Question about Crosley caw9244xq 3.4 cubic foot white super capacity top load washer
Replaced ECU and tried to calibrate, but I can't get machine to enter the diagnostic mode, fill light will blink, machine fills and drains, but won't agitate
3 Suggested Answers
  • 61 Answers
SOURCE: Kenmore 80 series
ok sound lie a broke drive coupling lean the machine back look under the front you will see the motor in the center with a pump mounted on the front behind the motor is the gear case between the motor and gearcase is the drive coupling. To replace it disconect the power, remove the two clamps holding the pump on,remove the pump disconect the wiring harness to the motor now on the front of the motor there are two screws one on top and one one the bottom one the front of the motor with a 1/4 scocket romove the two screws. with a flat head screwdriver release the top clamp on the motor now the motor should tilt down and you can lift it off the coupling is on the short shaft of the motor and on the shaft of the gear case remove both may need to use a flathead screwdriver to get the one off the gearcase replace using a 1/2 deep well scocket and short extention and hammer tap them both on lightly but be sure the go all the way on put the rubber part of the coupling on the gearcase side and turn one of the fingers to 12:00 position turn one on the motor to 6:00 put motor back on the gear case bracket and put the top clamp on frist put the bottom clap back on insert screws put pump back on put pump clamps back on note you will have to turn the ootor to line the shaft up to go into the pump reconect the motor wiring harness plug machine in and test
Posted on Jan 20, 2009
SOURCE: CROSLEY CAH4205AWJ FRONT LOADER WASHER
I know it's been a while since you posted this, but I thought I'd put an "answer" in here in case someone else stumbles across this post when trying to figure out what is wrong with their washer.
I'm not sure how to put it in service mode, but the problem is likely with your water pump. This pump pulls all of the water out of your machine before it goes into spin mode. If the pump doesn't engage then the washer won't spin. You likely need a new pump. They usually cost around $50 and are pretty easy to install. But if you have standing water in your machine, then you are going to have a mess when you pull the hose off to disconnect the pump. I'd suggest having a shop vac handy to **** up all the water as it comes pouring out of the Tub to Pump Hose. A towel isn't going to cut it. You're going to have lots of water that you don't want all over your floor.
Posted on May 29, 2010
My fisher and faykel washer model wa37t26gw2 does not fill, and will not drain. diagnostic says plugged drain hose, but it is clear from pump to diverter
Your question does not make sense. You say it does not fill but then you say it will agitate. How can it agitate if no water has filled? Does it beep and give an error code/ If so what is the error?
Jul 23, 2016 | Fisher and Paykel Washing Machines
Bosch Dishwasher model SHU66C06 doesn't enter wash cycle
this sounds like flow sensor failure,it it fails machine will either not fill up or fill and drain without washing its a cheap part to replace and is fitted downstream of inlet valve behind l/h/s side panel either attached to inle hose or heat exchanger.
Mar 03, 2017 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
417-44052400 Fills with water, washes, drains/spins then comes to a stop. If I did the diagnostics right it indicates E11? Anybody else have this problem?
e11 is a water problem filling to slow,you could have a problem with your cold water fill line,clogged sediment in the valve or something like that,when it goes into rinse the machine uses cold water so the clothes won't wrinkle and it sounds like it's filling to slow.
Nov 26, 2011 | Washing Machines
Unit will not run. cannot enter diagnostic mode.
i would say that you have a bad touch panel..99 percent positive
May 10, 2010 | Dishwashers
Kenmore Elite Calypso Washer fills then doesn't advance..
You can get a replacement pump at pcappliancerepair.com - part # 285990 - and a lifetime replacement warranty on the pump - for (at this time, July 2009) about $124 total.
However, before you do anything you can run the washer diagnostics by pressing the following key sequence to put the washer into the Automatic Service Diagnostic mode (make sure the washer is EMPTY of clothing when you do this):
Prewash Options --> Wash time --> Prewash Options --> Wash Time (also known as a "Key Dance"). You have to press the 4 keys within 5 seconds for the washer to enter the diagnostic mode.
The washer will start counting down from 99 on the LED display and will run through the following steps:
Display 99-81, Nutate & Fill (washer plate rocking motion is called Nutate), Cold Water, Drive Motor Speed 300
Display 80-61, Nutate & Recirculate, Cold Water, Fabric Softener Dispenser, Pump in Recirculate mode (wash), Drive Motor Speed 275
Display 60-41, Nutate, Fill & Drain, Hot and Cold water, Bleach Dispenser, Pump in Drain Mode - LISTEN FOR IT TO RUN, Drive Motor Speed 250
Display 40-21, Nutate, Fill & Drain, Hot Water, Detergent Dispenser, Pump in Drain Mode, Drive Motor Speed 225
Display 20-01, Spin & Drain, no water fill, no dispenser solenoids, Pump in Drain Mode, Drive Motor Spin Speed 500
Return to Standby at the end of the countdown.
You can press Cancel at any time.
Also, if you can get the washer drained, when you tip it on its side and open the bottom cover (unplug the AC power first and secure the water lines & drain), if you shine a bright flashlight up inside the outer case of the washer, look for a plastic sleeve with some paperwork in it.
If it is there, you will find the washer's Service Diagnostic Paperwork, a large fold-out sheet that shows all the keystrokes, like those documented above, for putting the washer through a bunch of diagnostics.
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
Crosley caw9244xq 3.4 cubic foot white super capacity top load washer Logo
32 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
