Question about Antamedia Internet Caffe
Socket error 10061 - Antamedia Internet Caffe
How to solve error code 404 and system error code 10061
The firewall is blocking the connection.
Check and correct the firewall settings.
Apr 05, 2016 | Computers & Internet
How to solve the mysql error 2003 Can't Connect to mysql server on 'localhost' (10061)
Your client software attempts to connect to a MySQL database instance on your local computer. There is no DB server running locally, hence the error.
Before reinstalling Windows, did you connect to a remote DB server or did you use a local instance?
In former case, you need to configure the DB connection to point to the remote serve. In the latter case, on top of Windows you also need to reinstall the MySQL DB server software locally, and it needs to be started.
Feb 27, 2013 | Sun MySQL
Unable to send e-mail through OE 6 installed. Getting error message as below: An unknown error has occurred. Account: 'HOME', Server: 'smtp.bsnl.in', Protocol: SMTP, Server Response: '421 Cannot...
You probaly have the SSL box checked in your SMTP settings.
Open Outlook Express.
Click on Tools in the menu, and click on Accounts in the drop-down menu.
Click on Mail.
Double-click mail account.
Click on Advanced.
Outgoing mail (SMTP) should be 25
Box on the left of This server requires secure connection (SSL) should be clear. If not, click on it to clear the check.
Clikc OK button and you should now be able to send emails.
Dec 17, 2010 | Computers & Internet
Can not send email
The connection to the server has failed. Account: '192.168.0.1', Server: 'mail.abc.com', Protocol: SMTP, Port: 25, Secure(SSL): No, Socket Error: 10061, Error Number: 0x800CCC0E
May 25, 2010 | Microsoft Outlook Express
Reds come out yellow, and facial tones are too red
It sounds like your machine needs to be calibrated. First try turning the machine off and unplug it for about 15 seconds. When you turn it back on it will reboot its software and stabilize the image units. If this does not correct the problem you can perform a gradation adjustment by:
1 Load 11 × 17 L-size paper into the 1st drawer.
❍ Letter C, A3 L or A4 C can be loaded instead.
2 Press the [Utility] key.
3 Touch [Admin. Mode].
4 Using the keypad, type in the administrator code.
❍ Touch [Enter].
5 Touch [Gradation Adjustment].
The Gradation Adjustment screen appears.
6 Press the [Start] key.
A test pattern is printed.
7 After the test pattern is printed, a screen appears, indicating how
the test pattern must be loaded.
8 Place the printed test pattern on the original glass.
❍ Align the edges of the printed test pattern with the document scales.
9 Place into the 1st drawer 10 more sheets of blank paper of the same size as the printed test pattern page.
10 Close the original cover, or the reverse automatic document feeder if it is installed.
11 Press the [Start] key. The printed test pattern is scanned.
12 Based on the scanned image, the gradation levels are automatically adjusted.
After the gradation levels are adjusted, the Admin. Mode screen appears again.
13 Repeat steps 5 through 12 three times.
14 Touch [Exit], and then touch [Exit] in the Utility screen.
May 11, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
My wife's email [ downloading and sending] has failed and the problem is 'socket error 10061 error number 0x800cccoe What can be done Thank you
Hi please see this link. If you can add more information it would help to be able to guide you through the process.
- Are you using Outlook Express or Outlook, and standalone, or attached to an exchange server.
http://support.microsoft.com/kb/191687
Sometimes when you add a new email account the default ports are not those that you need. If it is e.g. a Gmail account that you want to use with Outlook etc, follow their instructions to make sure you set up the correct ports.
Feb 11, 2010 | Microsoft Outlook Express
I have a Danby Mod.# DPAC 10061 portable A\C, the
This sounds like it could be a power supply problem. It may be very simple. I think I would first just unplug the unit, open it up, look for the PS connectors, and check/wiggle them to make sure there is good contact.
I went to the Danby's website:
https://www.danby.com/
And I was unable to find any service or owner's manuals in PDF format. The site does however have a locator for service shops. Good Luck!
da Marty
Dec 31, 2009 | Danby DPAC10061 Air Conditioner
The connection to the server has failed. Account: 'mail.insightbb.com', Server: 'mail.insightbb.com', Protocol: POP3, Port: 110, Secure(SSL): No, Socket Error: 10061, Error Number: 0x800CCC0E
You can also receive this error message when you have antivirus e-mail protection or personal firewall software enabled on your computer.
Try disabling the antivirus program through msconfig or close the antivirus program and see if you get the same error again, if not then disable email scanning and this will help you.
Sep 23, 2009 | Compaq AMD Athlon 64 200GB Desktop...
I have yahoo mail plus & I like to use incredimail with it. The incredimail program stop sending & receiving. I get an error msg 10061 port 465 & port 995 not configured. I've tried everything. Please...
I would use YPOPs and download my email through a third-party client like Windows Live Mail, Thunderbird or Outlook. The link for YPOPs can be found here.
Anything else, please let me know.
Mar 20, 2009 | Yahoo Mail
Connection to server failed account ntlworld server pop.ntlworld.com protocol pop3 port 110 secure (ssl) no socket error 10061 error 0x800CCCOE. This message appears when I use my laptop which uses vista...
Verify the setting via Manage accounts on your XP machine (the one the email client works on) in whatever email client you use on it and verify and edit if need be the setting in your Windows Live Mail on your Vista home Laptop.
Jul 15, 2008 | Computers & Internet
Computers & Internet Logo
Top Antamedia Computers & Internet Experts
David Payne
David Payne
Are you an Antamedia Computer and Internet Expert? Answer questions, earn points and help others
