Question about Echo Garden
My echo 600cs chain saw locked up recently, Ithought the engine seized up. When I removed the chain and bar I discover that the sprocket was broken which caused damage to the chain, bar and adjuster. Has anyone else had a sprocket break in pieces like this? The dealer is blaming me for misusing the saw, but it suddenly failed while sawing normally.
    Problem Solver:
  • 11 Answers
Happens quite often. you need to replace the sprocket more often, as this is normally associated with wear & tear
Posted on Jul 23, 2014
  • 24 Answers
SOURCE: poulan 2600 chainsaw
check and make sure you have the correct sprocket.is your chain .325,3/8?sprocket has to match as well as chain and bar
Posted on Oct 20, 2008
  • 22 Answers
SOURCE: Makita 5012B chain cannot be tightened
some chainsaws have different knotches where the bar locks onto the saw. loosen the nuts and see if you can move the bar.
Posted on Dec 13, 2008
SOURCE: poulan pro series chain saw 20" bearings seizing up on bar
There's a tiny hole on the front of the bar near the bar sprocket. This is used to grease the sprocket. If you go somewhere like Lowe's look in the chainsaw section and you'll find a grease tube that is specially designed to lube the front sprocket. Before lubing use a small wire to clean out any debris from the whole. Press the lube tube against the hole and push repeatedly until grease comes out from the outside of the bar. This should greatly extend the life of the bar.
Posted on Jan 09, 2009
  • 398 Answers
SOURCE: need to know oil to gas ratio mix for echo 510 evl chain saw
50:1 or of its old 100:1
Posted on Mar 20, 2009
VtToolMan
  • 704 Answers
SOURCE: Chain tightens up under power to point engine stalls
If you've already tried to tighten the bar tensioning nuts and the bar keeps "creeping" and gets tighter, that is unusual, as most times the bar should get looser, not tighter.
I would suggest you try a new bar and set of tension nuts, or at the very least a new set of tension nuts first.
The problem might be the tip sprocket has worn out (it needs to be lubed every time you add bar & chain oil to the reservoir in the chainsaw). If the tip sprocket is worn badly, you should replace the bar and inspect the cutting chain for excessive wear on drive side of the chain.
Remember that the slightest bit of dirt can cause rapid wear of the bar and chain and quickly ruin it beyond repair.
I hope you find this helpful and best regards!
Posted on Aug 06, 2009
Chain keeps slipping off saw
Remove the bar and chain. Lay the chain out on a bench or table and examine for sideways bent/broken links, badly damaged cutting teeth, or damaged drive teeth. Inspect the bar chain-groove all the way around for any damage. Make sure the tip sprocket turns freely and is not damaged. Check the sprocket on the clutch drum for hooked teeth or other damage. Clean the small oil passages that feed oil out to the chain groove in the drive end of the bar. Start the engine and check the engine side port where the bar fits to--it should ooze out oil from the small port there. If everything checks ok, re-assemble the bar and chain leaving the cover fasteners finger tight. Adjust the chain until it pulls up to the bar, but not so tight that you can't turn turn it by hand. Tighten the bar fasteners and re-check the chain tension. Start the engine and hold the bar tip near some cardboard--it should throw off a thin line of oil after several moments of running at speed. Hope this helps!
Jul 17, 2010 | Craftsman sears 18" Chain Saw Chain (...
Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Jun 25, 2010 | Echo CS400 18" Chain Saw
Chain jumps off guide
Remove the bar and chain. Lay the chain out on a bench or table--inspect it for sideways bent or broken links. Check the chain drive teeth for damage as well as the sprocket drive teeth. Inspect the bar chain groove for damage or sideways bending, also the tip sprocket for free turning. Start the engine after cleaning the bar mounting area on the side of the engine, it should ooze out oil after running for a short time. Clean the bar drive-end oil passages which run out to the chain groove. Clean the entire chain groove. If all checks ok, re-assemble the bar and chain, but leave the mounting fasteners finger tight. Tighten the chain until it pulls up to the bar bottom, but not so tight that you can't move the chain by hand. Tighten the bar fasteners firmly and recheck the chain tension. Start the engine and run the bar tip near some cardboard at speed for a few moments--it should throw off a thin line of oil. Hope this helps!
May 12, 2010 | Craftsman 18" Chain Saw Replacement Bar...
Chain came off ,need to know how to put it back on!!!
On the chain saw there should be a panel held on by two screws or nuts where the bar and chain is attached. Remove the two screws or nuts and the panel and you will expose the chain and sprocket. Loop the chain around the sprocket and bar. Put the bar with the chain around the sprocket back on the saw, reinstall the cover with the two screws/nuts, but do not tighten too tight.(You will want to be able to move the bar with the chain.) Then pull the bar away from the saw to tighten the chain, once the chain it tight, then you will retighten the screws or nuts to lock the bar and chain in place. Be sure you lube the chain and bar with "Bar Oil" before starting to put the saw into service. Good Luck...I hope this helped Please rate me, Thanks
Jan 04, 2010 | Water Heaters
Echo chain saw sprocket not turning.
A few clicks form here will get an Illustrated Parts Manual, I find them them helpful.
EchoUSA
http://www.echo-usa.com/faqs.asp
If I read the pictures correctly it has an outboard clutch, this may also be helpful.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
Lou
Nov 11, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
The chain on my Remington electric saw keeps jumping the sprocket. Solution? Thanks.
Depending to what model you have, the Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. Or your cahin is not tensioned properly. According to the manufacturer... "The adjusting block on the adjusting screw isn’t inserted into the adjusting hole on the guide bar. Reinstall and align the sprocket cover by first removing the sprocket cover from the saw. Turn tensioning screw on the sprocket cover counter-clockwise until it stops. Pull guide bar away from saw body to remove slack from chain. Insert sprocket cover tab into saw body tab slot and lower sprocket cover into guide bar bolt. Finger tighten guide bar nut onto guide bar bolt. Slowly push guide bar toward saw body until adjusting block on the adjusting screw drops into round adjusting hole on the guide bar. Securely tighten guide bar nut after properly tensioning saw chain." If these tips do not work, you may need a new chain. You can order an new chain on-line at www.masterparts.net. I hope this helps you!
Jul 01, 2009 | Remington Electric Chain Saw
The chain will not engage
problem corrected.......I pulled the chain and bar off of the saw and discovered that the chain had seized up in the channel due to some slight "boggering" of some of the inside teeth that ride the groove on the edge of the bar. I filed the damaged metal on both sides of 8-10 damaged teeth (the chain was otherwise in good enough shape to continue to use). I then pulled the whole length of the loose chain through the chain sprocket end of the bar by hand to make sure that I had filed enough of the damaged metal away, before I reassembled the saw. There was slight damage to the drive sprocket, but not enough to prevent the saw from functioning properly. All is now well in the my chainsaw world......and the saw will get a new drive sprocket for Christmas.
Mar 22, 2009 | Poulan Garden
How do you replace the chain drive sprocket on an Echo CS-440?
you need to replace the clutch, you woould pull the side cover off and remove the bar and chain. then you remove the nut holing the clutch on( the clutch and sprocket should be on piece) take it to your local saw shop and grab a naw one.
Mar 18, 2009 | Garden
Poulan pro series chain saw 20" bearings seizing up on bar
check sprocket isn't worn it may be pulling on chain than over heating bearing. check pitch of chain ,bar , sprocket are the same.
Dec 29, 2008 | Poulan Garden
Open Questions:
Garden Logo
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
