Question about Nokia Lumia 820
Cant calibrate touch screen - Nokia Lumia 820
My iphone screen cant touch ?
Hello there,
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Thank you for using fixya.
Caseytech
Sep 21, 2011 | Apple iPhone Smartphone
Touch screen not working
The digitizer is no longer calibrated correctly. Open a support case at TomTom.
Jun 17, 2008 | Tomtom ONE GPS Receiver
My samsung s800 touch screen is sensing all touches like they are being made to the far left of the screen. can access any functions as they all require a touch in other places on the screen, had the...
The only way to get this back to normal is to re-calibrate the screen...
You can only do this through the handset menus.
If you can, go to settings > Phone settings > Calibration and re-calibrate
If you cannot even go into the menu properly, there is not a lot you can do other than a master reset or a software update (using the kies software).
You can do a reset by typing *2767*3855# if you can get to the call screen.
If not, it's a return to the manufacturer I'm afraid!
Feb 03, 2011 | Samsung Jet S8000 Cell Phone
My touch screen quit working
If the touch screen of your phone keeps working, then it means the sensor board of the phone is bad and need to be replaced, if you can access the menu of the phone, then you need to calibrate the screen first.
To calibrate the screen, you need to go to the menu, then you select settings, then you select calibrate screen then you follow the rest of the instruction from there on.
If calibrating the screen does not help you, then it means you have to fix the sensor board of the phone, if your information from the keypad reaches the screen, then it means you simply need to replace the touch sensor board of the phone.
Hope this helped.
Take care and good luck
Jan 10, 2011 | Samsung SGH-A877 Impression Cell Phone
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Dec 29, 2009 | Sylvania SMPK8854 Digital Media Player
Most of my ds lite touch screen is not responding
try getting to the calibration menu with the buttons and calibrate if u can if not send it in to nintendo for repairs
Sep 21, 2009 | Nintendo DS Lite Console
Touchscreen wont work
touch screen wont work,
what is it doing ?
Aug 14, 2009 | Sylvania SMPK8854 Digital Media Player
Stylus
Its not the styles it the ds
May 22, 2009 | Nerf Stylus Twin Pack for Nintendo DS...
The touch screen and the pen do not pair to function
my i9 phone does not apply the touch screen anymore and the pen calibration i cant click on screen . when i try to calibrate it keeps on the same infomation of "touch where the point is , left, center and right.
Dec 24, 2008 | Dual Electronics CECT P168 Cellular Phone
Calibrating the stick and screen
Go into system and choose calibration.
Dec 17, 2008 | Palm Tungsten E Handheld
Nokia Lumia 820 Logo
301 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
