Question about Poulan Pro " Pro" Self Propelled Mower
Adjusting the carb - Poulan Pro " Pro" Self Propelled Mower
4carberator adjustnent for 83seco 650
Carbs are mostly "locked up", no adjustments other than idle, and for "syncing". To adjust idle there a screw up on the linkage where the cable attaches, and a bellcrank that moves all 4 carbs together, it's up and forward of the carbs on the top, just under your fuel tank. It's a little hard but not impossible to adjust with the tank on.
The only other adjustments are idle air fuel on some models, a brass colored screw on the side of each carb. These should all be 1 1/2 turns, adjusting them any where else isn't gonna change much.
"syncing" the carbs involves being sure the slides inside are all the same height, this doesn't change much. It requires eithe a nanometer or vacuum gauge made for bikes, or the carbs coming off and physically measuring each slide and adjusting them.
Jul 26, 2014 | Motorcycles
Echo pb250 blower how to adjust carb.
the new carburators do have adjustments but consumer is not allowed to adjust do to epa regulations find an echo dealer or echo repair tech with tools to do job everyones answer is carb clean carb clean damages diaphrams and seals in carb never use carb clean on lawn and garden equipment.
Jan 07, 2014 | Echo Gas Blower 135 MPH390 CFM Blower...
When syncing the carbs on a 1991 Honda CBR 600 F2 there are only three adjusting screws to adjust them but there are four carbs on the bike. So how am I to sync the carbs with only three screws?
There are only three adjusting screws because you are adjusting them to the fourth, if you could adjust all four the possibilities would be infinite.
Dec 17, 2012 | Motorcycles
Put new carbs on. Having trouble tuning air/petrol mix and syncronising the carbs.
need vacuum gauge, take one carb and adjust till highest vac setting. then match next carb to first carbs settings (same vac) if u can't match adjust first carb to 2cd carb's highest vac setting. make sure engine is warmed up first.then ride
Apr 03, 2011 | kawasaki ZL 1000 A1 Eliminator Motorcycles
I do not have a tool to fit the needle valves (2) on this carb.? Is there a generic?
I am going to assume you want to adjust the carb. The manufactures make it difficult for you to do this because:
The carbs are preset from the factory to give the best performance and best EPA (emissions)
You can get carb adjusting tools from amazon and other sources. Just do a search for that term.
Before you adjust the carb I suggest you clean the fuel system. Remove the air cleaner and shroud around the carb and spray the carb down with carb cleaner. If you have an air cleaner, replace it. If it is a foam style clean it with Dawn dish detergent. Add fuel stabilizer to your gas/oil mix or 1 oz of Sea Foam brand carb treatment to a gallon of gas/oil mix.
A good cleaning is probably all you need and adjusting the carb will make matters worse.
Jan 05, 2011 | Garden
CLEAND CARB NEED TO KNOW HOW TO ADJUST CARB
Most carbs have the adjustment removed (EPA) but if yours still has the adjusting screws here are the seat of the pants methods:
One Screw Carb: Turn it all the way in and then back out 3-1/2 turns, start the engine and make slight turns in or out until the motor runs smooth from idle to wide open, do not get it too lean, turn in until max RPM is reached then turn out 1/8 turn and go from there.
Two Screw Carb: You adjust the one to remedy either the low or high, high is adjusted until the motor runs smoothly under load at high RPM and the low is adjusted until idle and off idle is smooth.
Feb 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Carb needs adjustment running rough and shaking
sounds like the jet in the carb is bad or was not put in all the way
Sep 09, 2009 | Garden
Whats the best and easiest way to set the carbs on a 1990 yamaha radian yx600
Your problem is probably the sycronizing as long as you havent messed with the fuel screw or jetting. If you dont have a set of vacuum guages you can eyeball the slides in the carbs to at least get you by and you can usually get them pretty close. Find the carb that is directly linked to the cable. the other carbs are adjustable to that carb so you need to make all the other carbs identical to that one. Look at the gap from the bottom of the slide to the bottom of the bore of the carb on that base carb with the throttle at idle bike not running. With the adjustments on the linkage to the other carbs adjust the other slides to the same height as that base carb as close as you can. Measure if possible to get all the carbs as close as possible to each other. you may have to adjust the idle after. If the adjustments on the carbs are all cables, for example there is a cable to each carb directly connected to the slide just adjust each cable accordingly and achieve the same as above. make sure you have a little freeplay at the throttle when you are done. you can adjust that by the cable adjustment by the throttle which will keep all the carbs in sync
Jul 29, 2009 | 1990 Yamaha XJ 600
Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Mar 30, 2009 | Garden
Idle adjustment
If there is not a screw on the side of the carb then look at the top of the carb where the throttle cable connects. The fitting at the top of the carb is threaded and would adjust the carb idle. There may be a similer adjustment at the twist grip but I don't remember one there.
Hope you can rate this solution as a 'FixYa'
Mar 20, 2009 | 2005 Suzuki RM-Z 250
Poulan Pro " Pro" Self Propelled Mower Logo
24 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
