How do you remove the back freezer panel on an lg lfx31925st
first you have to take out your freezer bin and remove the door from the tracks. after that you have to remove the ice maker(should be two to three screws) then remove the rails for the door(do that by loosing a small clip on the clip to the rear and pulling on the rail). then remove the plastic pieces that the rails slide into and set them aside, should be like 3-4 screws per piece, there may be a screw in the middle of the back panel, remove it, then it pulls out from the top. it has tabs so you'll have to pull it out. remember from the top not the bottom. then there will be a couple plugs that are attached to the panel, unplug and there ya go! may i ask whats wrong before you venture into such a feat? its not an easy job for a homeowner, may be able to help fix it without removing the panel.
