Question about Hoover S3670 Bagged Canister Vacuum
Hoover s3670 power head will not turn on, opened it up, band is ok, what else could it be
3 Suggested Answers
  • 2006 Answers
SOURCE: No electrical continuity within the hose of my
Those hoses are pretty close to being a sealed unit, and was meant to be replaced and not repaired. That being said, some people do fix the problem IF they can locate the problem close to either end. Most people won't mess with an open in the middle of the hose.
Unfortunately, since they are designed to be a replaced item and not a repairable item, there is no written instruction on disassembly. So it is one of those to times when you study your hose and figure out when the break is and then decide on if it is worth attempting a repair.
Posted on Aug 10, 2011
roden_matt
  • 91 Answers
SOURCE: no power to hoover s3670 canister vac
either need a new motor or speed control board.
Posted on Mar 27, 2013
No power to vacuum head
You've probably blown the 5a fuse on the control board. This
fuse is pretty much hard wired in - I had to solder in a replacement.
Aug 21, 2013 | Hoover S3670 Bagged Canister Vacuum
No power to hoover s3670 canister vac
Mar 27, 2013 | Hoover S3670 Bagged Canister Vacuum
Change fuse for power head
salut leo as tu un probleme avec ton aspirateur ,,moi je vien de reparer le mien ,,si tu as des question ecrit moi et si je peut aider ca me fera plaisir...
Mar 25, 2013 | Hoover S3670 WindTunnel Bagged Canister...
Power head not working
Steve:
The terminals for the power head plug into a terminal inside the machine. You'll need to unplug the machine from the wall and open the canister to find where the terminal wires plug into. You probably need to open the lower half of the canister to find those terminal plugs. It would help if you have a multimeter. The wires actually run through the hose, so I would check the hose carefully to see if the wires have been damaged there.
Jan 06, 2013 | Hoover S3670 Bagged Canister Vacuum
Hoover s3670 opening the vacuum case
there are screws under the power switch and the cord recoil switch. the switches pry off lengthwise. once the switch covers are off you will see the rest of the screws. it was pretty straight forward from there.
Jan 02, 2012 | Hoover S3670 Bagged Canister Vacuum
I have hoover S3670055 when I turn it on the power head does not come on when when you press the switch on
I too am having difficulty. Everything seems fine electrically. I only get about 350 mv AC Power with the switch off and 1.7V AC with the swiitch on. I would think the power brush head would require DC voltage of some sort.. Like 12V???
Sep 26, 2011 | Hoover S3670 Bagged Canister Vacuum
No electrical continuity within the hose of my Hoover S3670 Vacuum Cleaner. How do I disassemble bothe wnds that house the actual connections?
Aug 10, 2011 | Hoover S3670 Bagged Canister Vacuum
Have a Hoover model S3670 and the beater brush no longer spins. Have checked the beater belt and it is good, did find out that the light bulb in the unit was bad. Any suggestions on how to test the motor...
I usually test the motor with a cord with alligator clips on the wires, and attach them to the black and white wires on the motor ( remove the belt first ). A very common problem with this model was a short circuit developing in the short cord that runs from the nozzle motor into the swivel neck. This is probably where the problem lies. Replacing the cord is best left to someone with experience.
Apr 19, 2011 | Hoover Vacuums
Hoover s3765 windtunnel power head does not run
I have the exact same problem as you have. Have you found a solution since you posted on Mar. 18, 2009? Thank you.
Mar 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover S3670 Bagged Canister Vacuum Logo
67 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
