I have a Panasonic VHS Super Drive Ai NV-SD400 Show View that jams tapes now as soon as they are loaded. Apparently I now need a new loading mechanism. Any idea where I can source this, or is it just easier to buy another machine? Loathe to do as the current one has not been used that much and fits in with other units. Thanks.
SOURCE: DV tapes will not load
The problem you are having is caused by the grease that is used to move the reel positioning mechanism has hardened. Once the grease hardens the reels can no longer position properly. The grease needs to be removed and replaced. Do not remove the cassette assembly, only remove the top plate. Also check the pinch roller grease, make sure the pinch roller moves freely.
Posted on Dec 26, 2007
SOURCE: panasonic VCR VIDEO PLAYER
Hi, the problem may be typical for this VCR , you must to change 2 mechanical parts, one is the plug on the loading motor , the other is a rod, but you must to have experience in VCR repairs, becouse of that the best solution is to find a Panasonic service center
Posted on Jun 04, 2008
  • 4234 Answers
SOURCE: Part for VCR mechanism
I'm not sure what part you ned, but parts are still available from generic suppliers although not from Mitsubishi. Where are you located?
Dan
Posted on Oct 01, 2008
sodeep
  • 3267 Answers
SOURCE: VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
Posted on May 09, 2009
Grubhead
  • 5487 Answers
SOURCE: PANASONIC VCR DOES NOT LOADE THE CASSETT TAPE AND
VCR's have a thing called a mode switch. This tells the electronics of the machine want position the mechanical section is in. If it gets wrong signals then the VCR electronics power the machine down. These wrong signals are often caused by damage to any part of the VCR mechanical section. Perhaps in this case something to do with the carriage unit. But the switch itself can go wrong. A visual inspection inside might reveal damage to some part of the VCR.
Posted on Jan 21, 2011
Panasonic vhs super drive Ai NV-SD400 show view
Curry's Partmaster has a good range of parts for this machine. They don't look to expensive, so try them.
Jul 31, 2013 | Televison & Video
VHS Tape won't stay in compartment
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
My family videos are stored on the mini VHS tapes. I recently bought a VCR to dvd recorder to transfer them into dvds but now I discover my VHS playpak (that you need to play the mini tapes) is broken....
Maplin Electronics have a motorised VHS-C Cassette adaptor that will enable you to view any camcorder tape on a standard VHS. If that is any help priced around £15.00.
Mar 14, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a panasonic nv-hd640 i can't eject tape, when i try to eject give me a error f06 and turn off the video thank you
You have a K-Deck model there's lots of information on the net about these so check it out.
Meanwhile F06 means that the mechanism is locking up (getting stuck) after unloading the tape. The cause of which is either something to do with the loading motor or the carriage (where the tape fits) alignment.
Just type "Panasonic K-Deck Mechansim" into Google for the information.
Jan 16, 2011 | Panasonic NV-HD670BDX VHS VCR
Cannot view tapes. Picture fuzzy, interference lines on screen.
Well I have heard that sometimes the tape inside of the videocastettes that show the pictures on the screen wears out over time periods and from rewinding and fastforwarding so many times or the old age and useage so you could get the video castette tapes fixed but its not worth it now you should buy a DVD player because they are better and have less problems and most VHS tapes are on DVD too. Or check to see if any other devices are on at the same time.
Feb 23, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
How to time loading arm cogs on VCR?
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
Jan 03, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic video recorder malfunction
It sounds like you need a service manual - it tells you how to remove stuck tapes etc.If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
http://www.reptips.dk/Reptips/NV-FJ620.pdf
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
My Video casset palyer is Panasonic NV-MV20 VHS VCR
Looks like the Loading cage gears Timing has got messed up. If you are worried about taking it to a Repair Shop, take it to the company service centre.
Mar 16, 2007 | Panasonic NV-MV20 VHS VCR
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
