Question about Sizzix SideKick Machine
My dies are getting stuck halfway through my sizzix sidekick. Some are working but most won't go through. They are the sizzix sizzlits and not another brand! I've tried different papers etc. Any help would be appreciated! Thank you
My sizzix eclips won't turn on
Sizzix Eclips help please - Make The Cut! Forum
forum.make-the-cut.com/discussion/25227/sizzix-eclips-help-please
Jun 10, 2012 - 9 posts - ‎6 authors
I did email Sizzix but they won't answer until during regular business ... If you turnedoff the cutter, then start again, it should work properly. Turning off the grid lines and plus signs on the mat.
Nov 18, 2013
htv question
Sep 16, 2012
Plug In for the Sizzix Eclips, please!
Oct 8, 2011
roland blades
Jun 10, 2011
More results from forum.make-the-cut.com
[PDF]Help - Sure Cuts A Lot
Nov 14, 2015 | Saws
Machine jammed
you must contact to the supplier manufacturer in order to get support via ONLINE chat.
GOD BLESS YOU
Nov 06, 2013 | Ellison Sizzix Tim Holtz Inspired Vagabond...
Repair sizzix eclips
My sizzex eclips won't turn on, help
Oct 23, 2012 | Sizzix EClips - Electronic Shape Cutting...
I have some dies that are thinner than others. How do I get them to work in my Sizzix machine
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 11, 2012 | Cars & Trucks
On my 2001 kia sportage the back two windows won't go down and the right front window is stuck halfway up
make sure power windows lock out switch on driver side not on position, that will cause power windows not work or you have faulty power window relay.
Sep 11, 2012 | 2001 Ford Explorer Sport Trac
Cannot use die cuts
No I don't think your machine is defective. Here are some "sandwich" ideas to help you. I know you asked just for Cuttlebug dies; I included other "sandwiches" that you can do with your Cuttlebug. If you need further assistance feel free to contact me.
Cardstock
Chipboard
Magnetic/ Metal Sheets & Thin cork (Media)
Cuttlebug Dies
Plate “A”, Plate “B”, Die (cutting side up), Cardstock, Plate “B”
Plate “A”, Plate “B”, Die (cutting side up), Chipboard, Plate “B”
Plate “A”, Plate “B”, die (cutting side up), Media, Plate “B”
Cuttlebug Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”
Plate “A”, Plate “B”, Folder (with chipboard inside), Plate “B”
Plate “A”, Plate “B”, Folder (with metal sheet inside), Plate “B”
Nestabilities
You will need Spellbinders Tan Embossing Mat to emboss in
Cuttlebug™ machine (or a plumbers gasket cut to size, or some use a mouse pad)
Cutting Sandwich - (Stack from bottom up)
1. A plate
2. C plate
3. Spellbinders Die (cutting side up) that means the side with the
ridges
4. paper or cardstock
5. B plate
6. Run through Cuttlebug™ machine.
Embossing Sandwich- (Stack from bottom up)
*Remove C Plate for embossing sandwich
1. Place A plate on bottom
2. Leave die face up on A plate with die cut still in the die.
3. Place one Spellbinders Tan Embossing Mat on top of the die.
4. Use 2 or 3 pieces of cardstock to shim.
*Cautionary Note: Using more than 3 pieces of cardstock to
shim Cuttlebug Embossing sandwich will result in B Plate
breakage. When using Spellbinders Edgeabilities card making
dies, shim with only 2 pieces of card stock.
5. Place two acrylic B plates on top of sandwich and run thru
Cuttlebug machine to emboss Spellbinders die cuts.
6. Turn die over and use like a stencil with inks and chalks for
added detail.
BigShot Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”, Cardstock shim
BigShot Large Dies
Plate “B”, Cardstock, Die (cutting side down), Plate “B”
Revolution Dies
Plate “A”, Plate “C”, Die, Cardstock, Plate “B”
Sizzlit Dies
Note: Provocraft suggests using Plate” C” instead of the second Plate “B”, however, CB owners have cracked plates, so try with two “B” plates first.
Sizzix Original Dies & other Steel Rule Dies
Plate “B”, Chipboard, Die (cutting side down), Plate “B”
Sizzix CutNFold Dies
Plate “A”, Die, Cardstock, Plate “B”, Chipboard shim
Also try:
Plate “B”, Cardstock, Die, Chipboard shim (maybe 6 layers)
Sizzix Embossing Folders aka Simple Impressions
Also try:
Plate “A”, Chipboard shims, Folder (with cardstock inside), Plate “B”
QuicKuts Dies (Regular)
Plate “A”, Plate “B”, Die, Cardstock, Plate “C”
Plate “A”, Plate “C”, Die (cutting side up), Chipboard, Cardstock shim, Plate “B”
QuicKuts Dies (Grand)
Brass Embossing Stencils
Plate “A”, Plate “B”, , Brass stencil ,paper/cardstock,mouse pad (cut to size, rubber side down), Plate “B”
Sandwich may need to pass through several times based on cardstock thickness
Or use plumber’s black rubber plus red rubber gasket, instead of mouse, then add last plate B.
Big Impressions Texture Plates
Plate “A”, BI texture Plate, Cardstock, Silicone Rubber pad (from BISK), Impressions Pad (from BISK)
*BISK-Big Impressions Starter Kit
Fiskars Texture Plates
Plate “A”, Fiskars texture Plate, Cardstock, tan Wizard pad, black or tan Wizard pad, (possible Cardstock shim,) Plate “B”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (lightly misted with water), 2 layers Fun Foam, Chipboard Shim, Plate “C”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (right side towards TP), Rubber Plate (made from Plumber’s rubber gasket), Plate “C”
Plastic thin stencils
Here too- may try
Plate “A”, Plate “B”, , plastic stencil, cardstock, black rubber, red rubber, plate B
Jan 28, 2010 | Provo Craft Cricut Disney Font Cartridge
Manual?
About halfway down there is a link for the manuals
http://shop.sidekickskin.net/Sidekick-Related-sites
if that doesn't work then try this one
https://help.sidekick.dngr.com/en-us/
Dec 23, 2007 | T-Mobile Sidekick II
Cingular Sims Cards works in Tmobile Sidekick?
No Only Cingular Sims Work In Cingular Phones.
Sizzix SideKick Machine Logo
405 people viewed this question
Top Sizzix Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Sizzix Craft and Hobby Expert? Answer questions, earn points and help others
