocked small jet in carb, will it run ok higher in rev range
Mar 09, 2013 | 1995 Yamaha FZR 600
MTD SNOW BLOWER WON'T RUN WITHOUT CHOKE ON
If it will only run on full choke you have an air leak somewhere
Jan 21, 2013 | Garden
Replaced all fuel lines and pickup fuel filter. but won't stay running without choke.
Take the carburetor off and clean it and check and replace any air filters you may have. Can't say that this will fix it ,but it is a starting point for you. Hope it works and good luck.
Dec 01, 2012 | Poulan P3416 16Inch 34cc 2Cycle Gas...
2007 Yamaha Roadstar will not run unless the choke is wide open
Hi, Anonymous and the usual suspects are:
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Re bike won run unless on full choke Road Star Forum Yamaha Road Star
Yamaha XVS1100 Service Manual
OEM parts for Yamaha
YAMAHA XVS1100 Owner Manual
Oct 19, 2012 | 2005 Yamaha V Star 1100 Silverado
Yamaha royal star xvz 1300 won't idle without choke
2003 Star 1100 Custom won idle without choke aftermarket exhaust
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
https://www.tradebit.com/filedetail.php/243740175-1996-2001-yamaha-royal-star-xvz13a-service-manual
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
Jan 01, 2012 | 1996 Yamaha Royal Star XVZ 1300 A
Motorcycle starts on full choke but will not run even given more fuel even if the choke is turned off after warm up
Hi, Edward and the usual suspects are:
Yamaha XV535 runs only on idle choke
Yamaha XV 535 DX Virago Service Manual
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Nov 13, 2011 | 1994 Yamaha XV 535 Virago DX
Mower starts and runs but has no power acts like its flooding it burns a lot more gas can barley pull it self
Sounds like maybe the choke is stuck closed. If you remove the air filter the choke is the first butterfly valve you can see. The throttle looks similar but is a inch or so deeper into the carb, and you can't see that unless the choke is open. Try removing the air filter and starting the mower. It might run just a little better without the air filter since it will get a bit more air, but if the choke is stuck it still won't run right. But you will be able to see if that's the problem right off. If it runs great without the air filter, and the choke is not stuck, then the problem is a clogged air filter and you need to replace it. Good luck, Al K
Jul 26, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
1980 Yamaha xt250 won't idle without the choke being on
Hi, Earthquakeau and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Older XT250 Won Run Some Choke
Yamaha XT250X Service Manual
Yamaha XT250 Owner Manual
Feb 14, 2011 | 2008 Yamaha XT250
Garden Logo
37 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
