Question about Refrigerators
I have a Samsung Srs583dw the temp on the fridge has gone to 10 degrees and i try and bring it down to 3 and it goes straight back up to 10 it also sounds like the fan is constantly going when i open the door it stops and as soon as i shut the door it starts again can u please help ? Freezer part is still working fine
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
What usually causes this problem is that the oil used in the system changes position as if you have moved the fridge recently or the other possibilty is that the fan is over used and its damaged and is not cooling the gas as it should,in any of these cases you need to contact your dealership or a local repairs man to fix it.try not to fix it yourself and make it worse!! ;)
Posted on Aug 01, 2013
docjohn174
  • 943 Answers
SOURCE: RS21DGRS SAMSUNG SIDE BY SIDE REFRIDGERATOR
hi thanks for the question it might be a problem with a little frost on the freezer wall fridge not defrosting check the freezer wall with your hand,will feel some frost if this is the problem thanks the appliance doc you
Posted on Sep 17, 2008
SOURCE: Samsung RS2555SL humming noise
the freezer has gone on to test mode for some reason press and hold down at the same time the power cool and power freeze buttons for 8 seconds this will take it off its test cycle
good luck
phil
Posted on Mar 30, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Posted on Jun 28, 2009
  • 117 Answers
SOURCE: Samsung RSH1DTMH fridge freezer. All of a sudden
HI THIS SHORT VIDEO MAY HELP">
Posted on Sep 16, 2010
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
Samsung SRS583DW Fridge / Freezer not freezing
The unit has a built in defrost cycle that is controlled by the main board. You need to replace that board.
Nov 20, 2013 | Samsung Refrigerators
I have the samsung upside down fridge 590 litre freezer is great but the fridge is showing it is set on 3 degrees but inside the fridge it is 7
For starters, Get a second thermometer to check against those two.
Also leave the freezer closed to several hours and see what the difference is in temp.
I would expect that the inside temp would mostly be warmer than the 'set' temp., as the latter is always trying to catch up every time the freezer door opens.
Oct 24, 2013 | Samsung Refrigerators
My refrigerator display shows "Of" how do I get it to normal when I reset the temp for the fridge or freezer the display goes back to "Of"
I just had the same problem with my Samsung. OF means it is in demo mode. On my fridge I had to press "Energy Service" key and "Power Freeze" key simultaneously for at least 3 seconds to bring the fridge out of demo mode. Hope this helps.....
Jan 28, 2013 | Samsung Refrigerators
I havea Samsung SRS583DW model and the tempreture on my fridge keeps going up and down?.
Need to have you double check the model number. This way you can get faster service. Samsung numbers begin with RS2 Thanks Sea Breeze
Dec 12, 2009 | Samsung Refrigerators
Freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Apr 01, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
RS21DCNS
as a rule of thumb mfgs say give the unit 24 hrs to stablize where are you gettings the readings the fridge or freezer sides freezer readings run from -8 to -10 the fridge should run 34to38
Jan 31, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
141 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
