Question about Air Tools & Compressors
I need an owners manual and carrying case for a paslode 404466 framing nailer paslode website not helpful.
  • 1388 Answers
SOURCE: nail gun will not shoot
Not all 120psi air supplies are the same. Here are some differences. The pressure regulator has a great deal of effect on the performance of the air tool. Regulators are sold by the volume of air (cfm)that they can handle. The more cfm the larger the pipe fittings on the regulator. A 1/4 fitting regulator will restrict the air somewhat compared to a 3/8. Another difference is weather moisture is present in the air. Moisture will temporarily help seal the orings, however too much water in gun will cut the orings. The air hose and fittings will also stifle performance. Long small diameter hose will lower pressure at the gun. This can be measured by installing a guage on a T fitting on the end of the hose and watch the pressure as you fire the gun. Larger fittings and hose ID will improve performance. Finally, your nail gun should work on both compressors. To make your nailgun work at home, (assuming that there are no air leaks) lube the headvalve parts with silicone grease. (sold at lowes in plumbing dept) For best performance, replace the orings in the head valve, examine the plastic parts where the orings contact and look for wear and tiny scratches (use magnify lense). Replace these worn parts along with orings. Replace the head gasket and make sure that the body and the head-cap are not warped. Place sheet of fine sandpaper on flat surface, with cylinder removed rub the body of the gun on paper a few times to check for warp. Do same with cap. Parts are available at www.toolpartsdirect.com. Enjoy
Posted on Dec 14, 2008
Idaho_Biker
  • 32 Answers
SOURCE: Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
Posted on Mar 27, 2009
lester482529
  • 226 Answers
SOURCE: Paslode 5350/90S PM Powermaster Bends nails over
USUALY THIS IS CAUSED BY TO LOW OF AIR PRESSURE(NEED AT LEAST90-100PSI)OR NAILING INTO SEASONED HARD WOOD SUCH AS OAK,OR THE WRONG DEGREE PITCH OF THE COLLIATED NAILSHOPE THIS HELP'S.PLEASE RATE THIS .
Posted on May 23, 2009
rowdy45176
  • 2176 Answers
SOURCE: looking for a manual for an Hitachi Framing nailer
Go to Hitachipowertools.com and type in your model number and you can download a manual for this tool
Posted on Oct 27, 2009
rowdy45176
  • 2176 Answers
SOURCE: Paslode IMCT Cordless Framing nailer INOP.
yes it will did you test the spark, connect the battery to the tool and push the switch does fan come on?? manually active the safety roller and pull trigger while holding the safety roller does it spark, if so the board is bad, but before replacing look for a loose connection by the trigger on the wires that push onto it. they sometimes come loose. Let me know if you need more assistance.
Posted on Feb 15, 2010
Testimonial: "I will give that a try--Thanks for the INFO..."
Paslode framing nailer fan runs battery charged new fuel .fires a few time than nothing charged batter again couple more shots than nothing?
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Mar 04, 2011 | RTO PasLode 900420 Impulse Framing Nailer
I have a paslode cordless framing nailer 900420, just changed the molded circuit board and worked fine, put it away for about 4 weeks when I went to use it again the fan will not come on and will not fire
heatman101
Jan 17, 2011 | RTO PasLode 900420 Impulse Framing Nailer
My paslode framing nailer will not recycle
Bad o-rings or bent firing pin...
heatman101
Jan 03, 2011 | RTO PasLode 900420 Impulse Framing Nailer
What is the proper way to oil a Paslode 900420?
There is no oiling necessary until the gun is fully serviced as instructed in the "cleaning manual." The cleaning manual at paslode.com has a schedule.
http://www.paslode.com/owners-manuals.html
Nov 28, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Model 3250-f16 Paslode I recv'd this nailer without a booklet. I would like to know how to use it. Can you help?
heatman101
Nov 03, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My paslode impulse framing nailer fires intermitantly. New batt & fuel cell.
heatman101
Oct 23, 2010 | Palmgren 91232 Full Head Framing Nailer
I have serviced my IMCT several times per the owners manual. It needs to be serviced again however the manual has disappeared, and the one available on line does not contain the servicing instructions. ...
heatman101
Oct 21, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My framing paslode misfires or no nails that comes out.
heatman101
Aug 28, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My Impulse Framing Nailer fan doesn't go on when i press down on the gun
heatman101
l;';[]
Apr 11, 2010 | RTO PasLode 900420 Impulse Framing Nailer
How to load nails in the paslode f350s framer purchased a used nailer now trying to figure out how to load the nails
Hi, I found you a free owners manual for your model. Click on the link below and save or print.
http://www.paslode.com/uploadedFiles/pneumatic_ops_manual.pd f
Hope this Helps, RSMITH972278 P.S. PLEASE RATE MY ASSISTANCE
Dec 29, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Air Tools & Compressors Logo
44 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
