Question about Vector VEC010S Jump Start System 300 Amp starting power
Where does one find a replacement battery for a Veco 10S? The battery indicates HYS1290 but no one has the correct battery (connectors)... Thanks CCS
Go to battery spec.com look up battery jump start then click on vector jump starter battery is a TR9-12A
Posted on Dec 08, 2015
How do i refresh a veco t2pob battery jump starter
You need something like this http://www.ebay.co.uk/itm/12v-2a-2000ma-power-supply-adapter-with-multi-connector-universal-plug-charger-/231590081325
Aug 15, 2015 | Vehicle Parts & Accessories
Veco 11 300 amp jump start system power supply
recharges from standard AC
Use an w\extension cord
Oct 05, 2014 | JUMP START SYSTEM
Charge indicator
Perhaps you want to charge via a USB connector on your PC. Could be the PC connections are not correct for delivering 5V on that connector.
The manual also says:
Connect the camera directly to the computer; do not use a USB hub or keyboard.
Please try to charge via the external charger that came with the camera. If that fails too, please try to replace the USB cable.
Nov 09, 2013 | Fujifilm FinePix T400 Digital Camera Black
How do i change the battery on an hp 10s calculator
Steps
1.Remove the two screws on the back cover using watchmakers screw driver
2. Use a 4mm this flat screwdriver blade and remove the back cover by twisting it
3. Replace the battery [LR55] , put the cover back by pressing and replacing the two screws
4. Your calculator is ready to use
Aug 10, 2011 | HP 10s Scientific Calculator
Have a vector model veco 10 BD jumper box. need battery replacement. where can I call and order?
The cost to ship lead-acid batteries is really cost-prohibitive. I suggest going to your local Batteries-Plus store for the replacement.
Nov 03, 2010 | Vector Electronics - Others
How to check engine lgiht with paper clip
I am sending you a exploded view of the location of the service check connector, this is a two wire connector that can be jumped with a paperclip to access your trouble codes. To check the codes while ignition switch is off jump your two wire connector with a paperclip. Turn ignition switch on while watching your MIL lamp for the series of long and short flashes, the long flashes indicates the number in the 10s column. The number of short flashes indicates the number in the 1s column. For example, 4 long flashes followed by 3 short flashes would indicate DTC 43. I hope this will be of some help to you, good luck
Oct 05, 2009 | 1996 Honda Accord
Red light
There are two 3300Uf @ 35V capacitors that will cause that problem they are located on the PWB. they are right next to each other and the only ones with that rating on the PWB board
Apr 10, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Vector VEC010S Jump Start System 300 Amp starting power Logo
319 people viewed this question
Top Vector Electrical Supplies Experts
Steve
Gene Haynes
Are you a Vector Electrical Supply Expert? Answer questions, earn points and help others
