Question about Emerson CKS3029 Clock Radio
LED not display time
LED Display for Emerson Model CKS3029 does not display the time. Is it the battery. Lithium CR 2430 3v If so where do I get a new one.
  • Sprinter220 Sep 03, 2007
    The solution was quite simple. My wife told me the radio woke her up in the morning, so it had to be operational. After spending a lot of time on the internet and taking the battery out. It suddenly worked. She explained that it had not been plugged in. You might add this to your solutions. I feel pretty inept.
    President:
  • 1,114 Answers
Depends where you are in the world, try a google search for CR 2430 as below and add your country: http://www.google.co.uk/search?hl=en&q=CR+2430&btnG=Google+Search&meta= Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 31, 2007
SOURCE:
Had to open radio to clean it because of static. Where does piece of cardboard go?
It is not a good idea to "open" electronic devices when you are not familiar with them. Next time take a photo of each step so you can recreate your "dismounting procedure.
Actually, it's the firt time I read that the Emerson CKS3029 Clock Radio has a piece of cardboard inside.
Aug 04, 2015 | Emerson CKS3029 Clock Radio
After a power outage of approximately 45 minutes i have no display
Hello
There is a Lithium battery inside your clock to get a backup even the power is interrupted for a long time. This battery may last up to 3 years eventhough there is no power to the device. If this has gone weak, the backup fucntion will not be. so check this battery.
Just reset the device. It will make it work properly. To reset the clock after total memory loss; do the folloing.
[1] Connect the radio to your AC outlet and let the clock set itself.
[2] Depress the MONTH/DATE and TIME buttons together. The display will change
from 'Time'to 'Year'
While holding the MONTH/DATE and TIME buttons, press the SET + button
to set the display to the correct Year, then release the buttons
OK.
Jul 24, 2011 | Emerson Smartset Clock Radio
I have had my radio for many years but when I wanted to put it in another room it displays a half "L" on the display when I plug it in. Do I have to replace the battery when I'm using an...
Hello
You haven't specified nothing about your Emerson Smartset Clock Radio. Nothing is there about its model number. Yet I posts this solution before you assuming that yours' is a CKS3528 Emerson Clock radio.
There is a long life lithium battery installed in this clock radio when you buy it.
This battery can maintain the time and alarm settings for 3 to 5 years, or even
longer, so there is no need to pay for a new 9-volt battery every 6 months, as
is recommended in other clock radios with normal battery back up.
But if this lithium battery has gone down [ in terms of voltage]; the display 'L" will be there. It means that, it is time to replace this backup battery. It will be of disc type, usually used as bios setting storage, used in computers. OK.
May 13, 2011 | Emerson Smartset Clock Radio
Even if full batteries are loaded in the S60 , when turning on , display says "batteries empty" and camera goes off.
Alkaline batteries are not supported
use either lithium AA or CR-V3 batteries or rechargeable Ni MH AA batteries
Aug 08, 2010 | Pentax Optio S60 Digital Camera
Changing alarm dates
Press the "alarm mode" button and change it with the + and - buittons. On the display you should see what days it will go off.
Jan 05, 2009 | Emerson SmartSet CKS1850 Clock Radio
Daylight Savings Times Changed
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
Oct 29, 2007 | Emerson Smartset Clock Radio
Daylight savings time adjustment
Go to:
http://www.emersonelectronics.ca/emerson/en/product/details/VLJT600
or
http://www.emersonelectronics.ca/emerson/en/category/list/694
The solution appears to be common for all recent Emerson SmartSet(tm) radios (BTW it's not the clock fault, it's the law).
Remarkably Emerson foresaw this, so here we go.
Short version (may require three hands :-) )
DST start:
Press and hold MONTH/DATE and ALARM 1 buttons for at least 3 seconds until the display changes to something like "4 F" (Fourth month, First week) alternating with something like "4. 1" (April 1st, for 2007) or "4. 6" (April 6th, for 2008). While holding down the MONTH/DATE and ALARM 1 buttons, now press the DOWN or "-" Set button (3 times) until "3F2" shows (Third month, second week) alternating with something like "3.11) (March 11th, for 2007) or "3. 9" (March 9th, for 2008). Let go of all buttons and we are now half done.
DST end:
Press and hold MONTH/DATE and ALARM 2 buttons for at least 3 seconds until the display changes to something like "10 L" (Tenth month, Last week) alternating with something like "10.28" (October 28th, for 2007) or "10.26" (October 26th, for 2008). While holding down the MONTH/DATE and ALARM 2 buttons, now press the UP or "+" Set button (1 time) until "11 F" shows (Eleventh month, first week) alternating with something like "11. 4" (November 4th, for 2007) or "11. 2" (November 2nd, for 2008). Let go of all buttons and we are now done.
This should remain until either the lithium battery fails or Congress undoes its work.
BTW the Emerson addendum has a history error. The time change in the first Sunday in April and the last Sunday in October did not start in 1966, but in 1987. Before that starting in 1966 the standard was set at the last Sunday in April and the last Sunday in October. Except for 1974, when it was January 6th, 1974 (DST start) and October 27th, 1974 (DST end) and in 1975 when it was February 23rd, 1975 (DST start) and October 26th, 1975 (DST end). Before 1966, state and local governments had many different rules. Source: http://webexhibits.org/daylightsaving/e.html
Oct 28, 2007 | Emerson CKS3029 Clock Radio
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Emerson clock radio model cks3029
When you set the alarm make sure that it is set to go off on the day of the week desired. This clock has the feature to allow for weekday, weekend, or both. The alarm mode button while the alarm set button is pushed to change. Observe the LED's below.
Jun 27, 2007 | Emerson CKS3029 Clock Radio
Emerson CKS3029 Clock Radio Logo
143 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
