Question about Caterpillar Cat Pump Pressure Washer Pump 3SP30G11
What other pressure washer pump than general pump tx 1510a will fit honda 390 gx
How to fix a flooded engine.
Remove the spark plug and pull the starter rope several times to clean the cylinder, clean the spark plug and fit it back, try to restart the engine.
Aug 13, 2014 | Honda Gx390 Gx 390 13.0 Used Small Engine...
I installed a new GX 390 Honda engine in a Toro 413 TX machine. Motor starts, idles and full throttle fine, but when hydraulics,i.e. drive is engaged, motor dies.
you have a dingo, ugh
I would suspect a bad pump or wheel motor if the rpms are set correctly and no safety switches are causing it to die...
Dec 26, 2013 | 13 HP Electric Start GX390
I am looking at buying the following 2006 Landa PG4-3500 PSI washer Used 283 hours, 13 HP Honda GX-390 3.8GPM, pump 1300RPM Comes w/ wand, hose,& 4 tips What would this washer be worth?
It has quite allot of hours on it so it has been used extensively. 283 hours on a pressure washer pump is about 27% of it's life expectancy. The good news is that it has a Honda engine. If it runs perfectly, looks like it has been taken care of, and has plenty of pressure, I would pay no more than around $400 for it tops. You are the buyer and the seller is wanting to sell. You have the upper hand in this deal. Offer $300 and then bargain.
Jan 06, 2011 | Honda Garden
We need a manual for our pressure washer 3700 PSI, 13 HP-GX 390. How do we get this?
The numbers you have listed are for the engine, Honda doesn't actually make pressure washers but makes the engines. If you are looking for the manual on the pressure washer itself you are going to have to find some other numbers that should be listed on the frame of the machine.
Nov 01, 2010 | Honda Garden
Got a Dewalt 3800 PSI Pressure Washer with 4.0 GPM with a Honda GX 390 gas engine. Tipped it up to roll it out to my truck and got a big puddle of water with what looked like Pump oil in the puddle. Can...
Could very well be. Did you check the oil level and condition of oil? If its too full or if its light brown milky, then water has entered crankcase. Pressure washer pumps cannot stand to ever let run dry. Even a little. Also excessive idling will overheat pump if it doesn't have a thermostatic relief valve that allows some more cool water to enter pump.If it doesn't have one add one. Find your PUMP mfg and model number. IF it's pumping good now and no leaks, quick replacing the seals will save big future repairs. www.pressure-washer-parts.com has lots of info on many pump manufactures. Or get some seals from dewalt.
Aug 11, 2010 | Dewalt 3800 PSI Pressure Washer
I need to buy a pressure washer for residential/commercial work
Were I to pick from one of those three, I would pick the Landa. The most reliable pumps are Hotsy and since Karcher bought Landa and Hotsy, those three brands now have Hotsy pumps, though it doesn't say it on the machines.
Jan 01, 2010 | Honda Pressure Washer PSI 3000
Honda gx 390 only starts when it feels like it
Sometimes you have to lower the air pressure in the tank to allow it to run. The back pressure from the compressed air in the compressor head overcomes the pressure created in the engine at the slow RPMs you are able to pull while attempting to crank it.
Aug 13, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Open Questions:
See all Caterpillar Cat Pump Pressure Washer Pump 3SP30G11 Questions
Caterpillar Cat Pump Pressure Washer Pump 3SP30G11 Logo
69 people viewed this question
Top Caterpillar Garden Experts
J.D. Browning
J.D. Browning
downhille
Bill Boyd
Are you a Caterpillar Garden Expert? Answer questions, earn points and help others
