I have dual monitors and when i pushed ctrl+alt+f1 screen 1 went blank, then i pushed ctrl+alt+f4 and screen 1 came back but then screen 2 went blank. how do i fix this and get both screens back?
computafixa
  • 317 Answers
SOURCE: Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Posted on Feb 21, 2008
  • 109 Answers
SOURCE: X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
Posted on Jun 01, 2008
SOURCE: Screen goes Black about 1 or 2 seconds after powering up.
you have problem wit the lamp just plug in another once you removed the back cover and if the lamp stays on the it is 100%. you do not need original lamp. Any 15" lcd lamp that fits will do the job. HA HA well done
Ahmad
COMPBITS.COM.AU
Posted on Jul 06, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Posted on Jul 21, 2009
  • 19 Answers
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Posted on Jan 18, 2010
I am having trouble logging out of my facebook account because log out is listed or its under the tool bar on the top of the screen
USE ALT-F4 TOGETHER TO EXIT OUT OF ANYTHING THAT YOU ARE IN.
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Jan 06, 2015 | Computers & Internet
Tip
Keyboard Shortcuts
[Alt] and [Esc] Switch between running applications
[Alt] and letter Select menu item by underlined letter
[Ctrl] and [Esc] Open Program Menu
[Ctrl] and [F4] Close active document or group windows (does not work with some applications)
[Alt] and [F4] Quit active application or close current window
[Alt] and [-] Open Control menu for active document
Ctrl] Lft., Rt. arrow Move cursor forward or back one word
Ctrl] Up, Down arrow Move cursor forward or back one paragraph
[F1] Open Help for active application
Windows+M Minimize all open windows
Shift+Windows+M Undo minimize all open windows
Windows+F1 Open Windows Help
Windows+Tab Cycle through the Taskbar buttons
Windows+Break Open the System Properties dialog box
on Apr 04, 2011 | Computers & Internet
Tip
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore...
Windows XP HELP
  • Windows key + R = Run menu
  • cmd = Command Prompt
    iexplore + "web address" = Internet Explorer
    compmgmt.msc = Computer Management
  • Windows key + E = Explorer
  • ALT + Tab = Switch between windows
    ALT, Space, X = Maximize window
    CTRL + Shift + Esc = Task Manager
    Windows key + Break = System properties
    Windows key + F = Search
    Windows key + D = Hide/Display all windows
    CTRL + C = copy
    CTRL + X = cut
    CTRL + V = paste
  • Keyboard Shortcuts
  • [Alt] and [Esc] Switch between running applications
    explorer shortcuts
    END....... Display the bottom of the active window.
    HOME....... Display the top of the active window.
  • Type the following commands in your Run Box (Windows Key + R) or Start Run
  • devmgmt.msc = Device Manager
    msinfo32 = System Information
    cleanmgr = Disk Cleanup
    ntbackup = Backup or Restore Wizard (Windows Backup Utility)
    excel = Microsoft Excel (If Installed)
    msaccess = Microsoft Access (If Installed)
    powerpnt = Microsoft PowerPoint (If Installed)
    winword = Microsoft Word (If Installed)
    frontpg = Microsoft FrontPage (If Installed)
    notepad = Notepad
    wordpad = WordPad
    calc = Calculator
    mspaint = Microsoft Paint
    wmplayer = Windows Media Player
    control = Opens the Control Panel
  • Internetbrowser
  • type in u're adress "google", then press [Right CTRL] and [Enter]
    add www. and .com to word and go to it
  • For Windows XP:
  • Copy. CTRL+C
    Cut. CTRL+X
    Paste. CTRL+V
    Undo. CTRL+Z
    Delete. DELETE
    Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE
    Copy selected item. CTRL while dragging an item
    Rename selected item. F2
    Move the insertion point to the beginning of the previous paragraph. CTRL+UP
    Select all. CTRL+A
    Search for a file or folder. F3
    View properties for the selected item. ALT+ENTER
    Close the active item, or quit the active program. ALT+F4
    Opens the shortcut menu for the active window. ALT+SPACEBAR
    Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4
    Refresh the active window. F5
    Cancel the current task. ESC
    on Oct 12, 2010 | Computers & Internet
    Cant see option to log out/sign out on facebook from Lenovo g50 laptop
    • F1: Help
    • CTRL+C: Copy
    • CTRL+X: Cut
    • CTRL+V: Paste
    • CTRL+Z: Undo
    • CTRL+B: Bold
    • CTRL+U: Underline
    • CTRL+I: Italic
    Oct 02, 2014 | Computers & Internet
    Proper booting up, what needed to type f4 or f2
    Restart your computer
    During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys
    Acer: - Ctrl+Alt+Esc
    ALR PC: (F2) or (Ctrl)(Alt)Esc)
    AMI BIOS: (Del), (F1) or (F2)
    AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
    Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
    Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced Bios features press Enter you will see what the boot order is set to.
