Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
For some reason my device has stopped working. The red light on the side of the device lights up when I plug it in to charge, but when I turn it on it no longer activates the device. it is only 2 months old.
Green light constantly flashing. not charging
yes, when the charging device is turned off and you plug in charger you get one red light and then a green blinking light while charging. When it stops blinking it is fully recharged.
Feb 05, 2018 | Computers & Internet
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
MY LG TONE HBS-730 WILL NOT CHARGE
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
Red light turns on and off while charging e-reader 600
Okay Plug It In And Let The Red Light Turn Off By Itself Then Get A Tooth Pick Or Any Item That Will Go In The Reset Hole Then Pug it In Again. The Red Light Will Still Be On But After Five Minutes Unplug It Turn It On The Light Will Be Yellow Then Turn On .
Jun 07, 2010 | Sony E-reader Portable E-book MP3 Player
All LEDs are in constant switched on state(BLUE)
When you plug in the source device and the output device, all of the LEDs light blue, letting you know that the device is ready to capture. When you are ready to capture, simply press the play button on your source device, the Rec button on the Video Transfer, and the LEDs light red, both on the source side and the output side, letting you know that a recording is in process. To stop recording, press and hold the record button and when the lights turn blue, recording has stopped.
this is the source: http://www.pinnaclesys.com/PublicSite/us/PinnacleLife/Content/Reviews/video+to+ipod.htm
Jul 25, 2009 | Pinnacle Video Transfer
Why does insignia ns-bthdp have a solid blue light?
I had this problem but the red light was on constantly with no response to anything I did. I plugged this into my power adapter and pressed the + and - buttongs at the same time and it reset and started working properly.
Nov 11, 2008 | Cell Phones
Plantronics cs70 nc stop working
Make sure that the power is connected to the headset.  You can tell it's connected because there will be a red solid light on the left side of the front of the charging base.  Check the power cord for any frays and make sure it's plugged into the wall.  If it is, then try the following:
A system reset:
1.  Lift the headset off of the base. 2.  Make sure the headset is turned off.  The green light will not be on on the base. 3.  Hold down the minus button at the same time as the call answer button on the headset.  Hold them down for at least 10 seconds.  An orange light on the headset will flash several times.  It should go off when you let go of the buttons.  If the orange light stays solid, push the minus button once. 4.  Put the headset back in the charging cradle.  Leave it for 30 seconds.  Lift it back out of the cradle and try using it again.
Oct 01, 2008 | Plantronics CS70 Wireless Headset
Not Charging
Same thing happened to me the other day. For some unknown reason my wep500 seemed to just die with no apparent cause or reason. So I took the unit apart and tested the battery with a multi meter. It read 3.9V. So power was not the issue, I then put it back together and by chance, happened to continue pressing the power button for 5 seconds in hope I would see the LEDs flash but no dice. Then for no reason, I went to my phone and tried to pair and to my amazement it actually paired (meaning the device must of been on). So I then hit the big button on the wep500 and sure enough it calls the last number stored in my phone. It turns out (out of all things) the led itself went bad for some unknown reason. I suggest you try charging it (you won't see the red led), try turning it on (you won't see the blue led) and then try pairing from your phone. If you phone indicates it paired, then try calling the last number from your wep500. If it works, then you too have a bad LED (I have never seen an LED go bad before). Hope this helps.
Sep 13, 2008 | Samsung WEP500 Wireless Headset
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
13 people viewed this question
Top Parrot Cell Phones Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
