Question about Hayward SUPERPUMP 2.0 HP, 115/230V
Put new seals in pump - Hayward SUPERPUMP 2.0 HP, 115/230V
    Top Expert:
  • Hayward Master
  • 5,743 Answers
If seals are bad probably ruined bearings in motor replace whole unit
Posted on Jun 05, 2016
Pool pump leaks
This will be a ceramic seal that seals between the impeller (motor side) and the pump housing. The seal is hard to change if you don't have a shop. If by chance you do get it apart be sure not to contaminate the new ceramic seal surfaces. You should have new bearings installed in the motor while it is down and apart.
Jul 21, 2014 | Pool & Spa
Put in new motor, but pump will not turn. a.j. smith motor, pentair ultra flow... installed new seals also
The most common reason is you left part of the old seal stuck on the impeller and the new seal is riding on top of the seal ring (black rubber) of the old and therefore is tom compacted and it binds up the pump. Double check you removed all the old seal parts.
If that's not it, with the impeller off, can you turn the motor shaft then?
John
May 29, 2011 | Pentair 15 Hp Superflo Swimming Pool Pump
PUMP NOISY, WATER LEAKING
Your pump shaft seal is leaking and has flushed the grease out of the bearings. Any reputable spa or pool company should be able to replace the bearings and the seal kit for far less than the cost of a new pump. Approx $150.00 to re and re bearings and seal kit.
Oct 17, 2010 | Sta Rite Above Ground 1 12 POOL PUMP 15 HP...
How do i change water pump seal on a 1996 suzuki rm250
easy. just remove the water pump from the engine. now, you remove the shaft from the water pump, and put the new seal in. The other way that sometimes works, is prize the old seal out with a very small screwdriver, and then just tap the new one in over the shaft.
May 10, 2010 | Suzuki RM 250 Motorcycles
How do I replace a washer pump on a 2004 silverado 2500HD
Remove the air cleaner, then remove the washer container. Then unhook the washer tubes. Next remove the pump by carefully pulling the pump from the retainer on the container. Then remove the pump from the sealing grommet. Put the sealing grommet on the new pump then push it back into the retainer on the container. Hook back up your hoses then proceed to put the washer container back in and the same with the air cleaner.
Feb 04, 2010 | 2004 Chevrolet Silverado 2500HD
Need to put in new bearing, it is really starting
Bearing on new motor failed for some reason, Make sure the new one will last, check that all shields and water deflecters are in place and that pump seal is not leaking. New motor bearings should be sealed but water has a bad habit of getting into anytging we try to keep dry.
I recomend replacement of pump seal whenever pump is opened and impeller is removed, cheep insurance. Take your time and make sure everything is clean as it goes back together, don't lubricate the pump seal faces, the ceramic faces are designed to be self lubricating and anything (even fingerprint oils) on them can cause a leak.
Aug 01, 2009 | A.O. Smith SQ1102 Pool Pump Motor
What kind of oil do you put in a tsc130 wayne sump pump
The seal is bad and adding new oil will not fix that problem. If you get the seal fixed, normally you use 20 wt non-detergent oil in submersible pumps.
Jun 27, 2009 | Plumbing
Replaced water pump for the 5th time and it leaks from the hole u
No , it's not normal to leak.
Either , water pump is bad ( 5 times ? )
or instalation was bad or more likely , leak is not the water pump at all
May 09, 2009 | Ford SVT Cars & Trucks
Hayward SUPERPUMP 2.0 HP, 115/230V Logo
22 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
