Question about Campbell Hausfeld 26 - Gallon Air Compressor
Need manual for Champion compressor 6.5V80E - Campbell Hausfeld 26 - Gallon Air Compressor
Champion CSF30 compressor high screw temp fault
Check the oil level, if oil level is ok, check the cooler for cleanliness, if cooler is clean, check the thermal valve by measuring the temperatures going in and coming out of valve. The final thing would be the air-end (pump). has lost it clearances.
Apr 04, 2014 | Champion Air Tools & Compressors
Builds up pressure pop off valve at tank opens will not regulate pressure
I would say you have a problem with your pressure switch, you may need to adjust it down. The pressure switch is normally located under plastic cover where your on off switch is on the compressor. There should be a screw with arrows next to it. Try that, otherwise you may need a new switch
Sep 27, 2012 | Champion International Champion 2 Stage...
Need manual for air compressor 5 rca
That is made by Gardner Denver under the same model number. I could not find a manual for it but here is their site. I would contact them and see if they can furnish you one.
Gardner Denver
Aug 25, 2012 | Champion International Champion 2 Stage...
Having problems with my champion air compressor
Crankcase vent may be stopped up. Could have too much oil in the compressor.
May 28, 2010 | Champion International Champion 532 2...
Champion compressor pops manifold relief on head
depends on what relief valve it is, if it is a 2 stage pump and it is the relief on the inner-stage that is lifting indicates the second stage is not pumping correctly! I would check for a broken valve. if it is the one on the discharge line to the tank, then something is restricting it, check for blockages in the line or in the check valve entering into the tank. Most important you isolate the compressor and drain all air pressure before you attempt any repairs
Dec 29, 2009 | Champion International Air Tools &...
Compressor not cycling and building pressure after servicing
Hi
I suspect you may have either overfilled the sump or used the wrong viscosity oil, may have splashed up onto valves and patially jammed one open.
Aug 11, 2009 | Champion International Champion 532 2...
After replacing Bearing, Compressor will pressurize to 30psi. It just runs without increasing pressure.
What bearing did you replace? Check belt tension. there should be less than 1 inch of deflection.
Jul 07, 2009 | Champion International Champion 532 2...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
57 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
