Enable touchpad emachine
My acer mousepad is not working what is the command for this problem there is no any hardware issue
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Then its a driver issue!!
try using a usb mouse and then re-installing all the drivers that are provided in one of your laptop's partitions or try downloading them from the acer web site.
or try re-installing the windows
Posted on Aug 01, 2013
SOURCE: touch pad inactive
press the Fn+F7. Fn is between the ctrl and window key.
Posted on Apr 23, 2008
ajuhere81
  • 256 Answers
SOURCE: Acer Aspire 5720 'quick launch' buttons
it may be due the windows problem , virus in system or not proper driver installed . pls check for all this
Posted on Aug 12, 2009
weblord
  • 507 Answers
SOURCE: emachines laptop touchpad diabled.what keys do i
there are no keys, it can only be enabled using the software that came with it.
Posted on Oct 20, 2009
WinstonMeyn
  • 141 Answers
SOURCE: my acer 5517 touchpad is not working. what should
Onto the left side of the power button there is button which has a picture of a hand on a rectangle, turn that button off , Touch pad will be enabled
Posted on Jun 30, 2010
SOURCE: My Acer emachine E627 the touchpad doesn`t work.
Mine stopped working too, and it turns out to be that button to the left of the power button that disabled it. Check that...if the
light is on the mouse pad is lock... Hope it helps!
Posted on Oct 04, 2010
Mousepad not working
It was probably inadvertently disabled. To re-enable the touchpad press the Fn and F7 button at the same time. This toggles the touchpad to ENABLE/DISABLE.
Nov 29, 2010 | Acer Aspire One PC Notebook
I have a toshiba laptop the mousepad won't move.
First connect a mouse to your laptop. Click "Start" and open the control panel, click printers and other hardware and then click "mouse". Under mouse properties, click the "device settings" tab. Under the device window, you can see if the touchpad is enabled or not. If it is not enabled, click on the enable button.then click "apply" of "ok" button. Your touchpad should be working again.
Sep 07, 2010 | Computers & Internet
Each Touchbad should have basic functionality by default in every Operating system, letting it be used even when no driver is installed. However, try pressing FN and F7 together and see if the touchpad works again. Some people accidently press this FN + F7 key when they mute the sound with the FN + F8 key.
The FN + F7 is there to disable/enable the touchpad as some people use a USB mouse instead of the touchpad.
If you still need the drivers, here are the download links. Please choose desired driver by Operating system and Touchpad brand...
Acer Windows XP TP Drivers Synaptics
Acer Windows XP TP Drivers ALPS
Acer Windows 7 TP Drivers Synaptics
Acer Windows 7 TP Drivers ALPS
Acer Windows Vista TP Drivers Synaptics
May 18, 2010 | Acer Aspire One PC Notebook
I have recently bought an acer aspire 5532 and the mousepad has stopped working how can i check if it is enabled and re-enable it if it isn't
Hi
Thank you for your query
From what you are descrbing the mousepad has been locked up
Normally for Acer's the key to unlock is fn+F7 or F5 however if these 2 dont work the picture your looking for ontop of the F key is a small rectangle with a arrow/finger pointing to it
I hope this helps
Mar 04, 2010 | Acer Aspire 3050 Notebook
Touchpad stopped working..I can get a usb mouse to work
It seems to me the drivers for your mousepad may be out dated go to hardware manager and update drivers
if you need help doing this just ask
Thanks
Cbz123
Feb 08, 2010 | Acer Aspire 5500 5570-2609 Laptop
The touchpad on my emachines E525 isnt working AT ALL although is says its enabled in the properties menu... any tips? or is it a hardware problem
It might be an internal problem. Hopefully you haven't drop it. If it persist you may need to take it apart and look at the actual connection for the touch pad.
Feb 06, 2010 | Acer eMachines 520-2890 Notebook
The mousepad on my acer aspire 5633WLMi doesn't work...any ideas?
Check if it's enabled. If enabled, but still don't work, connect an USB mouse to any free USB port. If you can move the pointer with the mouse, but nor with the touchpad, reinstall your touchpad's drivers. If stills refusing to work, then take your laptop to service center.
Nov 21, 2009 | Televison & Video
Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Apr 14, 2009 | Toshiba Satellite A60 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
