Question about Canon EF 70-200mm f/2.8L IS USM Autofocus Lens
I have a Canon 70/200 lens that when autofocus seems to keep jumping and can not sit still to focus on an item. This has happened numerous times to me while shooting an indoor church wedding...any suggestions?
    Sergeant:
  • Canon Expert
  • 488 Answers
If it focuses OK in manual mode then there is a possibility that you have a damaged ribbon cable in the lens.
Posted on Aug 31, 2016
poolseman
  • 206 Answers
SOURCE: lens auto focus sometimes does not work.
First make sure contacts on lens are clean ( see enclosed pic #2 ) . If this does not solve the problem the ultrasonic motor may be faulty pic #1.( sometimes switching on but sometimes not , will have to be replaced , unless there is a bad connection between the motor and lens pc board )
Posted on Nov 26, 2007
cammedic
  • 667 Answers
SOURCE: Canon 70-200mm f/2.8 IS lens not focusing
I have had to replace the focusing servo motor is these before. The problem of seeking without locking in may mean the same for your lens. Do check for a dirty filter on the front and look to see if the rear optic is dirty or cloudy first. I'm assuming other lenses work fine on your camera.
Posted on Jan 05, 2008
jackboy
  • 2985 Answers
SOURCE: Canon EF-S 17-85MM F/4-5.6 IS, Canon 28-300 L IS
You will have to refer to Canon re this - it possible the firmware update did not take or was the wrong one.
Posted on Apr 24, 2008
  • 83 Answers
SOURCE: My Canon EFS 18-55 mm lens stop focusing
Unfortunately, unless you suspect dirt in the lens (been taking pictures on the beach maybe? ;), this sounds like autofocus motor failure.
Even if you manage to source the replacement motor, swapping it is a really fiddly operation.
I would suggest selling the lens for spares on ebay and getting a new one.
They are fairly cheap these days. I recommend getting the IS version - it's much better than the original, although build quality is similar.
Good luck,
Raf
Posted on Nov 09, 2009
  • 77 Answers
SOURCE: Auto focus not working?
1st u reset the factory setting and then u see the lense is correctly fitted or not and the autofocus option is working or the manual focusing is there or not
Posted on Dec 14, 2009
Canon Ef_S 18-55mm f/3.5-5.6 Lens won't focus in manual or auto mode
If the camera is used you may have a problem with the seller. Before jumping into conclusions however read your manual for your solution or simply search youtube for a help video. Hopefully this helped.
Feb 14, 2014 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Autofocus problem on canon 135mm f2
If it focuses OK on manual focus and won't focus on auto focus the problem may be down to a broken ribbon cable in the lens.
May 06, 2017 | Canon EF 135mm f/2.0L USM Telephoto Lens...
Canon 7D -I have my setting on one shot - in any mode.- Lens: Canon 17-85mm. The autofocus jumps back and forth no matter where I focus at.
it means the lens is about to die.
i get same problem with my nikon 18-55 mm lens. the solution for my problem was that i shift from autofocus to manual focus on the llens and then back to autofucus. the lens works fine for me then :P
u can try the same thing.
Mar 02, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Autofocus gives erratic results
Are you using this indoors, in low light perhaps? This would be the most common reason for this happening. The only way to get around that is to use a "faster" lens, such as f2.8 / f1.8 / f1.4 etc.
If not, try cleaning the lens and camea contacts with a plastic eraser, make sure no debris falls in the camera body (hold upside down for this).
Jun 02, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Jan 10, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Autofocus jumps around and often will not settle on the correct setting
what i do is usually put it onto manual focus then back to auto focus, what it may be is that you are using the wrong lens for your subject :/
Feb 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
70-300DL Macro Super autofocus problem
It is likely that the lens will need parts. Sigma is not the best for repair parts. Typically, the small nylon gears that control the AF break. It is still a useful piece in manual focus. Repair costs would likely exceed its value.
Feb 17, 2008 | Cameras
Jan 05, 2008 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
Autofocus is stuck on Quantaray 28-200mm F3.8-5.6
NEVER open it up. You will destroy the dust seals. Have Canon repair it.
Apr 15, 2017 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Canon EF 70-200mm f/2.8L IS USM Autofocus Lens Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
