Change expiration date for hp officejet pro l7600 print cartrige
  • 213 Answers
SOURCE: hp officejet 7110 battery and cmos location
The battery is located behind the left front cover. Open the printer, grasp the left front cover from inside the printer and pull to open. Look inside the printer to left and you will see it.
It is enough to remove for a minute to reset the expiration.
But I'm afraid after that the printer may not keep the date and time when turn off.
Posted on Dec 17, 2008
SOURCE: I have an HP Officejet Pro 7580. When printing in
Press "set up" button until number 6
Number 6 is "tools"
press OK
press forward arrow (to right of ok button)
No.2 is clean printhead
No.3 is align printer
No.4 is calibrate line feed
Posted on May 04, 2009
SOURCE: HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Posted on Dec 29, 2009
SOURCE: HP officejet Pro L7580 print head is not working properly.
i order the 8 jan 2010 2 print heads No : 88 (ref hp c9381a for black/yellow and ref hp c9382a for magenta/cyan) and i receive it after 4 days.
Posted on Jan 15, 2010
  • 5097 Answers
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
Printer claims ink cartridge is expired and won't let me print
Hello, if you change the date on your computer to 3 months previous (say), then reboot, you can probably overcome this temporarily. Obviously, for normal operation it's best to restore the date to current, and only set the date back when you want to print something.Regards,nicam49
Jan 10, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
I have an hp officejet pro l7600
I have an OJ l7600, and the colored ink cartridges pod out on their holdings rendering the printer inoperable. I have tried replacing the cartridges,even though there was ink still available. Even with new cartridges this still happens. What gives?
Jan 20, 2010 | HP Officejet Pro L7680 All-In-One Printer
How can I remove the sending fax number on my transmissions on HP
Check the HP Officejet Pro L7300/L7500/ L7600/L7700 All-in-One series
User Guide
(page 83):
"Configure the fax header:
The fax header prints your name and fax number on the top of every fax you send. HP
recommends that you set up the fax header by using the software that you installed with the device. You can also set up the fax header from the control panel, as described here.
NOTE: In some countries/regions, the fax header information is a legal
requirement.
To set or change the fax header
1. Press Setup.
2. Press Basic Fax Setup, and then press Fax Header.
3. Enter your personal or company name using the numeric keypad, and then press OK.
4. Enter your fax number by using the numeric keypad, and then press OK.
To set or change the fax header via the embedded Web server
▲ Select the Settings tab, select Fax from the left pane, select the Basic sub-tab,
and then enter the Fax Header Name and Fax Number. Click the Apply button."
Sep 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
HP Officejet 9110 empty or expired cartridge error
You were a bit vague in your report as to what the exact error is that you are plagued with. Perhaps you have more than one. The 9100’s ink cartridges are “smart cartridges.” They each have a chip in them that reports various cartridge statuses directly to the printer. Diagnosing the problem correctly requires the identification of the particular error message. You can find a list of the error messages and what they mean here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=376170&prodTypeId=18972&prodSeriesId=376170&objectID=c00067620
I think that you are experiencing an “INK CARTRIDGE EXPIRED” error. This error is not related to the ‘volume’ of the ink within the cartridge(s) but rather to the actual expiration ‘date(s)’ on the cartridge(s). The expiration date is encoded on the chip that resides on the cartridge. The actual expiration date appears to relate to the date two years after the date that is stamped on the cartridge label. I can’t change the expiration date on the chip—at least not easily or inexpensively—but I have discovered a way around it.
The date on the cartridge corresponds to the date on the printer itself. You just need to send the printer back in time to a period before the expiration date and you should be able to print again. A time machine is probably out of the question. Instead, reset the date on the printer to reflect a suitable date.
This could conceivably have some negative consequences that I haven’t experienced yet. I’ve only just discovered this ‘hack’. Though I haven’t tested it, the newly assigned, incorrect date will probably appear on any subsequently received fax transmissions. I can also conceive of networking issues if your printer is networked. Some network related instructions require that all network nodes (all devices on the network—computers, printers, etc.) report a time (and date) within just a few minutes of each other to communicate. You’ll just have to try it in your network and see if everything functions properly or within acceptable limits.
To change the date on the 9100 printer, you’ll need to access the ‘Maintenance’ menu. Just below the LCD panel on the front of the printer there are a series of buttons as follows:
[Return], [Up] & [Down], [Accept], [Left], and [Right]. They each have their own unique symbol, but I’m sure you can understand my descriptions. Press and hold BOTH, the [Up] and the [Down] buttons at the same time while you press and release the [Accept] button—then release the other two buttons. If you weren’t taken directly to the ‘Maintenance’ menu (# 10), then use the [Up] or [Down] arrow button to navigate to it and then choose the [Accept] button to select it. Similarly select the ‘Set date and time’ option, and follow the prompts to make the necessary changes using the appropriate buttons.
Once you have changed the date and time you may have to turn the printer off and then back on again before the printer will recognize the cartridge(s). In my case, the printer went through an extensive print head alignment.
Jan 27, 2009 | HP Officejet 9110 All-In-One InkJet...
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP Officejet L7680
i say change the print head an the cartrige an that should be find
couse i did an my printer is perfect
by andrew
Feb 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
Cartridge error
Hi, As you are receiving cartridge error you can try to check if the cartridge ink levels is fine or take out the cartridges and check for the cartridge expiry dates printed on the cartridges as the cartrige error only occures if there print cartriges are expired.. However you can try the instructions in the below HP webpage to isolate the issue http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-45265-1&cc=us&lc=en&dlc=en&product=390315&dlc=en&lang=en Just click on the weblink to open the HP webpage and follow the instructions if the issue is still unresolved check the issue with another set of cartridges too this should fix the issue Regards, Barret.
Sep 17, 2007 | HP OfficeJet 4255 All-In-One InkJet...
61 people viewed this question
k24674