    IDE-0 means Pri master ?
    IDE-1 means Pri slave ?
    IDE-2 means Sec master ?
    IDE-3 means Sec slave ?
    If you are unsure on what the boot order should be you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
    This will set the boot order.
    Dec 01, 2012 | Microsoft Windows XP Professional With...
    Tip
    Key-bord shorcut
    · Shift + F10 right-clicks.
    Win + L (XP Only): Locks keyboard.
    Similar to LockWorkstation.
    · Win + F or F3: Open Find dialog. (All Files) F3 may notwork in some applications which use F3 for their own find dialogs.
    Win + Control + F: Open Find dialog. (Computers)
    Win + U: Open Utility Manager.
    Win + F1: Open Windows help.
    Win + Pause: Open System Properties dialog.
    · Win + Tab: Cycle through taskbar buttons.
    Enter clicks,AppsKey or Shift + F10 right-clicks.
    · Win + Shift + Tab: Cycle through taskbar buttons inreverse.
    · Alt + Tab: Display CoolSwitch. More commonly known as theAltTab dialog.
    Alt + Shift + Tab: Display CoolSwitch; go in reverse.
    · Alt + Escape: Send active window to the bottom of thez-order.
    · Alt + Shift + Escape: Activate the window at the bottomof the z-order.
    · Alt + F4: Close active window; or, if all windows areclosed, open shutdown dialog.
    Shift while a CD is loading: Bypass AutoPlay.
    · Shift while login: Bypass startup folder. Only thoseapplications will be ignored which are in the startup folder, not those startedfrom the registry (MicrosoftWindowsCurrentVersionRun)
    · Ctrl + Alt + Delete or Ctrl + Alt + NumpadDel (BothNumLock states): Invoke the Task Manager or NT Security dialog.
    · Ctrl + Shift + Escape (2000/XP ) or (Ctrl + Alt +NumpadDot) : Invoke the task manager. On earlier OSes, acts like Ctrl + Escape.
    · Printscreen: Copy screenshot of current screen toclipboard.
    · Alt + Printscreen: Copy screenshot of current activewindow to clipboard.
    Ctrl + Alt + Down Arrow: Invert screen. Untested on OSesother than XP. · Ctrl + Alt + Up Arrow: Undo inversion.
    Win + B : Move focus to systray icons.
    2.) Generic
    · Ctrl + C or Ctrl + Insert: Copy.
    Ctrl + X or Shift + Delete: Cut.
    · Ctrl + V or Shift + Insert: Paste/Move.
    · Ctrl + N: New... File, Tab, Entry, etc.
    · Ctrl + S: Save.
    Ctrl + O: Open...
    · Ctrl + P: Print.
    · Ctrl + Z: Undo.
    · Ctrl + A: Select all.
    · Ctrl + F: Find...
    Ctrl+W : to close the current window
    · Ctrl + F4: Close tab or child window.
    F1: Open help.
    · F11: Toggle full screen mode.
    Alt or F10: Activate menu bar.
    Alt + Space: Display system menu. Same as clicking theicon on the titlebar. · Escape: Remove focus from current control/menu, or closedialog box.
    3.) Generic Navigation
    Tab: Forward one item.
    · Shift + Tab: Backward one item.
    · Ctrl + Tab: Cycle through tabs/child windows.
    Ctrl + Shift + Tab: Cycle backwards through tabs/childwindows.
    · Enter: If a button's selected, click it, otherwise, clickdefault button.
    · Space: Toggle items such as radio buttons or checkboxes.
    Alt + (Letter): Activate item corresponding to (Letter).(Letter) is the underlined letter on the item's name.
    Ctrl + Left: Move cursor to the beginning of previousword.
    · Ctrl + Right: Move cursor to the beginning of next word.
    Ctrl + Up: Move cursor to beginning of previousparagraph. This and all subsequent Up/Down hotkeys in this section have onlybeen known to work in RichEdit controls.
    · Ctrl + Down: Move cursor to beginning of next paragraph.
    Shift + Left: Highlight one character to the left.
    · Shift + Right: Highlight one character to the right.
