Question about Line 6 Spider Valve MkII HD100 100 watt Guitar Amp Head
I need a schematic for a line 6 spider valve hd100 mkII
5 Suggested Answers
djlaplaya
  • 74 Answers
SOURCE: en los amplificadores line 6 spider iii
translation: In the amplifier Line 6 Spider 3, is it possible to connect effect pedals of other makes apart from Line 6.
Creo si, pero primo del amplificador con una corda guitarra.
I think that you can, just add them to the input
Posted on May 06, 2010
  • 5603 Answers
SOURCE: my line 6 spider iii30 30 watt amp works with
There is likely a switch contact on the headphone jack that routes the amp output to the speaker. These jacks on most music stuff are JUNK and the contact may not be closing.
If the spring contact is bent so it won't close you can bend it to contact BUT the springyness usually is gone and the contact will be marginal.
Posted on May 10, 2010
  • 5603 Answers
SOURCE: What causes your line 6 spider amp to turn on and ...
This MAY be due to overdriving the amp. The single chip amplifiers used in these have thermal protection usually and will cycle on and off if you drive it too hard. This is a tiny amp and is for use as practice and is NOT suitable for heavy use. Most of these use chips like the TDA 2050 and MANY of them have VERY substandard heatsinks and often don't even use thermal conductive grease under the chip.
If you want loud, then you need to step up the size of amp you are using to say a 100 Watt one that is designed to take the power.
Posted on May 21, 2010
KeithOB
  • 59 Answers
SOURCE: all the lights on my
Unfortuently for you i can already tell you that is going to be your digital board. notorious for going bad in these things. line 6 has a flat rate to repair them but wont release parts. sorry man i've been fighting that battle since these were released.
Posted on Sep 01, 2011
Need schematic for line 6 spider 4 30 watt l
If you read down almost to the bottom of this link, you'll find a working link to it.
Thread LIne 6 Spider IV 30 Schematic request
Mar 13, 2016 | Line 6 Line6 Spider IV 30
Schematic diagram
Line 6 does not supply schematics to end users.
Feb 04, 2014 | Line 6 Spider Iii 15 Modeling Guitar...
My line 6 spider mk 11 starts making a cracking noise about 50-60 seconds after i turn it on, then loud fuzz noise- whats wrong plz help
Disable ALL digital settings....problem gone? If not, with tube guards and/or shileds removed try lightly tapping on each tube (one at a time). Does your amp go crazy while tapping one particular tube? If yes then it is new tube time.
Oct 18, 2012 | Line 6 Spider Valve 112 MkII 40 watt 1x12...
User manual for line 6 112 75w
Hi TOny:
Sorry for the delay, You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Dec 31, 2011 | Line 6 Spider Valve 112 MKII Guitar Combo...
All the lights on my line 6 spider valve 112 are no longer working except for the power light. what would cause this and how can i fix it?
Aug 30, 2011 | Line 6 Bogner Spider Iii Valve Tube Combo...
2009 212 40 watt mk2 in shop mother board went out is this common and what would cause it
"Mother board went out" is a statement of a tech that is incapable of troubleshooting things to the component level. Most common things are broken pots and connectors. There is nothing common to cause a "motherboard to go out". You should find a tech capable of analyzing the problem that has proper test equipment and skill to repair the unit. There is likely a part with cost less than $2 that has failed. Common problems include: broken connectors, broken pots, circuit board cracks, Bad solder connections. Bad solder and bad jacks are most common with bad pots third in line. Bad electrolytic caps are next in line.
Jun 13, 2011 | Line 6 Spider Valve MkII 212 40 watt 2x12...
Line 6 Spider IV 30 I have the above amp and there seems to be a short when the guitar input jack makes contact with the chassis. There's a copper contact pad on the sub board that the jack is mounted...
Typical guitar input on a schematic for line 6 shows an inductor between the input jack sleeve connection and the "earth" or safety ground.
I do NOT understand how you could fry one of the voltage regulators via the guitar cable unless you have more than a guitar (other devices) connected to the jack.
ALWAYS power any interconnected audio equipment from the same receptacle or power source to avoid ground bounce/fault damage to equipment.
Jan 08, 2011 | Line 6 Line6 Spider IV 30
My line 6 doesnt turn on,its like no electricity is going through it? i would like to know what is the problem???
I can't find a schematic but there should be a circuit breaker or a fuse on the backside of the amp.
Nov 13, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
En los amplificadores Line 6 Spider III ¿puedo conectar pedales de efectos que no sean de la misma marca línea 6?
Jan 23, 2010 | Line 6 Spider Iii 30
Line 6 Spider Valve MkII HD100 100 watt Guitar Amp Head Logo
156 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Are you a Line 6 Music Expert? Answer questions, earn points and help others
