Question about Bunn ICB-Twin Coffee Maker
Adjust brew volume - Bunn ICB-Twin Coffee Maker
Adjust bunn coffee maker water level
To adjust the brew volume/batch size you will need to access the main circuit board behind the front panel. Isolate the machine before removing panels.
NOTE: Check that the brewer is connected to water supply, the tank is properly filled and a funnel and server or decanters are in place prior to setting or modifying batch sizes.
  1. Modifying batch sizes: To modify a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. If the brewer has a batch selector switch, position it to the size to be changed. To increase a batch size: Press and hold the START or BREW switch until three clicks are heard. Release the switch (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory) and press it again one or more times. Each time the switch is pressed, 2 secs are added to the brew time period. Allow the brew cycle to finish in order to verify that the desired volume has been achieved. To decrease a batch size: Press and release the START or BREW switch once for every 2 sec interval to be removed from the total brew time period; then immediately press and hold down the START or BREW switch until three clicks are heard. Release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). Allow the brew cycle to finish in order to verify that the desired volume has been achieved.
  2. Setting batch sizes: To set a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. Press and hold the START or BREW switch until three clicks are heard (this will take approx. 10 secs) and then release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). View the level of the liquid being dispensed. When the desired level is reached, turn the ON/OFF switch to "OFF". The brewer remembers this volume and will continue to brew batches of this size until the volume setting procedure is repeated. Empty server(s), turn selector switch to positions that have yet to be set and repeat batch setting procedure until all batch sizes are set.
    NOTE: When brewing coffee, batch volumes will decrease due to absorption by the coffee grounds.
  3. Setting programming disable feature: If it becomes necessary to prevent anyone from changing brew times once
    programmed, you can set the SET/LOCK switch to the "LOCK" position. This will prevent any programming to be done.
    NOTE: If the clicks cannot be heard, lightly grip the incoming water line to feel when the valve cycles on and off.
Jun 22, 2014 | Bunn CWTF15-TC
Saeco Intuita adjust water volume
Press and hold the coffee button the entire time until the cup gets to the length that you prefer, then let go. That will program the cup to that length.
Saeco Parts
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Sep 14, 2013 | Saeco Magic De Luxe Espresso Machine
Why doesn't it brew a full cup?
The settings are incorrect. See manual for setting up volume measures and reset.
Sep 19, 2012 | Keurig B60 Special Edition Gourmet...
My Bunn CWT15-APS , PF works well except when i push the start button it only makes a few ounces of coffee. Can you help?
It is possible that the brew volume needs to be set, remove the front panel and you find the instructions to set the brew volume.
Sep 22, 2011 | Bunn CWTF 15-APS Coffee Maker
How many ounces or cups of ground coffee is standard for a Bunn dual dbc to make a 1/2 gallon of brewed coffee?
For a half gallon of brewed coffee you should start with a "volume" measure of 10 oz. The reason I recommend a volume measure is because the weight could be completely different using light roast or dark roast coffees. Brewing by volume you can have consistency throughout. The main object is to have the same surface area of grounds for your brewing. The 10 oz. volume should equal between 3.75 and 4.25 ounces by weight. Adjust by taste to your palette but don't sway too low in amount of grounds, otherwise you will stand to "over-extract" and your coffee will taste bitter and will have no body or mouth-feel.
Oct 12, 2010 | Bunn Dual SH DBC
Decreased brewing volume per cup, sluggish start to brewing
You should descale to see if that helps but if not you should contact Keurig 866-901-2739 or Green Mountain Coffee and 866-639-2326 to see if they have any suggestions or if this may be a known issue with that model brewer
Feb 11, 2010 | Keurig B60 Coffee Maker
The coffee maker over flows with coffee
You might have to reprogram the brew level. Does it over fill the decanter or is is over flowing from the brew basket?
If from the decanter then reprogram, there are instructions behind the front panel.
If from the brew basket then adjust coffee grind and or volume, also check and clean the sprayhead.
Jul 14, 2009 | Bunn CWTF35-3- Stainless Steel
I have a new Z5 (less than 300 cups) that began dispensing a slow and reduced volume of coffee and also began leaking approx 3 oz of water into the tray after just 2-3 cups of coffee. I have meticulously...
If the grounds are really wet and not looks like a round firm cake, you need to use coarser grist on the grinder. The water in the drip tray is coming from the brew unit. The o-rings are not holding the pressure inside because the sieve is clogged. It could also be that the o-ring are dirty, then the brew unit needs to be disassembled and cleaned.
A good way to controll if the grist is too fine, is to watch if the coffee is just dripping from the outlet. Then try adjusting the grinder until the coffee flows evenly. You can also hear if the pump works harder during brewing.
Apr 26, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Bunn ICB-Twin Coffee Maker Logo
18 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
