Question about kawasaki 21.6 volt Cordless Drill Driver 2 batt
The switch on my 691758 drill works sometime and sometime not. Can I get a new switch.
Where can I get a switch for drill?
The manufacturer. Just cross your fingers re the price. Sometimes they will charge you more for the trigger assembly than for a brand new drill!!!!!!!!!!!!
Jun 07, 2015 | Drills
My corded drill only works in reverse
Your R/L switch is probably faulty. Sometimes the little pin on top of the switch brakes off.
Jan 23, 2013 | Craftsman 3/8" Corded Drill
I have a dd200 hilti core drill & the motor stopped working & i cant restore the reset switch
sometimes the motor of it have something called CARBON BRUSH inside,, try to look at it and replays a new one,,,,it is the most common trouble of a drill when its getting old olready but still can be fix by your self..good luck its not to hard..
Feb 17, 2012 | Drills
Switch sometimes does not work
The switch on these drills is notorious for doing exactly what you describe. One thing to check is the battery terminals on the bottom of the switch, they get bent or broken off easily. It could also be internal to the switch but the only fix is to replace it. You need Dewalt part number 152274-22 to repair the drill. It's a fairly easy repair but shop the internet, they cost from $55 to $75 plus shipping.
Feb 03, 2012 | Dewalt DC988ka 18 - volt XRP 1/2''...
When I pull the trigger on my Dewalt dc925 xrp hammer drill it's working for a bit then stopping and starting
it sounds like you have a problem with the switch or battery. Try cleaning the battery contacts first and then remove the battery and look into the tool and see if the switch contacts are bent not allowing battery to seat firmly. If that is OK then I would think that you need a new switch. MAKE note of how you remove it because it is polarity sensitive. Let me know if you need more assistance.
Jan 09, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Jul 24, 2010 | Bosch Drills
Drill stopped work ing when hot. One drill we bought stopped after 10 6mm holes. The others work when you pull the trigger and then sometime they don't.
Sounds like a burned out motor.
Sometimes you can replace the brushes and make them work again.
When operating that drill, make sure that you are not overheating the motor.
Depending on the material that you are drilling, you may need to use the drill on a slower speed in order to not overheat the motor.
Another way is to have more than one drill, and switch to a cool one as soon as you notice heat on the in-use drill.
If your drill is battery powered, stop using the drill and change the battery as soon as the battery dies enough to slow the speed of the drill.
Operating the drill under reduced power is very hard on the motor for several reasons.
Oct 28, 2009 | Milwaukee Tool Drills
Shake the drill to make it work
I just replaced the switch assembly for the same problem
Jan 12, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
kawasaki 21.6 volt Cordless Drill Driver 2 batt Logo
Top kawasaki Drills Experts
jasbo
jasbo
Jim London
Jim London
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