    · Shift + Up: Highlight from current cursor position, toone line up.
    · Shift + Down: Highlight from current cursor position, toone line down.
    · Ctrl + Shift + Left: Highlight to beginning of previousword.
    Ctrl + Shift + Right: Highlight to beginning of nextword.
    Ctrl + Shift + Up: Highlight to beginning of previousparagraph.
    Ctrl + Shift + Down: Highlight to beginning of nextparagraph.
    Home: Move cursor to top of a scrollable control.
    · End: Move cursor to bottom of a scrollable control.
    on Oct 10, 2010 | Computers & Internet
    Tip
    WORD 2003 Shortcuts
    All Caps Ctrl+Shift+A
    Annotation Alt+Ctrl+M
    App Maximize Alt+F10
    App Restore Alt+F5
    Apply Heading1 Alt+Ctrl+1
    Apply Heading2 Alt+Ctrl+2
    Apply Heading3 Alt+Ctrl+3
    Apply List Bullet Ctrl+Shift+L
    Auto Format Alt+Ctrl+K
    Auto Text F3
    Auto Text Alt+Ctrl+V
    Bold Ctrl+B
    Bold Ctrl+Shift+B
    Bookmark Ctrl+Shift+F5
    Browse Next Ctrl+Page Down
    Browse Prev Ctrl+Page Up
    Browse Sel Alt+Ctrl+Home
    Cancel Esc
    Center Para Ctrl+E
    Change Case Shift+F3
    Char Left Left
    Char Left Extend Shift+Left
    Char Right Right
    Char Right Extend Shift+Right
    Clear Del
    Close or Exit Alt+F4
    Close Pane Alt+Shift+C
    Column Break Ctrl+Shift+Return
    Column Select Ctrl+Shift+F8
    Copy Ctrl+C
    Copy Ctrl+Insert
    Copy Format Ctrl+Shift+C
    Copy Text Shift+F2
    Create Auto Text Alt+F3
    Customize Add Menu Shortcut Alt+Ctrl+=
    Customize Keyboard Shortcut Alt+Ctrl+Num +
    Customize Remove Menu Shortcut Alt+Ctrl+-
    Cut Ctrl+X
    Cut Shift+Del
    Date Field Alt+Shift+D
    Delete Back Word Ctrl+Backspace
    Delete Word Ctrl+Del
    Distribute Para Ctrl+Shift+J
    Do Field Click Alt+Shift+F9
    Doc Close Ctrl+W
    Doc Close Ctrl+F4
    Doc Maximize Ctrl+F10
    Doc Move Ctrl+F7
    Doc Restore Ctrl+F5
    Doc Size Ctrl+F8
    Doc Split Alt+Ctrl+S
    Double Underline Ctrl+Shift+D
    End of Column Alt+Page Down
    End of Column Alt+Shift+Page Down
    End of Doc Extend Ctrl+Shift+End
    End of Document Ctrl+End
    End of Line End
    End of Line Extend Shift+End
    End of Row Alt+End
    End of Row Alt+Shift+End
    End of Window Alt+Ctrl+Page Down
    End of Window Extend Alt+Ctrl+Shift+Page Down
    Endnote Now Alt+Ctrl+D
    Extend Selection F8
    Field Chars Ctrl+F9
    Field Codes Alt+F9
    Find Ctrl+F
    Font Ctrl+D
    Font Ctrl+Shift+F
    Font Size Select Ctrl+Shift+P
    Footnote Now Alt+Ctrl+F
    Formatting Properties Shift+F1
    Go Back Shift+F5
    Go Back Alt+Ctrl+Z
    Go To Ctrl+G
    Go To F5
    Grow Font Ctrl+Shift+.
