Question about Motorola Mobility RAZR V3
Voicemail I want to set up a personal voice mail answer on my motorola razr, but cannot figure it out. Only choice given is my name. Help please!!
    Brigadier General:
  • 7,752 Answers
Re: voicemail
You will have to call you mobile service provider and have them assist you with this issue.
Posted on Feb 22, 2008
0 characters
3 Points
I have a pantech caper 8035Txt prepaid with verizon and my voicemail is on please help me turn it OFF.
Hi Sandra,
I'm here in Australia and straight away thought is Verizon like some wholesale carriers here where by default VMB is turned on and the only way to switch it off/disable is by contacting the network/cell I asked Google and came up with the info in link.
How to Turn Off Voicemail
I hope it helps.
Nov 02, 2014 | Cell Phones
Motorola RAZR V3:Can't delete each and every voicemail (new or stored) when directed to press #7. Also can't prevent hearing the date and time for each voicemail. What is the solution?
hearing the date and time for each voice mail is adjusted using your carriers voice mail options. as for deleting each voice mail, it usually requires that you push 7 to save a voice mail and 9 to delete
Sep 07, 2010 | Motorola Mobility RAZR V3i Cellular Phone
My Verizon Razr V3 voice mail indicator
have you set your voicemail box up yet? maybe thats your problem...if you cant get it to work call customer service from a different phone so a customer representative can help you with your problem.
Apr 09, 2009 | Motorola Mobility RAZR V3
Call your wireless provider for a voicemail reset. YOU MAY lose all of your new messages, but its the only way to unlock your vm.
Dec 11, 2008 | Motorola Mobility RAZR V3
Voicemail answering
Contact your mobile service provider's helpdesk for further assistance on activating your VM
Aug 28, 2008 | Motorola Mobility RAZR V3
Recorded message after my personalized greeting
This isn't in the phone. It's in your voicemail preferences. Listen to all options in your voicemail settings. Just keep listening for an option number for settings after it tells you that you do or dont have messages. If you dont find something fairly obvious call *611 and tech support should be able to talk you through it. Call from a phone other than the razr.
May 29, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Razr v3 setting up voice mail
Which mobile service carrier do you use? Are you trying to setup voicemail to play your messages on your phone, or are you trying to setup greetings and what not inside of the voicemail?
Your voicemail settings depend on where you live, and there are hundreds of different access numbers. If you are trying to setup the phone to connect to voicemail and are on Cingular/AT&T, call them at 800-331-0500 from a different phone and they can walk you through the setup easily since they have access to the appropriate voicemail access number for your location.
Dec 17, 2007 | Motorola Mobility RAZR V3
Voice mail
is this a new purchase? Perhaps you havent set up your voicemail yet. Usually to access it from your phone you dial 123.
Dec 08, 2007 | Motorola Mobility RAZR V3
Recorded voice
I assume you mean your voicemail? If so, call your voicemail and you can change these settings in the Admin Menu. Listen to the prompts, it will walk you through it.
Nov 27, 2007 | Motorola Mobility RAZR V3
Changing the message
when your done listining to voice mails go into admin options you can change you greetings there and record new greetings there
Sep 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
