Question about Boating
2008 Yamaha sx 230
Kill switches located in compartment where clean out plugs are located. I have one that the nut is cracked and lets it be to low to make contact. What size and thread nut will be needed to replace it.
galaxian
  • 14 Answers
SOURCE: Need to replace the amp jack nut, Epiphone Dot
Just take the guitar with you to a local guitar music store, where you'll have to go anyhow to get the part, and the store will be happy to repair it for
the price of the part.
Posted on Dec 13, 2008
SOURCE: broken/stripped rear lugs on pacifica that needs to be replaced
From Experience trying to clean the threads up usually results in just stripping the stud the rest of the way. Depending on how the car is set up (i.e. rear disc or rear drum brakes) replaceing the lug studs is fairly straight forward. All you need to do is remove the tire, remove either the brake drum or disc, and determine if you have room for removal and reinsertion of a new stud. If not determine what has to be removed to give you that room. Then comes the fun part. Take about a 2-3lb. hammer and knock the old one out. Yes, they just knock out. Then to instal the new one just set it in the hub where the old one came out, place a few washers that will fit over the knurled part at the base on the stud and the new lug nut and tighten it down til the back side if flat against the hub. Then just reinstall previously removed parts and you are done.
Posted on Apr 01, 2009
SOURCE: 2008 dodge avenger spark plug location and socket size.
  • 2008+ Dodge Avenger 2.4L 4cyl.
  • Remove plastic cover on top of engine, just pull on each corner for it is friction fit.
  • Once removed you will see 4 black spark plug covers with one hex type screw holding each.
  • Remove Hex screw and place aside, pull upward to remove plug boot from plug.
  • To remove the plug, use a 5/8 socket with a 6" extension. Once plug has been turned out all the way and you cannot get the plug up and out of the hole, just press the plug boot back on the plug and pull it back up.
  • Gap and replace 4 plugs with the same or equavalent type,. Drop plug down the hole and use socket to align and tighten until just snug, then torque to manufactures specifications.
Posted on Feb 23, 2010
  • 5 Answers
SOURCE: I am looking for a wiring diagram for the ignition
Posted on Jul 31, 2010
  • 15 Answers
SOURCE: I replaced ignition coil on a Tecumseh Toro 20018
It is a short in the kill switch, or the wire running to the kill switch. check insulation on the wire running to the kill switch and check the routing of the wire to insure that it is not being rubbed by moving parts, or the insulation melted by hot engine parts such as the exhaust system. Finally check that the kill switch itself is functioning properly with a test light or OHM Meter.
Posted on Aug 12, 2010
How do I bleed a clutch line for a 1983 Yamaha
crack the bleeder nut at the wheel, put fingertip over loosened tip, have master cylinder full, gently squeeze lever, while letting air and fluid drain from bleed nut. Do this until all air is removed from brake cylinder, and dont let master cylinder get to low during this process. hold down lever, tighten bleed nut, then refill clutch cylinder to its full line,,,,,,,done!
Sep 02, 2014 | Motorcycles
My TTR 230 runs at idle but right off idle runs rough and shuts off If I hold starter button down revs fine what's up with that
Hi, Anonymous and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
230 will not run without choke rough idle please help TTR
Dirt Rider Magazine
http://www.manualesdemecanica.com/images/files/discussion/644/6831c10187c2269620ce242953e4cbbe.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-tt-owners-manuals
May 27, 2014 | 2006 Yamaha TT-R 230
Ttr 230 does not start cold
Hi, Johanvn and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
How to fix my TTR 230 TTR
2006 Yamaha TT R230 cold start issues
Yamaha ttr230 Service Manual
Dec 11, 2012 | 2008 Yamaha TTR230
Need float height spec for 2005 ttr 230
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ttr 230 help with carb TTR
2004 YAMAHA TTR 225 CARBURETOR FLOAT REPLACEMENT
Yamaha TT R230 Owner Manual
Oct 12, 2012 | 2008 Yamaha TTR230
Yamaha PW50 stalls when throttle applied
Hi, Rick and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
pw50 bogging down
PW50 won rev lots of things tried
https://books.google.com/books?id=ozV8-Aer4N8C&pg=PA84&dq=pw50+manual&hl=en&ei=TCS2TcbdJ4PW0QG0z9jmDw&sa=X&oi=book_result&ct=result&resnum=1&ved=0CGUQ6AEwAA#v=onepage&q=pw50%20manual&f=false
Yamaha PW50 Owner Manual
May 27, 2017 | 2005 Yamaha PW 50
WHERE IS THE BATTERY COMPARTMENT LOCATED ON A 2008 HONDA CRF 230
I am not 100% sure. But I can't think of any other place that it would be. I would say under the seat. That is where it is in every other motorcycle.
Oct 29, 2010 | 2003 Honda CRF 230 F
I have a 2006 Yamaha TT-R 230. It was recently
.hAVE YOU TRYED TAKING THE CARB OF DRAINING IT CLEANING IT AND DRYING IT. CHANGE THE SPARK PLUG JUST IN CASE YOU HAVE GOT WATER INTO THE HEAD START IT UP AND LET IT JUST TICK OVER FOR 20 MINS. JUST AN IDEA STUFF TO ILLIMNATE. GOOD LUCK BUDDY
Mar 14, 2010 | 2002 Yamaha TT-R 225
2008 yamaha r1 keeps shutting off on me. i
I HAVE A YZF R1 2008 IT KEEP CUTTING OUT AND CODE 46 COMES UP ON THE DASH WHAT IS THIS CODE
Jul 04, 2009 | 2008 Yamaha YZF-R1
LOSE OF SPARK
Pull the plug back out of the cylinder and ground it against one of the head bolts, kick the engine over to see if you are getting a spark.
Nov 12, 2008 | 2008 KTM 105 XC
Boating Logo
22 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