    Grow Font One Point Ctrl+]
    Hanging Indent Ctrl+T
    Header Footer Link Alt+Shift+R
    Help F1
    HHC Alt+Ctrl+F7
    Hidden Ctrl+Shift+H
    Hyperlink Ctrl+K
    Indent Ctrl+M
    Italic Ctrl+I
    Italic Ctrl+Shift+I
    Justify Para Ctrl+J
    Left Para Ctrl+L
    Line Down Down
    Line Down Extend Shift+Down
    Line Up Up
    Line Up Extend Shift+Up
    List Num Field Alt+Ctrl+L
    Lock Fields Ctrl+3
    Lock Fields Ctrl+F11
    Macro Alt+F8
    Mail Merge Check Alt+Shift+K
    Mail Merge Edit Data Source Alt+Shift+E
    Mail Merge to Doc Alt+Shift+N
    Mail Merge to Printer Alt+Shift+M
    Mark Citation Alt+Shift+I
    Mark Index Entry Alt+Shift+X
    Mark Table of Contents Entry Alt+Shift+O
    Menu Mode F10
    Merge Field Alt+Shift+F
    Microsoft Script Editor Alt+Shift+F11
    Microsoft System Info Alt+Ctrl+F1
    Move Text F2
    New Default Ctrl+N
    Next Field F11
    Next Field Alt+F1
    Next Misspelling Alt+F7
    Next Object Alt+Down
    Next Window Ctrl+F6
    Next Window Alt+F6
    Normal Alt+Ctrl+N
    Normal Style Ctrl+Shift+N
    Normal Style Alt+Shift+Clear (Num 5)
    Open Ctrl+O
    Open Ctrl+F12
    Open Alt+Ctrl+F2
    Open or Close Up Para Ctrl+0
    Other Pane F6
    Other Pane Shift+F6
    Outline Alt+Ctrl+O
    Outline Collapse Alt+Shift+-
    Outline Collapse Alt+Shift+Num -
    Outline Demote Alt+Shift+Right
    Outline Expand Alt+Shift+=
    Outline Expand Alt+Shift+Num +
    Outline Move Down Alt+Shift+Down
    Outline Move Up Alt+Shift+Up
    Outline Promote Alt+Shift+Left
    Outline Show First Line Alt+Shift+L
    Page Alt+Ctrl+P
    Page Break Ctrl+Return
    Page Down Page Down
    Page Down Extend Shift+Page Down
    Page Field Alt+Shift+P
    Page Up Page Up
    Page Up Extend Shift+Page Up
    Para Down Ctrl+Down
    Para Down Extend Ctrl+Shift+Down
    Para Up Ctrl+Up
    Para Up Extend Ctrl+Shift+Up
    Paste Ctrl+V
    Paste Insert
    Paste Format Ctrl+Shift+V
    Prev Field Shift+F11
    Prev Field Alt+Shift+F1
    Prev Object Alt+Up
    Prev Window Ctrl+Shift+F6
    Prev Window Alt+Shift+F6
    Print Ctrl+P
    Print Ctrl+Shift+F12
    Print Preview Ctrl+F2
    Print Preview Alt+Ctrl+I
    Proofing F7
    Redo Alt+Shift+Backspace
    Redo or Repeat Ctrl+Y
    Redo or Repeat F4
    Redo or Repeat Alt+Return
    Repeat Find Shift+F4
    Repeat Find Alt+Ctrl+Y
    Replace Ctrl+H
    Research Lookup Ctrl+Shift+O
    Reset Char Ctrl+Space
    Reset Char Ctrl+Shift+Z
    Reset Para Ctrl+Q
    Revision Marks Toggle Ctrl+Shift+E
    Right Para Ctrl+R
    Save Ctrl+S
    Save Shift+F12
    Save Alt+Shift+F2
    Save As F12
    Select All Ctrl+A
    Select All Ctrl+Clear (Num 5)
    Select All Ctrl+Num 5
    Select Table Alt+Clear (Num 5)
    Show All Ctrl+Shift+8
    Show All Headings Alt+Shift+A
    Show Heading1 Alt+Shift+1
    Show Heading2 Alt+Shift+2
    Show Heading3 Alt+Shift+3
    Show Heading4 Alt+Shift+4
    Show Heading5 Alt+Shift+5
    Show Heading6 Alt+Shift+6
    Show Heading7 Alt+Shift+7
    Show Heading8 Alt+Shift+8
    Show Heading9 Alt+Shift+9
    Shrink Font Ctrl+Shift+,
    Shrink Font One Point Ctrl+[
    Shrink Selection Shift+F8
    Small Caps Ctrl+Shift+K
    Space Para1 (single spacing) Ctrl+1
    Space Para15 (one-and-a-half line spacing) Ctrl+5
    Space Para2 (double spacing) Ctrl+2
    Spike Ctrl+Shift+F3
    Spike Ctrl+F3
    Start of Column Alt+Page Up
    Start of Column Alt+Shift+Page Up
    Start of Doc Extend Ctrl+Shift+Home
    Start of Document Ctrl+Home
    Start of Line Home
    Start of Line Extend Shift+Home
    Start of Row Alt+Home
    Start of Row Alt+Shift+Home
    Start of Window Alt+Ctrl+Page Up
    Start of Window Extend Alt+Ctrl+Shift+Page Up
    Style Ctrl+Shift+S
    Style Separator Alt+Ctrl+Return
    Subscript Ctrl+=
    Superscript Ctrl+Shift+=
    Symbol Font Ctrl+Shift+Q
    Task Pane Ctrl+F1
    Thesaurus RR Shift+F7
    Time Field Alt+Shift+T
    Toggle Character Code Alt+X
    Toggle Field Display Shift+F9
    Toggle Master Subdocs Ctrl+\
    Toggle XMLTag View Ctrl+Shift+X
    Translate Pane Alt+Shift+F7
    Un Hang Ctrl+Shift+T
    Un Indent Ctrl+Shift+M
    Underline Ctrl+U
    Underline Ctrl+Shift+U
