Question about Philips 30PF9946 30 in. HD-Ready Plasma Television
Connecting tv to dvd player
Please tell me how to connect dvd player to ViewSonic N3246w LCD tv with scart leads. Many thanks
  • 5 more comments
  • Anonymous Feb 10, 2008
    After connecting the dvd player to the Philips unit I get the dvd sound but ton picture.
  • jogwh Feb 24, 2008
    When connecting DVD to TV I receive sound but not a picture. I have tried every connection possible. Please offer solution for a non-technical individual..thanks..previous answer was too vague..provide diagram if possible.
  • jogwh Feb 29, 2008
    jogwh - When my cable company came to setup the HD-TV, the service person removed my existing cable and replaced it with the company's cable wire. His comment was, 'we don't use your cable wire any more.' Could this be the problem? Should I try using my cable wire and remove the company's before I spend more dollars?
  • onenicepop May 16, 2008
    When connecting a KOSS Model KD 305 DVD Player to my Protron PLTV-32, I can NOT get the DVD Player to come on. The regular TV keeps playing. How do you turn on the AV-1 & AV-2 Inputs? I'm using a Philips 4-Device Consolidator Universal Remote Controller? My Philips Remote was coded and does work to turn the TV ON & Off. However I ca NOT get it to operate my DVD or VCR Players.
  • KINGPASCAL May 11, 2010
    MY TV IS NOT CONNECTING BECAUSE THERE IS PRGRESSIVE SCAN ON THE DVD PLAYER
    DOES THIS TV HAS A PROGRESSIVE SCAN ON IT
    HOW CAN I TAKE THE PROGESSIVE SCAN FROM MY DVD PLAYER
Hi All
I have the PFM-42V1E with DVI and SVGA inputs only.
I have a special lead that you can get with scart one end and SVGA other - perfect. It also comes with video sync and a little transformer - this is why you have no picture!
Try looking for SyncBlaster cables - there must be many suppliers / variations but i got mine at www.keene.co.uk
Be warned though a good cable will cost you 50-70 GBP.
Hope it helps
Posted on Feb 28, 2008
  • Philips Master
  • 12,061 Answers
It should be fairly straight forwards.. Simply get the SCART to SCART Cable.. Connect up the Two, DVD to Screen, turn them on, selecting any input/outputs Format etc, setups from any Menus...then start player select "Play" & ya should see the Picture & hear the sound...
Posted on Sep 01, 2007
SOURCE:
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
How do I hook up my DVD player to my TV. I have a simple Panasonic DVD player and a Viewsonic flat screen TV.
Hi, I recommend using a scart lead, all TVs and DVD players should have this connection.
Dec 05, 2009 | Sanyo DVW-6100 DVD Player/VCR
What is the TV channel set to to play a dvds151 dvd player?
almost all Dvd players are connected to a television by either a scart or a HDMI lead.
When you plug the scart into the back of your television (make sure its in properly) then turn the power on. on your dvd player.
This should automatically come on as scart leads send a voltage up the scart telling the tv to change to that source/av.
If it is connected via a HDMI cable then if you look at the back of your telly it will tell you what HDMI input number it is. then all you have to do is press the AV/ SOURCE button on your remote to select that number.
Hope this Helps
Little Dish Fitter
Sep 01, 2009 | Daewoo DVDS151 DVD Player
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Can see no way of connection to terrestrial TV, no scart connection?
easy dose it have rf out? or phono out if you have phono out buy a phono to scart lead to conect
Apr 28, 2009 | Televison & Video
Connecting a dvd 250gb hard drive recorder to tv and virgin box
Right then, on the back of the virgin box there are 2 scart outlets, connect one scart from the TV scart port to the scart in on the DVD recorder, then connect one scart lead from the scart out on the DVD recorder to the TV.
Find the DVD recorder source channel on the TV and then use the DVD remote control to find the digital input on the DVD recorder, this is usually AUX channel.
Post back if you need any more help
Good luck and thanks for using Fixya!!
Feb 22, 2009 | Televison & Video
Sir I have just acquired a Sony DVD recorder model no. RDR-GX350. I have an LG LCD TV and a Sky HD Box and I have connected the recorder to the TV with an 'S' lead and I can play a DVD, I can't set up the...
Thanks, but no thanks, in the long run it is better to get a technician in to sort it, more expensive yes, but not so traumatic as trying to deal with someone by typing in answers to questions, the man I dealt with assured me I had two scart plugs on my TV. I only have one, so he said it can't be done, end of story.
Aug 28, 2008 | Sony Televison & Video
I have an Onn 15'' LCD TV Model No OLCD1504 and am trying to connect a DVD player that only has an AV out.I have tried connecting it with a Scart to Av lead in all combinations i.e. via freeview box,direct...
Some dvd players do not have the switching line fro your tv to automatically select scart input but you will be able to select via the tv remote if there are no buttons marked av it can be an oblong with an arrow pointing inwards or you may have to select via the source menu on the tv if you have your original handbook it will give a helpline number for Asda.SUPER8.
Jul 31, 2008 | Televison & Video
Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Jun 25, 2007 | Wharfedale DVD-M3 DVD Player
Open Questions:
HDMI quit working I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent problems with the HDMI audio bleeding in to the other inputs. Sometimes if for instance I turned on the PC, I could hear the audio from the HDMI output on the satellite receiver through the TV speakers. Other times, I might just hear a crackle in the audio when in PC mode. If I switched back and forth between HDMI and PC inputs a couple of times, both issues would go away. I tell this just as background to what happened next. Since I have my PC hooked to the VGA input on the TV, I have been forced to manually switch the HDMI input from the Satellite receiver to my XBOX 360. (Sorry, I was too cheap to buy the $100 switch). Anyway, I usuall make this switch hot (TV on, Satellite receiver on, but XBOX off. This system although a pain, was working until yesterday. I was watching HD satellite, when I decided to play XBOX. I switched the HDMI cable, but when I turned the XBOX on, it wouldn't start up. I immediately assumed my XBOX had crapped out , but when I switche the HDMI cable back to the satellite, the TV would not recognize the signal. I have since tried the XBOX and satellite on another tv with HDMI, and both still work fine. I am thinking that some sort of switch in the tv has gone out, but I don't know. Should I just junk this TV for a new 1080P? My problem with doing that is that I use PIP with the PC on one side, and HDMI on the other. This tv does that, but I can't find another tv that does.
Feb 28, 2017 | Philips 30PF9946 30 in. HD-Ready Plasma...
Philips 30PF9946 30 in. HD-Ready Plasma Television Logo
136 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
