Habco cooler. temperature control
Temperature control part price
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
SOURCE: Temperature on Keg Cooler (DKC644BLS) is dropping below freezing
Mine did this as well. last night the diplay read "LE" and the temp controls and the C/F buttons were unresponsive. I called Danby. Although I was on hold for 30 minutes, when they did answer they were very helpful. As mentioned elsewhere here, the touchpad has gone bad. You can order it right over the phone. The price of the touchpad is only $2 and shipping is $7. I ordered 2 of the touchpads (why not, right?) and the shipping was still $7 for the both. # for Danby is1-800-263-2629. Make sure your phone is charged.
Posted on Jul 09, 2009
snap101
  • 117 Answers
SOURCE: The water coming out in the shower from a
pull the handle off and there is a black dial you can pull out and readjust on the shaft of the cartridge that will allow you to have cooler and hotter settings. it's black plastic and has little splines on it . the more you go one way the hotter it gets and the same the other way gets cooler
Posted on Jul 29, 2009
  • 7 Answers
SOURCE: can't change the cooler's temperature?
LL is an error code which means that it is too cold. Surprised that it didn't freeze something. Problem is likely the thermostat ($15 - RF-7350-55) or motor control board ($50 - RF-0668-04).
Posted on Jan 28, 2010
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Posted on Feb 17, 2010
Adding freon to a commercial beverage air mm14ge cooler
If it needs gas it has a leak. These coolers generally don't come with gauge access ports and need to be silver brazed into place. These systems have a critical charge and will not operate right unless the exact ounces of refrigerant are in the system. The temperature controls measure coil temperature instead of cabinet temperature. The wrong charge makes them run and run and they cant control temperature. Hope this helped.
May 25, 2014 | Beverage-Air Refrigerators
Transmission fuild in radator
Replace the radiator as the oil cooler in the radiator is split allowing transmission oil to get into the radiator. Best option is to use an air cooled transmission cooler mounted before the radiator. Cools the transmission to below ambient temperature ( not engine temperature) , helps the engine to run cooler ( no heat from the transmission) and no risk of oil in the coolant system. The cost of the system will be close to the price of a new radiator
Nov 29, 2013 | 2000 Dodge Grand Caravan
What is a single zone wine cooler?
Single zone wine coolers have one temperature control and the storage space is undivided so the whole cooler is at the same temperature.
Aug 14, 2012 | Furniture
What kind of cooler should I get if I plan on storing both red and white wines in the same fridge?
You need a dual zone wine cooler. They have two temperature controls and the storage space is divided in such a way that each temperature control has its own section inside the cooler; allowing you to store both red and white wines properly.
Jul 31, 2012 | Furniture
The water is too cold in our newton water cooler. Is there an adjustment to make it warmer?
Yes there is an adjustment. Your water cooler should have a temperature control The enclosed adjustable thermostat is factory presetand should require no adjustment other than for altitude requirements. The temperature control should also be easily accessible.
Without specific model information difficult to identify where the temperature control may be located on your unit.
You might vist their website to identify your model. A search by model number may find more useful information on accessing and adjusting the temperature control.
Trust this is helpful.
Dec 17, 2010 | Computers & Internet
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
Whats the correct temperature the fridge should be set at? our milk goes off very quickly and nothing chills.
A refrigerator should be set for a temperature of 37 to 39 degrees F. Refrigerator controls are not usually marked in degrees but have indications for "warmer-cooler". Set the control toward the cooler side and check the temperature. Place a reliable thermometer on a middle shelf to check the temperature. If the refrigerator is not able to maintain a temperature in the 37 to 39 range then the cooling system may need service.
Oct 21, 2009 | Refrigerators
After pugging in the water cooler, the fan starts running, all good water is cold but the fan never turns off. is this normal.
Yes except if it has a temperature control but would cut off only when it has reached the desired temperature, and water coolers are not the efficiency compared to a heat pump or air-conditioning, it only cools the air with the water running over the pads so whatever the temperature of the water is that’s the temperature the cooler will cool the air to. so in theroy it will only drop the temprature 10 to 15 degrees.
Sep 14, 2009 | Hamilton Beach Water Cooler with Storage...
Habco EMS-28 Thermostat not finctioning correctly
i have HABCO ESM28......Where I can find the thermostat controller.....
Apr 25, 2009 | Danby DKC645BLS Compact Beverage Cooler
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