    Undo Ctrl+Z
    Undo Alt+Backspace
    Unlink Fields Ctrl+6
    Unlink Fields Ctrl+Shift+F9
    Unlock Fields Ctrl+4
    Unlock Fields Ctrl+Shift+F11
    Update Auto Format Alt+Ctrl+U
    Update Fields F9
    Update Fields Alt+Shift+U
    Update Source Ctrl+Shift+F7
    VBCode Alt+F11
    Web Go Back Alt+Left
    Web Go Forward Alt+Right
    Word Count List Ctrl+Shift+G
    Word Count Recount Ctrl+Shift+R
    Word Left Ctrl+Left
    Word Left Extend Ctrl+Shift+Left
    Word Right Ctrl+Right
    Word Right Extend Ctrl+Shift+Right
    Word Underline Ctrl+Shift+W
    on Dec 03, 2009 | Computers & Internet
    SIR, I wish to known MS Office 2007 advance functining & sortcuts
    Function keysTo do this Press
    Get Help or visit Microsoft Office Online. F1
    Move text or graphics. F2
    Repeat the last action. F4
    Choose the Go To command (Home tab). F5
    Go to the next pane or frame. F6
    Choose the Spelling command (Review tab). F7
    Extend a selection. F8
    Update the selected fields. F9
    Show KeyTips. F10
    Go to the next field. F11
    Choose the Save As command (Microsoft Office Button ). F12
    SHIFT+Function keyTo do this Press
    Start context-sensitive Help or reveal formatting. SHIFT+F1
    Copy text. SHIFT+F2
    Change the case of letters. SHIFT+F3
    Repeat a Find or Go To action. SHIFT+F4
    Move to the last change. SHIFT+F5
    Go to the previous pane or frame (after pressing F6). SHIFT+F6
    Choose the Thesaurus command (Review tab, Proofing group). SHIFT+F7
    Shrink a selection. SHIFT+F8
    Switch between a field code and its result. SHIFT+F9
    Display a shortcut menu. SHIFT+F10
    Go to the previous field. SHIFT+F11
    Choose the Save command (Microsoft Office Button ). SHIFT+F12
    CTRL+Function keyTo do this Press
    Choose the Print Preview command (Microsoft Office Button ). CTRL+F2
    Cut to the Spike. CTRL+F3
    Close the window. CTRL+F4
    Go to the next window. CTRL+F6
    Insert an empty field. CTRL+F9
    Maximize the document window. CTRL+F10
    Lock a field. CTRL+F11
    Choose the Open command (Microsoft Office Button ). CTRL+F12
    CTRL+SHIFT+Function keyTo do this Press
    Insert the contents of the Spike. CTRL+SHIFT+F3
    Edit a bookmark. CTRL+SHIFT+F5
    Go to the previous window. CTRL+SHIFT+F6
    Update linked information in an Office Word 2007 source document. CTRL+SHIFT+F7
    Extend a selection or block. CTRL+SHIFT+F8, and then press an arrow key
    Unlink a field. CTRL+SHIFT+F9
    Unlock a field. CTRL+SHIFT+F11
    Choose the Print command (Microsoft Office Button ). CTRL+SHIFT+F12
    ALT+Function keyTo do this Press
    Go to the next field. ALT+F1
    Create a new Building Block. ALT+F3
    Exit Office Word 2007. ALT+F4
    Restore the program window size. ALT+F5
    Move from an open dialog box back to the document, for dialog boxes such as Find and Replace that support this behavior. ALT+F6
    Find the next misspelling or grammatical error. ALT+F7
    Run a macro. ALT+F8
    Switch between all field codes and their results. ALT+F9
    Maximize the program window. ALT+F10
    Display Microsoft Visual Basic code. ALT+F11
    ALT+SHIFT+Function keyTo do this Press
    Go to the previous field. ALT+SHIFT+F1
    Choose the Save command (Microsoft Office Button ). ALT+SHIFT+F2
    Display the Research task pane. ALT+SHIFT+F7
    Run GOTOBUTTON or MACROBUTTON from the field that displays the field results. ALT+SHIFT+F9
    Display a menu or message for a smart tag. ALT+SHIFT+F10
    CTRL+ALT+Function keyTo do this Press
    Display Microsoft System Information. CTRL+ALT+F1
    Choose the Open command (Microsoft Office Button ). CTRL+ALT+F2
    Jan 05, 2011 | Microsoft Office Computers & Internet
    I want short cuts in ms word
    You can use this
    Ctrl + A Select all contents of the page. Ctrl + B Bold highlighted selection. Ctrl + C Copy selected text. Ctrl + E Aligns the line or selected text to the center of the screen. Ctrl + F Open find box. Ctrl + I Italic highlighted selection. Ctrl + J Aligns the selected text or line to justify the screen. Ctrl + K Insert link. Ctrl + L Aligns the line or selected text to the left of the screen.
