Question about GE 25GT240 25" TV
GE TV model 25gt239
My mother gave me this tv and I am trying to connect it to my comcast cable connection. But it appears that this model tv may not accept channels higher than 99 channels. Even with auto chan scan/set-up and spaces for three channel digits, the tv will not accept chan 100 and above. My mother did not have the owners manual so maybe the tv (a 1999 manufacture) is not capable of more than 99 channels. Can you help?
  • natina Sep 10, 2007
    Thanks for the update. I will see what I can find out about this possible tuner problem.
  • Faznichie Nov 25, 2007
    I have an older TV with the original remote but still can not get the channels above 99. We have com cast. Please tell me how to get the upper channels. Thank you
    Novelist:
    Champion:
  • 236 Answers
I think your TV is made by RCA and it should go to cable channel 125. If Comcast has any channels above 100, you should be able to get them. RCA TV's have a problem with the solder connections inside the tuner. This may be your problem. If this is the case the tuner would have to be taken apart and re soldered. Stargazer
Posted on Sep 09, 2007
SOURCE:
I have an old tv with comcast cable. I want to switch to a smart tv that has only been used with netflix. how do i connect smart tv to my comcast cable
Adding a smart tv just requires adding an ethernet cable to your internet connection to the ethernet port on the set. The smart services on the set us a broadband internet connection to work.
Jun 18, 2016 | Vizio 42 in. LCD TV
Brought a GE model 27gt722 tv...can not pick up all channels on cable. Usually once you hook up cable wire to tv cable is automatically on ..at least that is how it was on old tv
Depending on the cable company, some like Comcast have gone mostly digital meaning when you connect the TV directly to cable without a cabe box you will only get around 35 channels. The only way to get around that is to get a cable box. If you have Comcast service already they offer what they call a DTV cable adaptor which will allow you to get most cable channels. These DTV adaptors in most areas are free for the first two per household. I hope that helps : )
Jul 25, 2011 | GE 27GT722 27" TV
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
Panasonic 42" connected to comcast dvr, and dvd player
To solve need more info if this is still a problem.
Is your comcast dvr connected directly to the tv, and also the DVD connected directly to the TV?
If so then you will need to change the input selection on your tv remote to determine which inputs these devices are connected to.
If you are connected differently, please post how your devices are connected.
Dale
May 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Nov 11, 2008 | GE Televison & Video
GE TV model 25gt239
i have one , to watch DVD or VHS by the audio Video Compenent, from your remote control pess ( 00 ) 2x zero, thanx.
Nov 25, 2007 | Televison & Video
When connected to cable - sometimes snow on channels 14-21.
The RF Connector could be loose either because of bad solder connection or just that part of the tuner could be going bad in the TV. One fix or repair is too use a cable box to eliminate the tuner issue or borrow one for test, and or buy a inexpensive vcr and hook it to cable first then take the output out of vcr and run to tv tuner input. Or better yet, use Yellow ,Red, White cables (Composite video) and run it into respective inputs on TV if it has those inputs. Let me know if this solves your problem or at least gets you close. Thank you. And talk to you soon....Jay
Nov 06, 2007 | TruTech PVS2119 19 in. LCD Television
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
GE model 27GT722
Sorry, the board is not available as a replacement. That connector can be replaced by a skilled tech.
Aug 19, 2006 | GE 27GT722 27" TV
GE 25GT240 25" TV Logo
345 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
