Question about Samsung RS2630SH Side by Side Refrigerator
Icemaker The icemaker will not eject the frozen cubes.
  • 58 Answers
The bracket that hold the tray could be broke
Posted on Oct 31, 2007
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Icemaker on subzero 650 slow
check for water flow at water valve or replace water valve
Dec 09, 2013 | Sub-Zero 650 / O Bottom Freezer...
My icemaker has stopped ejecting the frozen cubes. If I press the button under the front of the device it does go through the eject cycle and fill again normally but then when the cubes are frozen it will...
Since you can work it manually (with the button) it is probably what they call the fixer sensor p/n DA61-01800A. It must not be sensing that the ice cubes are "fixed"
Jul 03, 2011 | Samsung RS2630SH Side by Side Refrigerator
The water dispenser on the door works, but the ice maker won't make ice
Pour about 1/2 cup of water into icemaker . If it dumps the cubes after freezing , but doesn't refill with water , then replace the water inlet valve ( part that wall water line connects to on fridge ). If the icemaker does not dump and holds the frozen cubes , replace the icemaker . Also check the fill tube at the icemaker to make sure it is not frozen closed , due to a seeping water valve , and make sure the coils are clean beneath refrig of dust , lint , pet hair , etc.
Aug 28, 2009 | Kenmore Refrigerators
Freezer is not making ice, help?
Aug 28, 2009 | Frigidaire FRS26H5AS Side by Side...
My ice maker has quit working. The water is not filling the tray.
Pour 1/2 cup of water into icemaker . If it dumps the cubes when frozen , then check the fill tube going into the icemaker , to see if it is frozen solid . If it is , remove and clean and replace water valve ( drip seeping ) . If not frozen , replace the wqter valve anyway . If the icemaker doesn't dump the cubes , and holds the frozen ice , replace the icemaker , after making sure the coils under fridge are free of dust , lint , pet hair etc.The icemaker needs to be 5 degrees to operate , and , dirty coils could bring the temp up to 6 or higher in the freezer section .
Aug 27, 2009 | Whirlpool Refrigerators
Kenmore freezer not making ice
Pour about 1/2 cup of water into icemaker ( unless ice is already there ) . If the icemaker dumps the cubes , then the water valve is bad . If it doesn't dump , and holds the frozen cubes , replace the icemaker . Also check your coils to make sure they are clean from dust , lint , etc . Check the fill tube going to the icemaker , to make sure it isn't frozen with ice . If it is , then watervalve is still bad (leaking ) .
Aug 25, 2009 | Kenmore Freezers
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
RS2630SH icemaker slow production
Had the same problem. This allows 12 seconds for the tray to fill. If your water filter is the least bit dirty or the water supply line is clogged a bit, you will get an incomplete fill and the cubes will be hollow, mishapen, or, in my case, all won't eject properly. Replace your filter. If that doesn't do it then use a shop vac with any kind of modification to it that will fit into the supply line and **** out the blockages. Hope this helps.
May 27, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ice is not ejecting
Sounds like the icemaker thermostat is opening too soon which turns the heater off.  The easiest thing to do is replace the whole ice maker which I have seen pretty cheap on ebay.  If you want you can test these part with an ohm meter.  Check the heater for resistance.  If it is ok then replace the module and thermostat.
Oct 26, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Samsung RS2630SH Side by Side Refrigerator Logo
128 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
