Question about Lands Phones
Panasonic kxtga401c speaker not working - Lands Phones
MY PANASONIC sa ak122 -responding only from big side speaker not responding from other two small speaker how it can sound help me
Set your speakers
If playing stereo music through 5.1 system, only 2 front speakers will work. 5.1 = 2 front 2 back, 1 monitor speaker. Okay with your settings.
Oct 12, 2015 | Panasonic Audio Players & Recorders
Why only one speaker works in my Panasonic music system
Either the speaker is bad or the source for audio going to it is dead.
Aug 29, 2012 | Audio Players & Recorders
Only one speaker works in my panasonic music system
Either that speaker is bad, or the channel connected to it has failed--audio output to each speaker is separate.
Aug 29, 2012 | Televison & Video
Panasonic Wireless Rear Speakers Ticking
move ur speakers around. if the noise is absent on some places u can be sure its the digital box. or one fix that might work is - get aluminium foils and wrap ur speakers. this can blank out interferences. if that works, open ur speakers and line the walls with thick aluminium foils. hope this helps.
Apr 13, 2010 | Panasonic Home Theater System System
Panasonic rx-dt610 the speaker port at the back
A port is only an opening into the speaker enclosure. If "it is not working" it is obstructed, something blocking it.
Apr 11, 2010 | Audio Players & Recorders
Change speakers on Panasonic SC-HT995W
absolutely ,but remember that theese home theater combo,s are sonically matched so you should find speakers that are rated to the same power handling and frequency response of the one,s you are replacing, if the frequency response is close to what you had that will work fine , if you were to use speakers that were rated for higher output your amplifier will not be able to push the sound of the higher rated speakers and you would not be getting the optimal listening experience , thanks and i hope i helped you ,sincerely Glenn
Mar 02, 2009 | Panasonic SC-HT900 System
Speaker
I'm not sure which speaker is not working so the parts are listed below:
Part number: RAS8P23-B Cost: $13.13
RAS8P24-B Cost: $13.22
Either one can be purchased from tritronicsinc.com or any other Panasonic parts distributor.
Dan
Sep 25, 2008 | Panasonic RX-ES20 Cassette/CD Boombox
Panasonic wireless speakers
did you play with the settings on the remote? turn the pro logic on.
Aug 08, 2008 | Panasonic SC-PT960 Theater System with...
No sound, subwoofer or speakers
Er so you plug the speakers into anther system and they work? Blindingly obvious but there is no fault with the speakers.
Oct 06, 2007 | Panasonic SC-HT730 System
My panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Jan 20, 2007 | Panasonic DMR-E50 DVD Recorder
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
