Question about Poulan Garden
Lehr propane weed eater how to start - Poulan Garden
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
  • 641 Answers
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Posted on Apr 13, 2009
  • 65 Answers
SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Posted on Aug 22, 2009
  • 53 Answers
SOURCE: weed eater bogs down
Under what conditions does it bog down? When it just idles? Cold or hot? When you give it gas? When you try to cut?
Posted on May 11, 2010
SOURCE: Tryingto replace my troy built weed eater's head
clean grass off between shaft and the top of the head. hold weed eater still and turn the head, looking between the shaft and the top of the head. There will be what looks like a hole. Place something there that will keep the shaft from turning, then twist the head off.
Posted on May 25, 2011
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    New 5 hp LEHR propane outboard motor requires 4 pulls to start. Not reliable at low revs, misses and stalls.
    You need to adjust the needle valve that controls the propane into the carb, Lehr website has videos about this, its real simple, you need to add more fuel than reset your idle speed, mine needed the same thing, these motors need adjustment at time of sale and many places do not do it.
    Aug 20, 2013 | Lehr Propane Powered Outboard Marine...
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    My weed eater starts but won't stay running. what
    Try a new spark plug.Thanks for asking and I hope it helps
    Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    Which trimmer starts the easiest and is built to last the longest? I'm considering the Honda 4-cycles and the Lehr propane models among others. Thanks...
    Be careful on the 4-strokes...the engines often last a long time, however, the weak point is still the carburetor, just as the two strokes were. The propane ones are a good choice, as they burn really clean, and your engine will run a long time due to the lack of contaminants in the oil. If you didn't go propane, then my suggestion would be a Stihl trimmer; there's a reason that most of the contractors and road crews use them; they will take a beating and last forever. Do yourself a favor, and search for problems for the kinds of trimmers that you're looking for on FixYa. You'll find that some brands are listed OFTEN, and some don't even have a category due to lack of need for one. If you're looking for more budget, believe it or not, MTD(troy bilt, bolens, etc) has a decent 32cc trimmer that's cheap with loads of power for its size. Hope this helped you a little. I won't give you specific models, as most of them are the same engines with small variations. I can tell you though, to stay away from the ones by Ryobi, Honda is a nightmare for repair, Homelite is a disposable machine, as well as weed eater and poulan.
    Jun 21, 2010 | Garden
    I have weed eater model FX26SC it starts and when I put it to run the weed eater doesn't spin but is running
    Either the clutch is worn out or the flexible drive shaft is broken. Either repair is likely to cost almost as much as a new unit.
    May 16, 2010 | Garden
    WEED EATER STRING
    you have the string in backwards, or the gear is not ingauged.
    Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    My te 475 weed eater wont start
    Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
    May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    Garden Logo
    23 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
