Question about Philips SoundBar DVD Home Theater with Ambisound
Sandstorm sound bar stanby on ok when sswitching to source click then retuns to stanby
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Philips Master
  • 924 Answers
You most likely have a problem known as DC Offset, meaning you have a damaged amplifier. For further assistance, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 28, 2013
Why won't my tv connect to anything? Had no picture or sound, it says No Sync. Signal.
Assuming the television is OK and you have selected the correct 'SOURCE' then check you aerial connection and retune the set. If this does not work, take the set to a friends house and try in a 'known good' location. Download the user manual and use Dr Google for hints and tips to FAQ's. Cheers
Dec 14, 2016 | Televison & Video
I hooked up my soundbar using the HDMI out (TV) port from bar to HDMI in port on my Philips TV power is on bar however I can't get any sound out of bar. But just audio cables worked what to do?
OK, If its the Samsung Sound Bar, this item should have 2 HDMI input, 1 3.5mm audio jack input and a digital audio input (fiber optic). Since there are various input, the remote control should have a source button, or it will probably read O/A Input, this is to change thru the inputs from the sound bar. If you connected your TV HDMI output to HDMI 1 from the Sound Bar, then press the source button to reach HDMI 1, maybe it will be display with a different name, like sound 1, or DIGI.1 Give it a shot and let me know in the comment section. Good luck.
Dec 19, 2015 | Samsung HW-H450 2.1 Channel 290 Watt...
Sound does not work on TV
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 17, 2014 | Televison & Video
I just bought a 32bv701b. When doing auto scan no digital channels appear. My previous TV received them all fine. Help!
Do a retune to this TV.
Press MENU button on the remote control and select
Install and Retune by using Left or Right button.
Press OK button and the following menu screen
will be displayed
Select Automatic Channel Scan (Retune) by using
Up or Down button and press OK button. Automatic
Channel Scan options will be displayed. You can select
options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation
Digital: Searches and stores aerial DVB stations.
Analogue: Searches and stores analogue stations.
Full: Searches and stores both analogue and aerial
DVB stations.
Whenever you select an automatic search type and
press OK button, a confi rmation screen will appear
on the screen. To start installation process, select
Yes, to cancel select No by using Left or Right
and OK button.
After auto channel scan type is set and selected
and confi rmed, installation process will start and
progress bar will move along. Press MENU button
to cancel process. In such a case, located channels
are not stored. The television will start to search for
all available stations. You must allow the television
to complete the search.
Jun 13, 2012 | Panasonic Televison & Video
My denon receiver avr-4802, has a clicking sound when i always turn it on
Hello
you haven't specified about its working. Whether it works properly after the clicking or not. It is normal to all Hi-Power amps, there will be a click sound, catching speaker output relay. If the amp works properly, the click sound can neglected. But if amp cuts off after the click sound, there is something fault. It can be inside the amp or outside to connections to speaker. If it cliks and shuts off/stanby, protection circuit inside it has the fault and should be rectified. To look into that section, one must have through knoledge in electonics, and have experience in trouble shooting, because it is the most complicated circuit part of that system. Ok.
Apr 12, 2011 | Denon Audio Players & Recorders
I bought a TOSHIBA 32KV500B tv. At the Initial Installation mistakenly I selected "yes" for 'do you want to search analogue channels?' guestion. And then I lost all my automatically selected...
I had this problem and searched the internet for hours looking for an answer and was given the initial same reply as this and it does not work. To solve this problem all you simply need to do is press source button on the controller followed by pressing the DTV/USB option. All your digital channels will come back to you and you will find the menu setup options you are looking for!!!
Feb 12, 2011 | Toshiba Televison & Video
I have a Daewoo DSL22V1WCD combined tv/dvd with built in freeview, our area is in the grasp of the digital switchover - everything I look at says I need to retune the tv - but this tv has various "sources"...
Press the DTV menu button (<<)
Press the Down arrow until you reach Settings
Press OK
Press the Down arrow until you reach Installation
Press OK
Press the Down arrow until you reach First Time Installation
Press OK
Aug 04, 2010 | Daewoo Televison & Video
When turned on only standby light appears
Try another video source such as a DVD player.Check that settings are set to receive your signal source
Oct 07, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Retuned my Freeview receiver but now have black bars.
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Sony BRAVIA KDL-40V4000E 40 in. LCD TV
Red stanby light is flashing with sound but no picture 1996 sony projection screen.I also here a clicking noise sometimes.
I will forward a link to a page where you can get more information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Jun 16, 2009 | Sony KP-61V75 61" Rear Projection...
Philips SoundBar DVD Home Theater with Ambisound Logo
118 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
