Have a Batching system that uses two interface ISA
Cards Installed RE-Man ITOX G4620-N. And unable to have computer reconize the two interface cards ??
WOW must be a fairly old system if it still has ISA slots.
Are you running XP or something else?
I assume you have the manufactures drivers that match the operating system you are using?
Have the isa cards worked in this system before?
My memory of isa cards is they are really useless at managing interrupts and I/O addresses. Go into device manager and see if there are any conflicts.
Try installing one card at a time. once it is recognised you can try the second one.
Also go into the bios settings page and turn off devices you are not using like serial ports and parrallel ports. if you have a sound card remove it or disable it if is onboard.
If you know what Interupt the cards is tyring to uses you should be able to reserve it in the bios so that plug and play devices won't touch it.
With a some trial and error and a combination of all these settings you should be able to figure it out.
siawolf I'm running DOS 6.22 I Thought (??) cards would be Plug & Play ??
some had to be jumpered to use specific irq's, which also have to be free or shared irq's. do these have settable jumpers on the isa cards? do you have the setup note that came with the cards?
are the cards plugnplay or jumpered?
