Question about Kyocera FSC2126MFP AllInOne Laser Printer
Close rear cover 1 keeps on showing everything all closed correctly turned printer on and off any Help or suggestions
3 Suggested Answers
acdr
  • 1913 Answers
SOURCE: I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Posted on Mar 21, 2009
SOURCE: kyocera fs3900dn close top cover printer startup sequence halts
Hi
Open the top cover and remove the Cartridge -
With Air Blower - Blow air inside the printer for 2 min
Insert the Cartridge and turn the printer on
Check your Printer now
Regards
Posted on Oct 03, 2012
Kyocera FS-C5100DN shows Error message "close front cover" what to do??
it is in the left front of the machine the cover you open to change toner should have a actuator that pushes the switch that could be broken off or 1 of your toner cartidges may not be set correctly remove all of them and close the cover if it says install toners do that 1 at a time see if it keeps saying install cartriges until all are installed or you see close cover message after 1 is installed that would be the 1 not installed correctly causing your close cover message
Mar 29, 2017 | Kyocera FS-C5100DN Color Laser Printer 23...
Its showing "close ink cover"
Hi there!
The message "Close Ink Cover" means that the cartridge door is not closed securely.
-please open the ink cartridge cover and make sure all cartridges are installed correctly and then close the cartridge cover. That should clear the message on the screen.
Hope this helps!
May 08, 2011 | Brother DCP 165C Compact Color Inkjet...
Close front cover
Unlikely the power supply. Sadly I can't think what causes that. I havent workrd on Toshiba for a couple of years now, but there is something else that causes that. Totally unrelated to the power supply or the switch. Have them call Toshiba support .
I am sorry I can't off hand remember the problem. But it is unlikely the power supply.
Jul 23, 2010 | Toshiba E-STUDIO 850 Copier
Paper Jam 13.20 on HP 4015
13.20 PAPER JAM CHECK REAR DOOR
Media stopped in the paper path during power on or when the top door was closed.
Action:
1. Open top cover and remove toner cartridge. Remove all media in the paper path, and then re-install toner then open and close the top cover.
2. Open read door and pinch blue latches on fuser and pull it out. Inspect the sensor flag for correct movement and any paper obstructions in the fuser rollers. Re-install fuser and Confirm rear door closure.
3. Remove tray 2 and confirm paper is not jammed in the pickup area. Confirm paper size adjusters in the tray are correctly set for paper being used. (Do not set back paper stop to ANY)
4. Replace any defective sensors or flags
Hope this helps. Please keep us updated and remember to rate this answer.
TF
May 24, 2010 | HP LaserJet P4015N Printer
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Error: "Back cover is open. Close back cover."
We had this problem. It turned out there was actually a piece of paper stuck in the printer! It wasn't so easy to see it from the rear.
We removed the paper from the front by taking out the ink cartridge first. Turned the printer back on and everything was fine.
Mar 26, 2009 | Brother MFC 7420 All-In-One Laser Printer
MP600 - Says inside cover is open - but it's not!
This is a hardware problem nothing to do with software; somewhere inside the printer a cover is not closed correctly.
Jan 24, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Installing new cartridges and showing empty
Is this a genuine Brother cartridge or a compatible/refilled cartridge? Inside, at the rear of the cartridge there is flag which when full blocks a sensor in the machine indicating the cartridge is full - with some compatible and refilled cartridges the flag may not be set correctly so the sensor sees that there is no ink in the cartridge. As a temporary fix place some black tape over the rear of the cartridge where the sensor arm is.
Sep 09, 2007 | Brother Multi-Function Center MFC-240C...
Kyocera FSC2126MFP AllInOne Laser Printer Logo
29 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
