Question about Hoover S3670 Bagged Canister Vacuum
Hoover S3670 powerhead will not turn on, vacuum itself works
reddevil6
  • 1673 Answers
SOURCE: Hoover U5344-950
Is it a rubber smell or an electrical smell, If it is a rubber type smell then maybe the belt or brushroll has a problem. If is a electrical smell, then would be coming from the motor. How long have you had this? Hoover has a one year warranty, so if it less then a year, take to a shop that does Hoover Warranty. You can call theur 1-800 number and they can tell you where you can take it. The number is on the metal tag where the model number is.
Posted on Jan 22, 2008
  • 1619 Answers
SOURCE: Hoover Elite Rewind - powerhead brushes are not
most likely band is broken. Usually there is a spare in the box or on the unit when new. Unscrew 2-3 screws by beater bar (brushes) pull off cover and replace band.
Posted on Jul 09, 2009
  • 53 Answers
SOURCE: I have a hoover celebrity QS wuith the power head.
You have done very well keeping this appliance working since 1975!!!
Lucky you!
I'm not certain you would be able to get replacement parts for this model any longer,
Maybe you will just have to continue with the powerhead only.
Posted on Nov 17, 2009
  • 2006 Answers
SOURCE: No electrical continuity within the hose of my
Those hoses are pretty close to being a sealed unit, and was meant to be replaced and not repaired. That being said, some people do fix the problem IF they can locate the problem close to either end. Most people won't mess with an open in the middle of the hose.
Unfortunately, since they are designed to be a replaced item and not a repairable item, there is no written instruction on disassembly. So it is one of those to times when you study your hose and figure out when the break is and then decide on if it is worth attempting a repair.
Posted on Aug 10, 2011
roden_matt
  • 91 Answers
SOURCE: no power to hoover s3670 canister vac
either need a new motor or speed control board.
Posted on Mar 27, 2013
No power to vacuum head
You've probably blown the 5a fuse on the control board. This
fuse is pretty much hard wired in - I had to solder in a replacement.
Aug 21, 2013 | Hoover S3670 Bagged Canister Vacuum
No power to hoover s3670 canister vac
Mar 27, 2013 | Hoover S3670 Bagged Canister Vacuum
Hoover s3670 opening the vacuum case
there are screws under the power switch and the cord recoil switch. the switches pry off lengthwise. once the switch covers are off you will see the rest of the screws. it was pretty straight forward from there.
Jan 02, 2012 | Hoover S3670 Bagged Canister Vacuum
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
I have hoover S3670055 when I turn it on the power head does not come on when when you press the switch on
I too am having difficulty. Everything seems fine electrically. I only get about 350 mv AC Power with the switch off and 1.7V AC with the swiitch on. I would think the power brush head would require DC voltage of some sort.. Like 12V???
Sep 26, 2011 | Hoover S3670 Bagged Canister Vacuum
No electrical continuity within the hose of my Hoover S3670 Vacuum Cleaner. How do I disassemble bothe wnds that house the actual connections?
Aug 10, 2011 | Hoover S3670 Bagged Canister Vacuum
I have a hoover celebrity QS wuith the power head. I have only used the powerhead for years purchased in 75) I removed the powerhead to use the brush and the power does not come on but if I put the...
Lucky you!
Nov 17, 2009 | Hoover Vacuums
Hoover Elite Rewind - powerhead brushes are not turning
Jul 09, 2009 | Hoover U5507900 Elite Rewind Bagless...
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Hoover S3670 Bagged Canister Vacuum Logo
73 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
