Question about LG LP1200DXR Portable Air Conditioner
Full water - LG LP1200DXR Portable Air Conditioner
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
Cme256 scotsman
Is it dumping water or is it pouring water back into the ice bin? if it is pouring water back into ice bin than check your water float to make sure it is not calling for water also make sure the water valve is not letting water seep buy you can cut power to machine and if you here water still entering sump tray then replace water valve. if not then turn machine back on check and see it the water full light is on if so and water is still entering sump tray then replace float switch. If water full light is not on and the sump tray is full of water than remove the water sensor and clean or replace it.
Jul 10, 2013 | Kitchen Appliances - Others
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
DeLonghi (W160B) Portable Air Conditioner "No Water" symbol is still on despite the water tank being full
Tank hols 14 litres water where you fill there is a indicator if that is clear the tank is not full has to be red to be full. The water fill symbol will then go out.
Dec 23, 2012 | Heating & Cooling
How do I fill and turn on my rheem 82v52-2
82V52-2 is typical 240Volt 50-gallon electric water heater.
Water heater has to be full of water before turning on power.
This is true for gas and electric water heater.
Once water pipes are connected, you are ready to fill tank.
Turn on cold water shut-off so water enters tank.
Open bathtub spigot on hot side.
When tank is full, water comes out of tub spout full stream.
Let the water run until there is no more air coming out.
Next, open TP lever on water heater for a moment, and this will bleed out last pocket of air.
TP valve is located on upper part of tank, on the side or on top. It is a brass valve with silver-colored lever. Lift lever for a moment and water will exit tank down the overflow tube.
Water heater is full.
Turn on 240Volt circuit breaker going to water heater.
Other links with electric water heater information:
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#cleanelectric
http://waterheatertimer.org/How-it-works.html
Aug 04, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
How do I fill water heater
Once the hot and cold pipes are connected to water heater, then open bathtub spout on hot side, turn water on so tank begins to fill.
After tub spout is running full stream without air, then water heater is full and it is safe to turn on the heater.
Turning on gas water heater before tank is full can damage tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Turning on electric heater before tank is full will burn out elements. Replace elements.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Keurig B60. Brand New used maybe 4 Kcups. Now it won't fill a full cup setting. Maybe 1/4 cup. You reset, get a little more to run through. At this rate going to be a long time for a full cup. took...
if water does go thru it...try white vinagar/water mixture about 1/2 cup vinagar to full tank water..
run cycles until empty...NO Kcups..then run full tank of clean water.....
Dec 18, 2010 | Keurig B60 Coffee Maker
Pasta boat manual
MicrowavePasta Boat InstructionsFor elbow, bowtie, ziti, rotini, and penne
1 serving -1/2cup -water levelat #1
2 servings -1 cup -water level at #1
3 servings - 1 1/2cups - water level 2
4 servings - 2 cups - water level at 4
6 servings - 3 cups - water level at 6
8 servings - 4 cups - water level at 8
cook times based on serving ( serving - minutes)
1 - 17
2 - 18
3 - 21
4 - 23
6 - 25
8 - 27
Stir macaroni once halfway through cooking for al dente; for softer pasta, cookseveral minutes longer.
For spaghetti, linguine, angel hair andfettuccini
1 serving - 1/2 the handle - water level 1
2 servings- 1 full handle - water level 2
3 servings- 1 1/2 handles - water level 3
4 servings- 2 full handles - water level 4
6 servings- 3 full handles - water level 6
8 servings- 4 full handles - water level 8
Cook Time: servings/minutes
spaghetti - 1/13-14, 2/15-16, 3/16-18, 4/18-20, 6/20-22, 8/22
thin pasta-1/12-13, 2/13-14, 3/15-16, 4/17-18, 6/19-20, 8/21
angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17)
Nov 30, 2010 | Microwave Ovens
LG LP1200DXR Portable Air Conditioner Logo
41 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
