Question about Tablets & eReaders
Where do i place a govia tag on the new holden cruze? The rear vision mirror set up puts it well down the windscreen.
Have forgot the password on my Kindle how do I install a new one
Try this;
Home > Menu > 5 clicks down > Enter (middle 5-Way) > Menu > 3 clicks down > Enter > 1 click right > Enter
Jun 23, 2017 | Tablets & eReaders
My screen is reversed. You have to touch the opposite side of the tablet to select what you want and I just want to know how to fix that.
Here are suggestions I found online:
Press the "font size" key. It should look like Aa or some similar marking. When you click that, you should be able to change the orientation. Use the 5 way controller to move the "selection" up and down and left and right. and then press it when you are over the desired rotation. You want to select the very first A selection
Mar 03, 2015 | Tablets & eReaders
I am currently unable to connect to the kindle store from my kindle Charmians new kindle why?
You are either going to have to phone or go to the store where you bought your Kindle for help. You could do a search for a problem and pick out the best solution that fits your problem.
Feb 26, 2015 | Amazon Kindle Paperwhite
How do I register my Kindle that I did not buy from Amazon?
To buy and deliver Kindle content, you'll need to connect wirelessly and register your Kindle to an Amazon account. Registering also allows you to transfer purchases between Kindle devices and Kindle reading apps. From Home, press the Menu button, and then select Settings. SelectRegistration. Specify the Amazon account you want to use for your Kindle:If you already have an Amazon account: Select this option. Enter the e-mail and password associated with your Amazon account. Select Register. Your name will appear as the Registered User when registration is complete.If you do not have an Amazon account: Select this option and follow the on-screen instructions to set up a new Amazon account.
Jan 25, 2015 | Amazon Kindle Fire HD
How do you put a microsdhc card in a noble tablet
You can add a properly formatted microSD card inside the rear of the device:
  • Power off your Nook, unplug from power, and disconnect it from any USB connection.
  • Place it face down on a kitchen towel (so it won't get scratched).
  • Find the tab near the center of the bottom of the back cover.
  • Lift the tab (gently)and open the back. Note that the cover is snapped-in at the bottom, the middle and the top. Unsnap the cover carefully.
  • Identify and open the microSD slot cover with a fingernail, not a screwdriver!
  • Drop the microSD card into place, while lining up the contacts.
  • Close and then lock the card holder.
  • Replace the back cover onto the Nook
  • Snap the sides into place,and close the tab.
  • Power up and enjoy
NOTE: the card needs to be formatted using FAT32 or FAT16 not NTFS!
Jan 04, 2015 | Tablets & eReaders
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
Jun 05, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
Xo vision xtab factory reset
I had been trying to locate how to access the recovery options for the XO Vision XTAB tablet as well. Mine would show the XO Vision logo on start-up and then show a cursor in the upper left corner for a few seconds and then showed "ANDROID" a little further down and to the right of the upper left hand corner with a flashing cursor right behind it.
I was finally able to get into the recovery options press HOME, VOLUME UP, & POWER at the same time and hold for about 6 seconds or so. You need to let go before the XO Vision logo goes away. Wait until the logo goes away and a cursor should display in the upper left hand corner and then you'll get to the recovery / update options screen.
Use the VOLUME UP / DOWN keys to navigate the menu and then you'll press MENU to select the option. After that let it run through its processes until it completes. My attempt was unsuccessful at a factory reset and I'm still not sure how to fix it, however, you may have better luck.
Apr 08, 2013 | XO Vision Xtab Android Ebook Reader
Tablets & eReaders Logo
55 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
