Question about Water Heaters
GSM10B-001 - Water Heaters
I have a John Wood powervented gas water heater, model 322152-001(13-05). The temp pressure relief valve is leaking. How do I operate/reset the valve manually?
There is a leaver YOU CAN PULL up but this may not stop the valve passing it may wash any dirt of the seating ,It may be best to change the valve .
Dec 19, 2016 | Water Water Heaters
Igniter on gas water heater only sparks once
First pull the ignitor wire off the ignition module...hold a screwdriver 1/8 to 1/4 inch away from the electrode pin on the module then turn the unit on to see if it sparks differently than what you described before you replace the ignitor.
Dec 19, 2013 | Honeywell Water Heaters
Water Heaters Logo
90 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
