Question about Tech Solution TS-900 Calculator
On/off button doesnt turn on
I spilled some juice on my calculator but the cover was on. so i dont really think that the calculator was affected, but now my calculator wont turn on
  • 91 Answers
Normally if you spill any type of liquid that would certainly affect your calculator from working- i would say that you need to have it replaced
Posted on Aug 31, 2007
SOURCE:
Water from a water bottle spilled all over my TI-84 Calculator. I dried it the best I could and replaced the batteries after drying them but none of the buttons work and it won't turn or. And way I can...
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
I also hope you let the calculator dry out thoroughly before replacing the batteries.
Sep 03, 2013 | Office Equipment & Supplies
My calculater has everything on the screen but its really light. I put in new batteries and it still doesnt work. Its a ti-84.
Turn the calculator on. Press and release the 2ND button. Press and hold the up-arrow button to increase the screen contrast. If you go too far, use the 2ND and down-arrow buttons to decrease the contrast.
Sep 15, 2011 | Texas Instruments TI-84 Plus Calculator
I have a coolpix and I spilled orange juice on it. I imediatly cleaned and dried it off but when I would try to turn it on...nothing. It's been a few months I tried to turn it on and it says battery...
First off, are you sure that the battery is charged? It is definitely possible that spilling orange juice on it messed it up, but it might be all right.
Assuming the battery is charged, it is likely that the spill caused some internal damage. When you spilled on it, did you open the battery door, take the battery out, and allow the the camera to air-dry completely before turning it on? If you didn't, it is almost surely fried. If you didn't allow it to air-dry, it is likely that there was residual moisture and liquid on the internal components, and when you powered it on you likely messed them up. This is really a repair that is not worth paying for, as the cost of a new camera would be much cheaper.
May 07, 2011 | Nikon COOLPIX L4 Digital Camera
My daughters's calculator got wet when something spilled in her book bag. We took out the batteries and let it dry out. Later we put in new batteries and it works but is extremely slow and I have to press...
If water was spilled in it, the batteries should have been removed immediately, if you could remove the circuit board from the casing, dry it off and place it under a lamp for a few hours it should have been perfectly fine. If a soft drink, sugar base or other substance was spilled in it; the board would need to be cleaned, a small amount of soap and water can work, use a cotton swab, only clean the affected area of the spill, make sure to rinse all the soap off, dry with towel, then place under a lamp to get all the moisture out. Also make sure you clean the bottom side of the buttons that contact the circuit board. If it doesn't work then you may have to buy another unit.
Jun 19, 2010 | Texas Instruments TI84Plus Graphic...
When i turn on the calculator i get a dark screen and when i try to adjust the con trast it doesnt change
this is what i think you mean, if i diss-understood you (thought you mean something else) im sorry, then i dont know what to do
thats when you set your ti 84+ screen to very dark. this is how to solve it:
go and open mirage OS, and then just press the "-" (minus) button. the screen should get lighter.
Nov 23, 2009 | Texas Instruments TI-83 Plus Calculator
Juice on Shutter and on/off button- sticks or moves hard
take a wooden stick rape a cotton deep in alcohol try to clean it see that the alcohol should not' go inside or go to repair
Oct 16, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Ti-84+ turns on but no key function
Hi everyone,
I just had the same problem with my calculator. Only the On button worked, but nothing else. So I plugged in my calculator to my computer and I reinstalled the latest OS (2.43 I think). That didn't do anything, so I reinstalled OS version 2.22, a very old one. That made my calculator work! I think there is a problem with the 2.43 OS. I haven't tried upgrading my calculator any higher than 2.22. I'm sure 2.30 could work. Good luck. If anyone needs help in installing a new OS, I can help you.
-Eugene C.
Jan 02, 2009 | Texas Instruments TI-84 Plus Calculator
Sharp calculator
I had the same problem happen to me. What I did was carefully take the calculator apart using a T-10 Torx screwdriver to remove the back cover. I then used a compressed air can and blew air into all the crevices and holes in the calculator. I was able to dry almost all of the soda the spilled, however some of the soda dried and turned into somewhat of a sticky mess. I was able to carefully wipe the sticky parts clean with a tissue. After doing all of that my calculator worked perfect.
Nov 15, 2008 | Texas Instruments TI-84 Plus Silver...
Spilt juice on it and it won't turn on
You broke it. The biggest mistake people make after spilling liquids onto electronic devices is to try and turn it on to see if it still works. You should remove the battery and not try to turn on a device until it has had several days of dry warm air around it to ensure all moisture is removed from the electronic parts. I would guess that if you spilled juice on it and it will now not turn on or respond in any way that unit will need to be returned to the manufacturer for repair. Even if it is in warranty they will know it has been "misused" and not honor the warranty. The HDD should be ok but most likely a PCB has died. You could try the accidental damage cover of your household insurance.
Jun 20, 2007 | Archos AV 500 400-Hours Video Recorder
Tech Solution TS-900 Calculator Logo
139 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
