How to repressurise a certikin genie 50 boiler
3 Suggested Answers
SOURCE: Repressurise Potterton Performa 24 boiler
hope this is helpful. On my potterton 24 combi boiler it is the valve that sits the lowest, with a slight indent in the black tap. if you turn this for a short period you will hear a hiss and the pressure will quickly build to the desired pressure, when you can them turn the tap back off.
Posted on Feb 05, 2009
  • 3 Answers
SOURCE: I have a Certikin Genie
You could try resetting this as it could be caused by several factors (blown heat exchanger being one as Karl mentioned).
Hve you tried resetting from in Service Mode ?
To get to Servce mode you need to go ino User Setup Mode first (turn off the boiler via the panel switch - then hold the Lock/Reset button whilst turning back on). Once in User Setup Mode if you rotate the thermostats all the way clockwise (it should display the software version) Then press and hold the Lock/Reset button for 3 seconds.
This should put you into service mode and it is now possible to change/reset some of the control parameters.
If you try resetting the error.
This issue may be caused if the Flue or water stat is tripped (in which case reset the stat). If th Fan resistor remains open in the circuit then you will need tsomeone out to investigate as that may cause the GAS error too.
COuldalso be the Valve coils are faulty in wich case they need replacing (agians I would get an engineer outto confirm and do that).
I'm suyou probably tried all this but just in case...
If the roblem is solved can you advise what fixed it ?
Thanks
Posted on Jul 01, 2013
Hello! I've got a Ferroli Optimax HE Plus 31c boiler with the F37 fault flashing.
Try bleeding the air out of the rads then represure system
Sep 17, 2016 | Heating & Cooling
Boiler pressure saunier duval
Appear to be corroded/plugged inlet valve. De-pressurize system and check inlet valves and line.
May 11, 2013 | Water Heaters
Low pressure Saunier Duval therma condens boiler
May need to replace valves (appear to be corroded and plugged with deposits) and install a water conditioner in the inlet line if you have hard water.
Boiler pressure up at 3 bar and need to try to repressurise
may at the back outside casing can be pressurised by footpump if required
Oct 12, 2009 | Water Heaters
Vokera linea 28 boiler. I am continuously having to re-pressurise the loop (about twice weekly) also i keep getting a code 3 error appear which i know is a fan flue problem i have reset the boiler. The...
I have a similar problem with this boiler. When CH on, boiler overpressurises, (check relief valve outlet) You will then lose water from the CH loop and will have to repressurise when the CH loop cools. The problem is most likely caused by a loss of air from the expansion tank, which will need re-charged. This is not a big job as it has a standard tyre type valve connection but needs an accurate pressure gauge. Probably best left for plumber.
Mar 12, 2009 | Water Heaters
Jan 07, 2009 | Heating & Cooling
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
I have a 6 year old Halstead Ace High boiler which has many recurring problems due to a bad fitting. It was never flushed out causing the heat exchange needing to replaced TWICE through clogging and then...
Firstly your system needs a power flush to get rid of the grot, then it needs a good inhibitor to slow up the reappearance of the sludge.
Changing the boiler won't help. Any boiler will get clogged up but the halstead DHW heat exchanger is particualrly prone to getting gummed up. You can clean this out and refit without having to buy a new one. - but without a power flush it will happen again.
Jul 31, 2008 | Heating & Cooling
I have a Certikin Genie swimming pool boiler that is showing the word GAS and i can smell it. What should i do?
Thanks
Jul 13, 2008 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
