Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper feeding The printer is only feeding the paper through on the right side, it starts feeding and then jams on the left side. I've checked for small pieces of paper-don't see any, have tried clearing the dust out of it... Please help!!!!
  • 3 more comments
  • Cirulic Aug 31, 2007
    Yessssss!!!!! Fixed, thank you very much :))
  • BUTCHB Nov 01, 2007
    same problem but on MP450...I tried your suggested remedy....no result
    Paper takes off...feeds approx 1 or 2 inches and stops...gives paper jam message ... eventually a sheet will feed OK after 4 to 6 retries
    When pulling out sheet towards back feeder I feel light pressure on right side only
    paper often takes off entering right side only then jams
  • Anonymous Nov 04, 2007
    the paper only goes in on the right side where the wheel is the other side doesn't grab the paper
    there is nothing in the way i turned it upside down and shook it and that didn't help
  • mystika25 Nov 09, 2007
    the paer is feeding but it tilts to the right side and crinkles im trying to look in it checked the rolle and still no idea how to fix it please help
  • Anonymous Mar 16, 2014
    The paper will not feed into the printer, especially on the left side. It's as if it is not catching. The paper crumbles up, it doesn't get stuck in the printer, it doesn't even go in.
Thank you, thank you, thank you!!!!!!!!
Posted on Oct 27, 2007
Me too!!!!thanx
Posted on Sep 05, 2007
  • 78 Answers
Take the ink out. Turn the printer upsaide down and give it a real good shake. You DO have something either stuck in the feeder on the left or there is a component sticking out of place. a REAL GOOD SHAKE normally fixes the problem
Posted on Aug 31, 2007
SOURCE:
Paper jam door - I cannot open this no my HP 8250.
Turn off the printer, then unplug it from the power source. Clear the
printer of any paper that may be obstructing the paper path. Remove the rearaccess door. Gently remove the jammed paper from the printer, then replace therear access door.
Remove the rear access door to clear paper jams.If you cannot remove all jammed paper from the rear area of the printer, tryremoving paper jammed in the middle of the printer by opening the paper jamdoor located inside the top cover.
Open the paper jam door to clear paper jams in the middle of the printer.Plug the printer back in and turn it on.
In case of any doubt go to the following link and act accordingly
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00386753&lc=en&dlc=tr&cc=us&product=443024
Sep 25, 2011 | HP Photosmart 8250 InkJet Printer
As the paper starts to feed through, it jams on the left side, as if the left side roller is feeding the paper in faster than the right side
Take a soft cloth (not paper towel) moistened with alcohol and clean off the rollers that pickup the paper. Make sure you clean the entire roller. Chances are that there is paper dust on one or more rollers and they're slipping, causing the jam.
Feb 26, 2011 | HP Photosmart 2610 All-In-One InkJet...
My printer will not feed the paper properly. It
There must be a jam on the left side then. Open and look inside for the paper issue
Jun 16, 2010 | Lexmark JetPrinter Z11 InkJet Color...
Paper jams on right side when facing the printer
Please follow these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to t
May 01, 2009 | Office Equipment & Supplies
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
LEXMARK 2470 PAPER FEEDER PROBLEM
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck....
Sep 13, 2008 | Office Equipment & Supplies
Printer will not feed paper correctly
there were may situation that can help with this trouble,
1- try to see if the trays are seated correctly no bend or twisted
2- try to check the quality of your paper no concave nor convex ( like U or N)
3- clean the feed roller from either side by moistened cloth, ( only on one direction evenly
4- ensure no hindrance on the paper path inside the machine
5- reset the unit once more
let me know if you need some more
Jul 25, 2008 | Office Equipment & Supplies
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Paper Jamming
Could be a faulty roller, or jam you have not found yet. Check again with a torch right up insied unit. If no go, try uninstalling and reinstalling printer.
Jun 29, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Paper Mis-Feeding
Check for any pieces of torn paper in the path, especially on the left side. You can also reach into the slot that the paper feeds into and feel each of the rollers behind the plastic cover; they all should turn freely, pay special attention to the wheel to the left.
Mar 25, 2007 | Canon i850 InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
83 people viewed this question
Clive
Clive
old marine
old marine
Ekse