    Ctrl + M Indent the paragraph. Ctrl + P Open the print window. Ctrl + R Aligns the line or selected text to the right of the screen. Ctrl + T Create a hanging indent. Ctrl + U Underline highlighted selection. Ctrl + V Paste. Ctrl + X Cut selected text. Ctrl + Y Redo the last action performed. Ctrl + Z Undo last action. Ctrl + Shift + F Change the font. Ctrl + Shift + > Increase selected font +1pts up to 12pt and then increases font +2pts. Ctrl + ] Increase selected font +1pts. Ctrl + Shift + < Decrease selected font -1pts if 12pt or lower, if above 12 decreases font by +2pt. Ctrl + [ Decrease selected font -1pts. Ctrl + Shift + * View or hide non printing characters. Ctrl + Moves one word to the left. Ctrl + Moves one word to the right. Ctrl + Moves to the beginning of the line or paragraph. Ctrl + Moves to the end of the paragraph. Ctrl + Del Deletes word to right of cursor. Ctrl + Backspace Deletes word to left of cursor. Ctrl + End Moves the cursor to the end of the document. Ctrl + Home Moves the cursor to the beginning of the document. Ctrl + Spacebar Reset highlighted text to the default font. Ctrl + 1 Single-space lines. Ctrl + 2 Double-space lines. Ctrl + 5 1.5-line spacing. Ctrl + Alt + 1 Changes text to heading 1. Ctrl + Alt + 2 Changes text to heading 2. Ctrl + Alt + 3 Changes text to heading 3. Ctrl + F1 Open the Task Pane. F1 Open Help. Alt + Ctrl + F2 Open new document. Ctrl + F2 Display the print preview. Shift + F3 Change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word. Shift + Insert Paste. F4 Repeat the last action performed (Word 2000+) F5 Open the find, replace, and go to window in Microsoft Word. Ctrl + Shift + F6 Opens to another open Microsoft Word document. F7 Spell and grammar check selected text and/or document. Shift + F7 Runs a Thesaurus check on the word highlighted. F12 Save as. Shift + F12 Save. Ctrl + Shift + F12 Prints the document. Alt + Shift + D Insert the current date. Alt + Shift + T Insert the current time.
    Oct 11, 2010 | G7 Productivity Systems VersaCheck For MS...
    Advise uses of all F Keys.?.
    F1
    Almost always used as the help key, almost every program will open the help screen when this key is pressed.
    Windows Key + F1 would open the Microsoft Windows help and support center.
    Open the Task Pane.
    F2
    In Windows commonly used to rename a highlighted icon or file.
    Alt + Ctrl + F2 opens a new document in Microsoft Word.
    Ctrl + F2 displays the print preview window in Microsoft Word.
    F3
    Often opens a search feature for many programs including Microsoft Windows.
    Shift + F3 will change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word.
    F4
    Open find window.
    Alt + F4 will close the program currently active in Microsoft Windows.
    Ctrl + F4 will close the open window within the current active window in Microsoft Windows.
    F5
    In all modern Internet browsers pressing F5 will refresh or reload the page or document window.
    Starts a slideshow in PowerPoint.
    Sep 30, 2010 | Logitech EX110 Mouse
    Computers & Internet Logo
    178 people viewed this question
    David Payne
    David Payne
