Question about Seth Thomas St. Thomas Creations 6006.130 Palermo 1-PC Enhanced Height Elongated Toilet
Toilet flapper Model 6122 flapper, where do I purchase
Toilet is running
The most common reason for a toilet to continue to run is a problem with either the flapper or the entire flush valve itself. The water is slowly draining so the fill valve keeps running.
The flapper is the least expensive and easiest solution, so start their. It's usually around $5. If that doesn't solve the problem, I would purchase a flush valve kit, around $20, and replace your flush valve.
*Note: If you have to replace the flush valve, you have to take your toilet apart. Start with the flapper.
Feb 27, 2015 | Home
This flapper seems to be a desige failure. what product is a good alternative.
universal flappers fit all different ways you may have to cut or alter the tabs or o-ring to make it sit right also check chain is set right
Apr 03, 2014 | Fluidmaster 5403 3-in Universal Flapper
American Standard Carlyle Series toilet is refilling about 10 percent of the water in the tank every 20 minutes. Do I need to replace the flapper or the entire flush valve?
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
Sep 20, 2013 | American Standard 2004.014 - Champion...
Problem with water leakage at flapper valve on eljer toilet
recheck flapper may have replaced it with wrong one
Nov 26, 2012 | Home
I'm pretty sure i need a new flapper but can't find one specifically labeled for kallista michael Smith Town toilets when I search for parts/flappers. Can you suggest another brand toilet whose flapper...
Hello, I can assist you. The flapper part number you need for replacement is GP1078440. You can purchase this item from any of our authorized locations. To find a showroom location near you please visit www.Kallista.com or call our customer service team at 1-888-452-5547.
Oct 02, 2010 | Kallista Michael S Smith Country Mahogany...
Toto i piece toilet 6 ltr. water leaking to lower bowl replaced flapper, tightened tank drain works fine for a short period. Should I be purchasing a manufacting flapper Tom C
Yes, for many toilets you need to get the exact flapper to make them seal properly...the generic will often not work properly..
heatman101
Aug 04, 2010 | Toto UltraMax One Piece Toilet, 1.6 GPF -...
Yellow attachment to flapper in Cadet 3 toilet tank
Some toilet flappers are designed with this some are not. It has to do with the particular flapper design, helping the flapper to stay in the open position to allow a better flush. Anyways you should be to adjust this float up or down to optimize it's usefulness. Trial and error is all you can do, keep watching and flushing until it no longer gets in the way. I hope this helps in at least knowing that for your toilet and the flapper you have, it's suppose to be there. Good luck and thanks for using FIXYA and have a great weekend. Jeff
Apr 09, 2010 | American Standard 4112.016 Cadet Toilet...
Small streams of H2O down interior sides of commode bowl. Have replaced flapper and color tested for leakage,Nada, replaced ballcock fill assembly with Fluidmaster unit and still getting very small...
this is still the flapper.each toilet has a flapper designed to fit each toilet.your may not have the right flapper for the toilet you have.not all flappers weights are the same.youmay need to add some weight to the flapper or replace it with one that is designed for that model toilet.good luck with your project
Sep 29, 2009 | Home
Toto toilet, flapper doesn't stay up long enough to flush
One of two things is the problem. First, make sure that you have a tight chain with little slack. If there's too much slack, the flapper won't catch in the passing air to stay up. Second, the flapper is not correct for that style of toilet. You might want to look into purchasing a new Kolby filter that has a removeable cone in the center. Move that cone to 12 o'clock to allow the maximum amount of water to run through the flush valve. If the flapper you have now is flat, it needs to have a cone in the center on the underside.
Jul 09, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Valve adjustment
You need to replace the flapper and you will need to purchase one specifically for the Kohler toilet. I have the same toilet and tried using a generic flapper and from experiance, it didn't work until I bought the correct one and I'm a plumber! Have a great night.
Apr 01, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Seth Thomas St. Thomas Creations 6006.130 Palermo 1-PC Enhanced Height Elongated Toilet Logo
Top Seth Thomas Home Experts
Austin
UsedClockPartsdotCom...
William Smith
William Smith
Are you a Seth Thomas Home Expert? Answer questions, earn points and help others
