Question about Cell Phones
Input sim2 puk - Cell Phones
"Sim2 is now disabled enter PUK code to continue" message. What to do?
The sim which was there in sim 2 slot call the customer care of that service provider from other mobile and ask for puk code
Jun 04, 2015 | Cell Phones
Hi my sim card is block, my i get the PUK number? thanks,, ninoy32
of course not, because maybe you are liable to kip that puk number yourself. maybe your network partner can help you. and the only chance to do retrieve your sim card is to talk to your network provider.
Jul 15, 2011 | Cell Phones
My DLP projector SIM2 DOMINO D35 is turned on and works normally BUT picture is absent on all of inputs (projector shows NO SIGNAL, green indicators is ON). Sources of signal and cables are in order. What...
It is possible that the last time this was connected there must have been an higher input applied than is recommeded so that the input PRE_AMPS were loaded to fail.
You need to check with an signal trace on the input to find if an OP-AMP has failed or the LOGIC switching IC had failed.
Need to test using a signal tester and meter.
Jul 14, 2011 | SIM2 DOMINO D35 DLP Projector
I have k46 karbonn mobile and I forgot the password to unlock the phone. pleasehelp me
I HAVE KARBORN DUAL SIM,K330 SIM 2 BLOCKED,IT IS ASKING SIM2 PUK
Mar 12, 2011 | Cell Phones
9487315393 this number puk sim2
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Jan 21, 2011 | Nokia 1100
Sim2 blocked
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater Same Your No Problem will Solved
Nov 30, 2010 | Cell Phones
Hello i have china phone i9++i model in security set up sim2 it was asking puk2 pl send the puk2
The easiest way to get the PUK code is to call your service provider, such as T-Mobile or Verizon. They need to verify your cell phone number and your IMEI number and they will provide you with the PUK code.
Hope this helps,
Joe
Feb 04, 2010 | Dual Electronics CECT P168 Cellular Phone
I68, not read sim
Change of the SIM Places that you inserted !
Insert your working SIM1 to phone SIM2 SLOT Insert your not working SIM2 to phone SIM1 SLOT
Solution :
  • If your SIM2 that you inserted into SIM1 SLOT remain not working !
  1. Your sim card is defected or Phone does not support this sim card!
  • If your SIM1 that you inserted into SIM2 SLOT is not working
  1. There is a problem with phone's SIM2 SLOT
In case of SIM2 SLOT problem i can help you to get it fixed contact : omniarepair at gmail dot com
Best Regards
Jun 24, 2009 | Dual Cell Phones
Trying to update Firmware on a Sim2 HT300
Take it to an Authorised SIM2 service agent . Some things are just not for the DIY
Dec 19, 2008 | SIM2 HT300 Multimedia Projector
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
